Author Topic: [advertisement] Actobotics NOMAD 4WD Off-Road Chassis  (Read 10631 times)
Offline ServoCityTopic starter
  • Helpful? 18
« on: November 06, 2014, 10:26:59 AM »
NOMAD 4WD OFF-ROAD KIT :#637136 : $279.99
www.servocity.com/html/nomad_4wd_off-road_chassis.html
The fun begins where the road ends!
This is the Nomad 4WD Off-Road Chassis kit! A remarkably easy to assemble robotic platform capable of taking you places a normal chassis can’t go. What makes this chassis kit great is not only its vast amount of attachment points for various add-ons, but also the fact that it is easily and fully configurable to fit your needs!
Video: https://www.youtube.com/watch?v=F_e8d9c3bx0
(the assembly and "in-action" videos are coming soon)
This chassis is equipped with four 5.4" diameter by 2.25" wide heavy duty tires, four super duty, ball-bearing planetary gearmotors with full metal gears and a ball-bearing pivot suspension. Also included in the 4WD Off-Road Chassis kit is a large central ABS plastic body with two large access panels that open up to a cavity large enough for a 7.2V NiCAD/NiMH or other lipo battery and electronics to fit comfortably.
- Top Speed of 5MPH @ 12 Volts
- Weight: 6.45 lbs
- Assembly tools needed: Phillips head screwdriver, 7/64 hex, 3/32 hex
This central body also has a multitude of 0.77" hub patterns, cutouts at the bottom to run motor wires through, and since it is made out of ABS plastic drilling holes for additional mounting options is a breeze.
Questions about the Nomad? Email [email protected]
