Author Topic: Robotics project application  (Read 11531 times)
Offline patelshubham1912Topic starter
« on: March 14, 2015, 09:22:41 PM »
Hi guys this is my first robotics project and i need help finding severe applications for this project.
My robot is expected to work in two sessions training and testing.
In training session it will work in an environment where all d objects are kept and one by one it will pick object, capture the
image of an object and keep that object at base location. It will repeat this procedure for all the objects.
In testing phase it will work in the same environment where objects from the training phase are kept and many more objects are
added to the environment. Now what robot will do is differentiate all the new objects from the old ones. Here it will keep all the
old objects at base location and all the new objects at target location.
In short this robot is differentiating all the objects which were there earlier(training phase) and the new objects(Testing phase)
which are added. So can anyone help me find the application for this project it will be of great help..Thank you :) :) :) :)
« Last Edit: March 14, 2015, 09:26:36 PM by patelshubham1912 »
Offline mklrobo
Re: Robotics project application
« Reply #1 on: March 15, 2015, 08:09:33 AM »
 :) Hello!
Sounds like a great application for sorting objects; and if you
can add specific visual inspection, it may be able to be used for
quality management. This would be great for industrial part inspections.
If you could add more features to the visual inspection, (spectral, surface
abnormalities) the wider the target client customer base. Good luck!
 ;D ;D ;D
