Author Topic: PARALLEL CONNECTION OF IG52-04 24VDC 285 RPM Gear Motor  (Read 13310 times)
Offline toufeTopic starter
« on: May 19, 2015, 03:50:47 PM »
I have the AX3500 MOTOR CONTROLLER which can lead 2 motors. My platform needs four motors. Can I connect per two parallel;The type of the motors is: IG52-04 24VDC 285 RPM Gear Motor
Offline bdeuell
Re: PARALLEL CONNECTION OF IG52-04 24VDC 285 RPM Gear Motor
« Reply #1 on: May 20, 2015, 09:44:28 AM »
I would say that it is possible (remember the controller will be handling 2 motors on each channel so twice the current). Based on the specs of the motor controller you are using i assume you have decently sized motors and highly recommend having individual overload protection for each motor. This way if one motor stalls (or overloads) you will protect your system and anyone around your robot.
