Author Topic: Low Friction Potentiometers  (Read 12600 times)
Offline stabilizeTopic starter
« on: May 27, 2015, 06:10:25 AM »
I am looking to add some positional feedback for some micro servos but all my pots require some heft to move.
Are there any other solutions to this? I want it to be reasonably cheap.
I thought about patching into the internal servo as well but was unsure of any things I should be careful off with this method?
Offline mklrobo
Re: Low Friction Potentiometers
« Reply #1 on: May 27, 2015, 04:30:56 PM »
 ;D Hello!
I have not had any time to use micro servos, but have read some material on them.
I have use industrial motors and servos, but still, modular repair was what was done on them.
I would imagine, to acquire positional feedback without pots would guide you into  infrared
detection, or some light triggered metering device.
In the book, "Programming the propeller with Spin", page 204 - 205, indicates counting the
pulses
that was given to the servo. The pulses equate to time, in which, pulses can be converted to
degrees of change.(scales of movement) They compared a pot reading from an analog to digital
convertor would be 0 to 4,095; whereas a signal pulse goes from 750 to 2,250 microseconds.
The cheaper cost of the control is replaced with the labor/memory consumed to program this
control program. But, at least, another option. Good Luck!!!!   :) :D ;D
