Author Topic: dc motor swithing problems  (Read 2383 times)
Offline kraeteTopic starter
« on: November 20, 2011, 04:31:55 PM »
i just treid to post this and i think it bugged out so sorry if this is a double post.
i have 2 motors running off a 9v battery, the battery is connected to 2 PNP transistors darlington style so my 3v microcontroller signal will switch them
the setup works perfectly fine except for when i switch off the transistors the motors still spin very very slowly. i added a 10k trimpot to the base to try and tweak it which helps but they still spin, if i leave the transistor off and connect the 9v after they dont spin, only after running and having the transistor switched off do they continue to move
oh and heres a terrible picture
oh nevermind its too large
Re: dc motor swithing problems
« Reply #1 on: November 20, 2011, 05:53:04 PM »
That's not surprising, as the controller will be 3V max and the PNP Darlington has to see an emitter-base potential of less than ~1.4V, which with a 9V supply means it has to be over 7.6V.
You may actually harm the controller this way.
Change it to NPN-PNP instead and it will work.
Need a schematic?
« Reply #2 on: November 21, 2011, 11:58:38 AM »
hmmm im cobbling this together with parts from broken electronics, it seems i only have PNP's. i dropped the supply down to 5v and it seems to be fine. anyway i could make it work with the 9v? i want it to go a bit faster than the 5v will allow.
« Reply #3 on: November 22, 2011, 11:55:14 AM »
That sounds unlikely. Almost any piece of hardware will have more NPN's tha PNP's, as the latter are slightly more expensive.
If you have stripped at least 3 different electronic devices, you're almost bound to have an NPN somewhere.
Find an NPN and try the attached circuit, assuming a power PNP for Q2.
