Author Topic: [advertisement] New Gripper Kits!  (Read 10640 times)
Offline ServoCityTopic starter
  • Helpful? 18
« on: October 29, 2014, 01:23:54 PM »
Parallel Gripper Kit A - $14.99
Get a grip! The first in our line of standard size gripper kits is here. The Parallel Gripper Kit A is a simple, durable, and versatile kit that is great for all kinds of robotic applications. The grippers move towards one another in a parallel motion, hence the name, and have a maximum width of 2.80”. By incorporating the Actobotics 0.770” hub pattern into the back plate, and 1.0607” hole spacing on the grippers, you can easily attach nearly any Actobotics component to the assembled kit. Designed for use with any standard size Hitec or Futaba servo (sold separately). The kit is easy to assemble and requires only a Phillips Head Screwdriver.
http://www.servocity.com/html/parallel_gripper_kit_a__637092.html
Standard Gripper Kit A - $9.99
Adding to our line of grippers, is the Horizontal Standard Gripper Kit A! This gripper is a sleek and simple kit that is great for all kinds of robotic applications. The grippers have a maximum width of 4.20” and contoured design to help hold on to larger objects. By incorporating the Actobotics 0.770” hub pattern into the back plate you can easily attach nearly any Actobotics component to the assembled kit. Designed for use with any standard size Hitec or Futaba servo (sold separately). The kit is easy to assemble and requires only a Phillips Head Screwdriver. Compatible with standard size Hitec or Futaba servos (sold separately).
http://www.servocity.com/html/standard_gripper_kit_a__637094.html
Standard Gripper Kit B - $9.99
Introducing the Perpendicular Standard Gripper Kit B! This kit is easy to assemble, durable, and fun. The design allows for a super wide grip, and the mounting plate mates up perfectly with our aluminum channel. Use with any standard size Hitec or Futaba servo (sold separately).
http://www.servocity.com/html/standard_gripper_kit_b__637096.html
