Author Topic: Need help with identification of Maxon EC Motor  (Read 10612 times)
Offline robotics1Topic starter
« on: January 20, 2015, 08:13:43 AM »
I have the maxon EC motor in the image attached. Specs are as follows;
MAXON EC MOTOR
411816 <> 1225974
SWISS MADE 00007
I need the datasheet of this motor. Couldn't find it on the maxon's motor list however.
Any idea ?
Offline mklrobo
Re: Need help with identification of Maxon EC Motor
« Reply #1 on: January 27, 2015, 04:09:26 PM »
 :) Hello!
In the United States, the Thomas Registry has all the listings of the manufacturers.
I would seek out the counterpart in the European theater. Good Luck!   :)
Offline bdeuell
« Reply #2 on: January 29, 2015, 06:45:25 AM »
I would search the web (not just their site) for the part number but if you can't find it anywhere it might not be available
Maxon (and other motor companies) often make customized versions of their motors for particular use cases.
Maxon is a high-quality brand, so the motors should perform well.
You might want to measure the sizes and diameters, and also the winding resistance, of those motors, and compare to the catalog information for stock Maxon motors, to see what base design of motor you're likely dealing with.
Offline Kohanbash
« Reply #3 on: February 01, 2015, 12:50:10 PM »
Have you tried calling/emailing Maxon?
