Author Topic: I can't read this datasheet...  (Read 2326 times)
Offline bobthefirst1Topic starter
« on: April 13, 2012, 09:53:12 PM »
I bought this connector and I can't read the datasheet; it's virtually gibberish. I attached the pdf for you guys to see. If you have any ideas on which pins are for which signal, please tell me. I'm also trying to make an eagle library for it, but I'm relatively new to making custom Eagle libraries.
Thx in advance
« Last Edit: April 13, 2012, 09:55:07 PM by bobthefirst1 »
Offline infurl
Re: I can't read this datasheet...
« Reply #1 on: April 13, 2012, 10:03:27 PM »
The datasheet becomes legible if I view it at 200% i.e. 2x magnification on my screen. Have you tried printing it out on a laser printer? It should look ok on paper.
« Reply #2 on: April 14, 2012, 09:12:09 AM »
Ok, thanks. I can read the little numbers now. I still have two questions. What scale are all the measurements based off of (cm, in, mm, etc). Also, I don't see where it says what pin connects which pin on the ports. I mean I could do it with a multimeter, but I would rather not...
« Reply #3 on: April 14, 2012, 09:30:46 AM »
NVM, I figured them out.
