Author Topic: Axles/Slip Rings/Angle Sensors  (Read 2322 times)
Offline jim5192Topic starter
  • "Brains!"
« on: November 15, 2011, 08:25:14 AM »
Hi all. I have a couple questions for those familiar with mechatronic hardware things.
I'm looking for some type of [(angle sensor) + (axle) + (Perhaps a slip ring as well)] all in one. The slip ring is necessarily going to be in the final project that I'm using it for but I could get a slip ring separately.  I was particularly concerned however of how to attach an angle sensor to an axle from two separate.
Regardless I need some way to combine a slip ring (electrical contact through a rotating connection) into an axle along with an angle sensor. How would I go about doing this.
Moreover... I don't even have a good idea for what to buy... what sizes... what tools I'll need to build this thing..
The project is a controlled double pendulum... I'm trying to control it to swing it up and keep it inverted...
here is a rough picture I drew of why I need such a complex [(angle sensor) + (axle) + (Perhaps a slip ring as well)] all in one:
http://s114.photobucket.com/albums/n260/x89codered89x/?action=view&current=11-14-11DoublePendulum.png
Excuse the sloppiness of the drawing... It's a concept drawing only.
My intuition leads me as far as .. "Ball Bearings sound g
"Imagination is more important than knowledge."-Einstein
Re: Axles/Slip Rings/Angle Sensors
« Reply #1 on: November 15, 2011, 09:33:03 AM »
[...] I was particularly concerned however of how to attach an angle sensor to an axle from two separate.
A rotational Hall encoder would work. A magnet on the moveable part and the Hall chip on the other.
They come in various resolutions, but I guess 1024 steps per revolution would be more than enough.
I doubt you'd find something with a slip ring integrated.
  • "Brains!"
« Reply #2 on: November 15, 2011, 09:59:03 AM »
Do you have a suggestion of a particular model? I was hoping to get an analog sensor in particular. Thanks!
« Reply #3 on: November 15, 2011, 12:42:59 PM »
Don't give away your own Google-fun so easy  ;)
Well, I'd suggest a digital sensor, but you can have analog sine/cosine output.
IChaus.de has got both types.
