Author Topic: linear actuator release?  (Read 12639 times)
Offline man_from_brightonTopic starter
« on: July 04, 2015, 02:24:13 PM »
Hi folks,
I'm trying to build a release for a linear actuator to suddenly fire a weight in one direction. I have a motor attached to a long screw thread to move the weight slowly in one direction. The weight is attached to a spring and so builds up tension as it moves. Does anyone know of a sort of automated "half-nut" arrangement or similar that will spring apart allowing the weight to fly back without having to engage with the thread?
thanks.
Offline mklrobo
Re: linear actuator release?
« Reply #1 on: July 06, 2015, 03:58:56 AM »
 ;D Hello!
I would venture a question, where permissible. Could you explain more of the
setup that you have? And if you cold make a simple "paint" pictorial, I would be more confident
in providing a resolution. Thanks.. ;D ;D
Offline artbyrobot1
    • www.artbyrobot.com
« Reply #2 on: July 10, 2015, 03:20:52 PM »
I'd pull the weight down on to the spring from the sides of the weight and then have the pullers spread outward so that the weight is free to shoot out
