Author Topic: Reusing a Microchip  (Read 11710 times)
Offline mariusTopic starter
Reusing a Microchip
« on: August 29, 2014, 03:48:57 AM »
It is possible to reuse a Microchip from a board (for example from a VCR player circuit board) to reuse it for my 3d printer project board ? To rewrite the Microchip for a different task ?
Re: Reusing a Microchip
« Reply #1 on: August 29, 2014, 01:55:16 PM »
Do you mean a Microchip manufacture's PIC processor?
It can be reused, re-programmed, only if it can be Erased and then reprogrammed. Look up the part number stamped on the part and read it's data sheet to find out.
« Reply #2 on: August 29, 2014, 02:27:13 PM »
Thank you so much for the answer ! I m just a real beginner and i just received  a big stock of various electronic devices...so i think is the time to use them and to learn in the same time. I start already to build the mechanical part of my 3D printer (model delta) and now i m at the hard part...electronics :)
Your answer is really helping me !
« Reply #3 on: August 30, 2014, 07:08:30 PM »
One more question about the above topic !
Mister (waltr),how can i rewrite the Microchips who was removed from different electronical devices boards ...one by one before soldering them one the new board ??? ...or i can write them after my new board is manufactured,soldered with all of the electronical components ?
You need to read the data sheets and app notes on Microchip's parts. Its all there:
http://www.microchip.com/
« Reply #4 on: August 31, 2014, 06:04:54 AM »
Thanks for the link !  :)
« Reply #5 on: August 31, 2014, 01:06:13 PM »
Sorry to bother again but my problem was not solved with the link from above :(
I can't find any of the compounds ...microchip's on that link ...strange database they have !
For example i give you :
cheertek CT908B 438G6A20328105CFBE
(which is a microchip from a dvd player board ),maybe you can help me ...?
« Reply #6 on: September 11, 2014, 09:03:29 AM »
First, Microchip is a BRAND name like FORD or NISSIAN.
Second, most of this chips found in consumer device like DVD players are custom made and there will be NO INFO available and they are not re-purposable.
