Author Topic: Help with transmitter/receiver setup  (Read 10548 times)
Offline CyclonedTopic starter
« on: January 16, 2015, 08:41:16 PM »
I have a FS CT6 tx/rx and I'm having issues. Basically I want to use this for robotics, and connect it like shown in the SoR beginner robotics tutorial video. When I move 1 joystick upward, both servos should go forward and when I move it downward both servos should go back. However, when I tried this, both motors started rotating without me giving any input to the tx.
I have connected 1 servo to Channel 1 and the other to Channel 2. In the configuration software, I set the left joystick to make Channel 1&2 to go forward with max speed when the joystick is pushed upward, and vice versa for when it is pressed downwards. However, at the neutral position, 1 servo is rotates at normal speed and the other is rotating at a slow speed. I tried to make it stop by moving the trims but it hasn't worked. I found this very odd because in the configuration software, it showed that at neutral position neither servo was being turned on.
How can I accomplish this?
