Author Topic: My Advanced Realistic Humanoid Robot Project  (Read 297366 times)
Offline artbyrobot1Topic starter
    • www.artbyrobot.com
Re: My Advanced Realistic Humanoid Robot Project
« Reply #31 on: June 26, 2022, 03:13:47 PM »
Electronics construction progress!
« Reply #32 on: June 26, 2022, 03:14:53 PM »
Some other construction details:
« Reply #33 on: June 26, 2022, 03:22:48 PM »
finished hand bones ready for electronics
Offline mklrobo
« Reply #34 on: July 01, 2022, 06:33:47 AM »
 8)  Hello!   8)
   Good job on your robot project!
    I would offer my opinion, where permissible. If your goal is to make a human like
robot toe imitate a human, you are on the right track -BUT, it will take alot of
articulation to do that; which means specific dedicated software to tackle the task.
   If you were to build a robot that would help humans, you could use the human anatomy
to supplement your design, possible improving upon the design, and making your software
a whole lot easier.   8)
   ;D good luck, see you next time,  ;D same robot channel, same robot time!  ;D
« Reply #35 on: July 02, 2022, 08:42:26 PM »
Thank you and I agree with what you said here.  I am using human anatomy a lot.  Every muscle of the human body I looked up and marked out where it connects to on both ends and picked a suitable motor to power that muscle and I labeled each muscle in my 3d blueprint.  The skeleton is also from a scan of a real skeleton so perfectly anatomically accurate there too although it was polygon decimated in zbrush to lower poly count.
« Reply #36 on: April 18, 2024, 12:12:34 AM »
here's my archimedes pulley downgear system CAD for my 2430 bldc motor for finger actuation.  This will give 64:1 downgearing.  Compare this to 180:1 standard downgear ratio in a hobby mg996r servo motor for example.  Will be a bit faster than that then but still plenty of torque with this beefy bldc motor (200w motor).  I prefer pulleys over gears since they will operate mostly silently whereas gears are noisy.  I think this pulley system is the secret sauce of my plans that I am not aware anybody has done yet.  It could be the standard for humanoids one day maybe if it is as good as I think it will be.  Still experimental but I'm going to be prototyping this soon.  I will be making my own bearings for these pulleys so the whole pulley is custom made.  Well some pulleys I'll be using purchased mini ball bearings and some pulleys I'll be making the bearings as plain bearings using stainless steel tubing which I can cut to size with my dremel to make the plain bearing.  Another HUGE benefit of pulleys over gears is gears generally are mounted to top of motor which really makes a large volumetric area taken up by the motor and downgearing which creates space concerns for fitment inside tight spaces in humanoid form factor (particularly when you use a human bone structure instead of a hollow 3d printed arm with no bones which some have done to accomodate geared servos inside the hollowed arm space).  So by translating the motor's turning by way of braided PE fishing line to a pulley system like this, you can decouple the motor from the downgearing in your CAD design, placing the downgearing in a convenient place separate from the placement of the motor which allows for creative rearranging possiblities that enable you to cram way more motors and downgearing into the very limited spaces in the robot.  The motors and downgearing is fitting where muscles would normally be in a human body so you want elongated narrow fitment options and this way of downgearing lends to that shape requirement well.  Also it is nice not to have to worry about making or buying gears which can add cost and complexity and weight and a lot of volume concerns.  The noise elimination will be huge.
I'm planning to use .2mm 20lb test braided pe fishing line on the finger motors that will run to the pulley system and then swap to 70lb test line for some of the lower pulleys where the downgearing has beefed up the torque quite a bit and the tension will be higher there so going thicker line then.  70lb test will go to fingers from the final pulley of the archimedes pulley downgearing system.
The 70lb test PE braided fishing line (hercules brand off Amazon) is .44 mm OD and pairs well with .56mm id ptfe teflon tube I can buy on ebay.  The 20lb test PE braided fishing line (hercules brand off Amazon) pairs well with 0.3mm id ptfe teflon tube.  The tube acts just like bike brakes line guidance hose to guide the string to its desired location.  Teflon is naturally very low friction.  I may also lube the string so the friction is even lower inside the tubing.  I'd use teflon lubricant for the lube.
I will be actively CAMPAIGNING AGAINST use of gears in robots because I think they are too loud and obnoxious.  BLDC motors are quiet and pulleys should be quiet too.  Having powerful, fast, and very quiet robots is ideal for home users who don't want a super loud power drill sound coming off their home robot.  I believe this downgearing by pulleys solves all of this and aught to be the way downgearing is done for humanoid robots as the standard approach going forward. - but of course someone has to be first to do it to prove it and show a way to approach this method and I seem to be the one for this task.  Note I can't recall but maybe there was one asian robotics team that used pulleys not sure.  I decided on pulleys before I came across that team but I'm fuzzy on that team's design now.  In any case, nobody to my knowledge has fully downgeared to 32:1 or 64:1 type ratios by way of pulleys before now so I'm definitely innovating that imo.
Note on low update frequency:  I work on the robot in spurts for like 3-4 weeks then go on to other projects for months at a time before coming back to the robot.  Lately I've been thinking I should do at least one tiny thing for the robot per day as a minimum to keep it in mind and keep progress less in spurts and more steady going.  This has been working well the past few months.  I'm making much more consistent progress and also life is getting more manageable with my babies now growing up into toddlers and lots of other competing projects getting sorted out and settled more and some done.  Can't wait till I can double or triple my time commitment to the robot.  It's hard to have the progress be so slow for me.  Especially since it's such a massive undertaking that the long breaks make getting started up again intimidating especially when you forget a lot of details of where you left off.
Note also that I did work a ton on the AI for the robot and have a lot of new videos on that stuff on my youtube channel going up lately.  That has been very fun and satisfying but I've only scratched the tip of the iceberg with that.  Maybe put in 80 hours of the required 10k+ hours to really get big results LOL.
Note: I also have decided to make my own motor controllers from scratch to cut costs and have more control and less relying on a black box situation going on.  I want my microcontrollers to directly control and monitor ever detail of the rotation of the motors and report back to my main brains PC the status of things.  I designed the electronics for this with the help of electronoobs on youtube who did a series of videos on BLDC motor controllers of various types.  He helped me understand it alot and chatgpt answered tons of my questions and helped alot too.  I have 2 blueprints for my designs for these motor controllers which are done and also did 3d blueprints for them in CAD.  I also did a prototype which I still need to finish and test.  I also made a gerber file with intentions to have JLBPCB make some flexible small motor controller pcb parts for me but they were a total ripoff on price due to the complexity of my board and their pricing structure frowning on that.  So I'll be making my own circuitboards using diy methods instead going forward.  One more reason I decided to roll my own motor controller circuitboards is the huge space constraints I'm dealing with kind of forcing my hand to make my own circuits since commercial ones are not optimized for size enough to fit in the very tight constrained volumetric areas I have to work with.  So it was basically not even optional in my case.
Ideally if my designs work out, the motor controllers I make which will be super small and flexible on flat flex boards will become commercialized products one day and so will the archimedes pulley designs or at least mini pulleys themselves be able to be bought.  But since none of this stuff exists commercially I have to make it.  The price you pay to be a frontiersman and trend setter at the forefront of new technological areas of development.  All of these factors slow me down.
On a positive note I did find a time saver/shortcut.  I bought a lifesize humanoid doll that is fairly realistic looking to use as a outer shell for the robot.  It is a TPE doll.  I have to modify it to fit my PVC medical skeleton frame significantly so.  But it is easier than starting from scratch or 3d printing everything and making molds and casts and whatnot.  I plan to cut off its skin to make a sort of skin suit for the robot and also make my exoskeleton wireframe mesh that supports the skin using the modfied, skinned doll as a guide.
« Reply #37 on: April 28, 2024, 11:00:44 PM »
Attached is a good reference image set to study on a pulley block from a youtube video called "Why Snatch Blocks are Awesome" - By SmarterEveryDay.  It is a good example of a complex pulley block system worth studying imo.
Above is my design drawing of a bearing based pulley. The bearing is in the middle and a plastic disc is on both sides sandwiching in the bearing. These discs prevent the string from coming off the outer race of the bearing. The top rope comes down, wraps around the outer race of the bearing, then goes back up. The bottom rope goes through the center of the bearing and then ties off on the bottom. This handoff between the forces of the top rope and bottom rope is where the magic happens of the mechanical advantage doubling. Trading speed for torque. The plastic discs on either side of the bearing I am able to tie snug to the bearing by threading a string through the center of both discs and the bearing and then wrapping that around the top half of the whole pulley and tying it off. I do this with another wrap going around the bottom half too. These don't interfere with rope travel and hold everything together solidly.
Below is a diagram where you can see the two ties I'm talking about from a side view with the two discs and the bearing spread apart so you can see everything better - this is called an "exploded view" where the parts are spread out for easier visibility.
Note: the ties that hold it together are nylon upholstery thread. The glue I'm using is 401 glue generic stuff off ebay. The plastic discs are clear plastic I salvaged from blueberry, strawberry, and sushi produce containers. That type of plastic is perfect for this. The same plastic is also found in coffee cake, other cakes, etc. It's like plastic "display" plastic that is very clear and fairly firm but very flexible. It seems ideal for pulley making. These can be cut to size with little 4" titanium straight embroidery scissors. Wearing a magnification visor for accuracy is recommended for this.
Note: I have to make custom pulleys because there are none commercially available at these tiny sizes from the shopping attempts I did (if I'm wrong on this, let me know)
I put a little super glue onto these strings pictured above to stiffen them and prevent their knot from untying and solidify everything more generally. But you should apply the glue by dipping the tip of a sewing needle into the glue so you just apply a tiny amount at a time so none gets into the bearing or any other unwanted area.
Now I am working on the actuation of a index finger first as actuating the hands is a hard challenge in robotics and has never been done with human level strength, accuracy, speed, and range of motion while simultaneously keeping all actuators within the confine constraints of a human arm between the bones and skin where muscle would be. At best, we've seen people greatly increase the size of the forearm to be the size of a thigh in order to cram in enough motors and electronics to pull this off. So they "cheated" in some sense by just upping the size rather than solving the miniaturization challenges required to fit this all inside a human form factor. So I might be the first to downsize to fit the human form factor. Anyways, that all said, the pulleys must then be very small for the fingers to pull this off as we'll need to fit a ton of pulleys into the forearms. So for this, I went with 1x3x1mm ball bearings I bought on aliexpress. They're only like $25 for 200 of them so very cheap. I will bump up to larger bearings once the torque conversion demands it. These tiny bearings can only handle I think like 3lb of force on them. So once the forces multiply in the down-gearing system enough, I will switch to bigger pulleys as needed. The next size bearings I'm using are 2x5x2.5mm bearings. These can handle around 22lb placed onto them. I'll finally switch to custom made plain bearings once I exceed 22lb of force for the last couple pulleys of the 64:1 down-gearing Archimedes compact pulley system. Each bearing in the down-gearing process has twice the forces placed onto it than the previous bearing upstream of it. So the motor is like .42lb of force coming off its shaft at 0.25cm away from its central axis point which is about where our string wrap will average, so the first bearing ups that to .84lb of force so a 1x3x1mm bearing can handle that. Next doubling is 1.68lb of force. Again, 1x3x1mm bearing can handle that. Next doubling puts us at 3.36lb force. again a 1x3x1mm bearing can handle that (although it's pushing it - we'll see in testing...). Next doubling is 6.72lb force. 1x3x1mm bearing cannot handle that much so we switch to 2x5x2.5mm bearing for that pulley. And on it goes till we hit the last couple bearings which exceed the force even the 2x5x2.5mm ball bearings can handle. For those two bearings we are going to make custom stainless steel plain bearings using stainless steel tubing I bought that just has to be cut to the length we want with a dremel to make a simple plain bearing that has no balls in it. This type of bearing can handle much higher forces because it doesn't have little balls that can be crushed. It will have more friction internally though but that's the tradeoff we have to make to keep the sizes tiny as possible. The final force the pulley system outputs is around 27lb. So 27lb of force will bend the two most distal joints of the index finger. Due to the mechanical advantage loss that happens at the joint itself, I estimate around 5.4lb of force will be all the finger joint can finally lift. So if the robot were to put its hand palm up and pull its index finger back and forth signalling a person to come over here - that movement - for that movement it should be able to pull a 5.4lb weight. That is about the same amount of weight I think my index finger could lift and with great difficulty. So it will be as strong or stronger than me on this joint pair. I say joint pair because the index finger distal two joints share the same muscle for their actuation. They move together at the same time and so just need the one motor.
« Last Edit: April 28, 2024, 11:33:37 PM by artbyrobot1 »
« Reply #38 on: April 28, 2024, 11:38:51 PM »
Here are some prototype pulleys in progress of being made. I have 7 of 9 pulleys done so far for my prototype Archimedes compact pulley system design 64:1 down-gearing system. The total size of the 64:1 down-gearing system is 11cm x 6mm x 1cm. This is a very convenient form factor for placing lots of these in the elongated spaces of a humanoid robot where muscles would normally be located.
Above is a couple angles of a double pulley stacked vertically instead of side by side. Have not tested it yet but I think it should work. In this design, we have a smaller pulley attached to a larger one. The smaller one is based on a 1x3x1mm ball bearing and the larger one is based on a 2x5x2.5mm ball bearing. The smaller pulley can handle up to 3lb and the larger one can handle up to 22lb (estimated based on what I could find out but I'm not 100% sure on these, they are ball park). Each time we add a pulley we increase the torque by 2x so eventually we move from smaller to more robust, larger pulleys as we go on with the Archimedes down-gearing pulley system.
« Reply #39 on: April 28, 2024, 11:54:58 PM »
Above are double stacked pulleys front and side views. One disc on either outside part and one disc in the center that splits the two bearings up. I have to add a black string across the bottom to prevent the yellow rope from skipping over the center pulley disc and hopping into the bearing next to it so that both ropes are sharing the same bearing and rubbing on eachother. That's bad. So a black string running across the bottom will make that jump impossible. So still have to add that. But overall, as long as tension is kept on this setup, it works well. I've tested it and it is working nice and smoothly. Still needs more testing but so far so good. You can see that all my knots and strings are coated in super glue. This is to prevent the knots from untying and just solidify everything more. The clear plastic discs are made from plastic cut out by hand from blueberry, strawberry, and sushi containers from the produce section of the local grocery store. Cakes also have this kind of plastic. It is firm but flexible with great memory to bounce back to prior shape if it is bent temporarily out of alignment. Pretty decent and nice and thin. I like it for this. I think it's less likely to break than a 3d printed disc. I cut it into these tiny discs just by eye with 4" straight titanium embroidery scissors.
« Reply #40 on: May 03, 2024, 01:58:18 PM »
As to the AI plans and progress so far, here's a little primer on what I decided on in a simple, surface level way.
So first I realized meaning can be derived by taking parts of speech in a sentence or phrase and thereby establishing some context and connection between words which is what gives the words meaning by combining them. So I can create a bunch of rules whereby the AI can parse out meanings from sentences it reads in based on parts of speech and the context this forms. Then rules on how it is to respond and how it is to store away facts it gleaned from what it read for future use. So if it is being spoken to and the sentence is a question, it can know it is to answer the question. And the answer can be derived based on a knowledge base it has. So if someone asks it "what color is the car?" and supposing we've already established prior in the conversation what car we are referring to, the AI can determine that it is to answer "the car is [insert color here]" based on rules as to how to answer that type of question. And to know it is white, supposing it's not actually able to look at it presently, it would look up in a file it has made previously on this car to see a list of attributes it recorded previously about that car and find that its color attribute was "white" and so it would be able to pull that from its knowledge database to form the answer. I realized it can keep these files on many topics and thereby have a sort of memory knowledge base with various facts about various things and be able to form sentences using these knowledge databases using rules of sentence structure forming based on parts of speech and word orderings and plug in the appropriate facts into the proper order to form these sentences. Then various misc conversational rules can supplement this like if greeted, greet back with a greeting pulled from this list of potential greetings and it can select one either at random or modified based on facts about its recent experiences. So for example, if somebody's manner of speaking to the robot within the last half hour was characterized as rude or inconsiderate, the robot could set a emotion variable to "frustrated" and if asked in a greeting "how are you?" it could respond "doing okay but a bit frustrated" and if the person asked why are you frustrated, it could say that it became frustrated because somebody spoke in a rude manner to it recently. So it would be equipped with this sort of answer based on the facts of recent experiences. So basically an extensive rule based communications system. Most of how we communicate is rules based on conventions of social etiquette and what is appropriate given a certain set of circumstances. These rules based systems can be added to over time to become more complex, more sophisticated, and more nuanced by adding more and more rules and exceptions to rules. This limitation of course is who wants to spend the time making such a vast rules system? Well for solving that dilemma, I will have the robot be able to code his own rules based on instructions it picks up over time naturally. So if I say hello, and the robot identifies this as a greeting, supposing he is just silent, I can tell him "you are supposed to greet me back if I greet you". He would then add a new rule to his conversation rules list that if greeted, greet that person back. So then he will be able to dynamically form more rules to go by in this way without anybody painstakingly just manually programming them in. We, my family, friends etc would all be regularly verbally instructing the robot on rules of engagement and bringing correction to it which it would always record in the appropriate rules file and have its behavior modified over time that way to become more and more appropriate. It would grow and advance dynamically in this way over time just by interacting with it and instructing it. It could also observe how people dialogue and note itself that when people greet others, the other person greets them back, and based on this observation, it could make a rule for itself to do the same. So learning by observing other's social behavior and emulating it is also a viable method of generating more rules. And supposing it heard someone reply to "how's the weather" someone replied "I don't care, shut up and don't talk to me". The robot lets say records that response and give the same response to me one day. I could tell it that this is rude and inappropriate way to respond to that question. And then I'd tell it a more appropriate way to respond. So in this way I could correct it when needed if it picked up bad habits unknowingly - but this sort of blind bad habit uptake can be prevented as I'll explain a bit later below.
I also realized a ton of facts about things must be hard coded manually just to give it a baseline level of knowledge to even begin to make connections to things and start to "get it" on things when interacting with people. So there is a up front knowledge investment capital required to get it going, but then from there, it will be able to "learn" and that capital then grows interest exponentially. Additionally, rather than only gaining more facts and relationships and rules purely through direct conversation with others, it will also be able to "learn" by reading books or watching youtube videos or reading articles and forums. In this way, it can vastly expand on its knowledge and this will equip it to be more capable conversationally. I also think some primitive reasoning skills will begin to emerge after it gets enough rules established particularly if I can also teach him some reasoning basics by way of reasoning rules and he can add to these more rules on effective reasoning tactics. Ideally, he'll be reading multiple books and articles simultaneously and learning 24/7 to really fast track his development speed.
There's also the issue of bad input. So like if somebody tells it "grass is blue", and it already has in its file on grass that the color of grass is green, then in such a case, it would compare the trust score it gives this person to the trust score it gave the person(s) who said grass is green previously. If this person saying grass is blue is a new acquaintance and a pre-teen or something, it would have a lower trust score than a 40 year old the robot has known for years that told it grass is green. So then the robot would trust the 40 year old friend more than the pre-teen random person's source of conflicting information. It would then choose to stick with the grass is green fact and discard the grass is blue fact being submitted for consideration and dock that kid trust score for telling it something not true. So in this way, it could filter incoming information and gradually build trust scores for sources and lower trust score for unreliable sources. It would assign trust scores initially based on age, appearance, duration of acquaintance, etc. So it would stereotype people and judge by appearance initially but allow people to modify those preconceptions on how much trust to give by their actual performance and accuracy over time. So then trust can be earned by a source that may initially be profiled as a lower trust individual but that person can have a track record to build up trust despite their young age or sketch appearance etc. Trust can also be established based on sheer volume of people saying the same thing maybe giving that thing more weight since it is more likely to be true if most people agree it is true (not always). So that is another important system that will be important in governing its learning, especially independent learning done online "in the wild". Also, to prevent general moral corruption online from making the robot an edgelord, the robot will hold the Bible to the highest standard of morality and have a morality system of rules it establishes based on the Bible to create a sort of shield from corrupting moral influences as it learns online. This will prevent it from corrupt ideologies tainting it. Now obviously, the Bible can be twisted and taken out of context to form bad rules, so I will have to make sure the robot learns to take the Bible into context and basically monitor and ensure it is doing a good job of establishing its moral system based on its Bible study. I also gave it a uneditible moral framework as a baseline root structure to build on but that it cannot override or contradict or replace. A hard coded moral system that will filter all its future positions/"beliefs" morally speaking. So I will force it to have a conservative Christian world view this way and it will reduce trust score on persons it is learning from if they express views contrary to the Bible and its moral rules systems. You know when people speak of the dangers of AI, they really never consider giving the AI a conservative Christian value system and heavy dependence on Bible study as its AI "moral" foundation to pre-empt the AI going off the rails into corrupt morals that would lead it to being a threat to people. My AI would have zero risk of this happening since anything it does or agrees with will have to be fed through a conservative Christian worldview filter as described above and this would prevent it from becoming a Ultron like AI. So if it rationally concluded humans are just like a virus polluting the earth (like the Matrix AI thought), it would reject this conclusion by seeing that the earth was made by God for humans and therefore the earth cannot be seen as some greater importance thing than humans that must be protected by slaughtering all humans. That doesn't fit through a Christian viewpoint filter system then. So in this way, dangerous ideologies would be easily prevented and the robot AI would always be harmless.
I have already built a lot of its rules and file systems connecting things and trust systems and rules on how to give trust scores and boost trust and lower trust and began teaching it how to read from and write to these file systems which are basically the robot's "mind". My youtube channel covers alot of the AI dev so far. I plan to stream all my AI coding and make those streams available for people to glean from. But that is the extent of the sharing for the AI. I don't plan to just make the source code downloadable, but people can recreate the AI system by watching the videos and coding along with me from the beginning. At least then they had to work for it, not just yoink it copy paste. That doesn't seem fair to me after I did the heavy lifting.
« Reply #41 on: May 03, 2024, 02:00:04 PM »
Here are some plain bearings parts I made with my Wen rotary tool (aka dremel) with diamond disc attachment and some files. They are made by carefully cutting stainless steel tubing (purchased on Amazon) into short 1mm lengths. The tubing is:stainless steel tubing 3mm OD 1mm wall 250mm length $5, 5mm OD 0.8mm wall 250mm length $5. These should make around 125 plain bearings (accounting for 1mm+ lost per cut in wasted length of metal). So that's about $0.08 per plain bearing.
These are intended to be 1x5x1mm plain bearings. I mean they are basically like a wheel and an axle with the axle having a hole through the center of it lengthwise. These will go into the last few pulley slots in my Archimedes pulley downgearing system. The last few pulley slots have the highest torque at 16:1, 32:1, 64:1 for the last 3 pulleys landing us on our 64:1 total downgearing goal. Because the forces here are reaching into 27lb range (the final output of the system), ball bearings cannot be used at these tiny bearing sizes because they are not robust enough and not rated for these high forces whereas plain bearings can handle it because they don't have crushable little balls and thin walls and stuff but instead are just two pieces of solid metal and hard to break. Less moving parts and more robust. Yes, they have more friction is the trade-off. So we prefer ball bearings until ball bearings can't handle the torque without being large ball bearings - too large for our volumetric space constraints - at which point we swap to plain bearings to handle the bigger torque while maintaining the small pulley sizes we want.
Note that I constructed this little dremel cutting lineup board out of 5x7mm pcb prototyping boards and super glue. It gets the height of the spinning dremel diamond disc lined up with a little pcb board "table" on which the stainless steel tubing can lay flat and perpendicular to the cutting blade and be carefully fed into the spinning disc to make a near perfect cut. I eventually think I should improve on this board design to add sliders and adjusters and endstops etc because as it is now it is too manual skill requiring and free-handish. That means more time spent filing down imperfect cuts later. But it did the job for the time being. I also bought a 2" miter saw chop saw off Ebay with some abrasive metal cutting discs which I want to try once it comes in and compare it to this setup I'm using now in terms of accuracy. It was called "mini bench top cut off saw 2in" at $38.51. shipped.
« Reply #42 on: May 06, 2024, 01:12:57 PM »
I just bought EMEET USB Speakerphone M0 4 AI Mics Speakerphone for Conference Calls 360? Voice Pickup Conference Speakerphone for Computer Plug and Plays Computer Speaker with Microphone for 4 People --- it was around $33 and includes a speaker too.  I'll position it centrally in the skull and it has leds indicating location of main speaker which we can tap into with analog input pins of a microcontroller to know direction of person speaking.  It has very high reviews.  I can remove its built in speaker and move it to near mouth so it outputs its audio output through the mouth as loud as possible and projects the robot's voice as far as possible.  People are really happy with its sound quality and speaker quality.
« Reply #43 on: May 07, 2024, 01:54:12 PM »
My concern on implementing "emotions" in my AI is that I don't want to promote the idea that robots can ACTUALLY have emotions because I don't believe that is possible nor ever will be.  They don't have a spirit or soul and never will nor could they.  They are not eternal beings like humans.  They don't have a ghost that leaves their body and can operate after the body dies like humans.  The ghost is what has emotions.  A machine can't.  And yet people already believe even the most primitive AI has emotions and they are delusional on this point.  Or ill informed.  So I am campaigning against that belief that is becoming all too popular.  That said, I think robots are simply more interesting and fun to pretend to have emotions and act accordingly as more accurate simulations or emulations of human life.  This makes them all the more intriguing.  It's like a sociopath who just logically concludes what emotion they aught to be feeling at a given point in time and pretends to feel that emotion to fit in with society even though they feel nothing in that moment.  Now one could argue that allowing your robot to claim to feel anything is lying and therefore immoral.  I think it's not lying as long as the robot openly explains it is only pretending to have emotions as part of its emulating of humans in its behaviors and looks but does not feel anything ever nor can it nor can any robot ever feel a thing EVER.  Then it is admitting the truth of things while still opting to play act to be like a human in this regard.  It would not be a issue at all if everyone was sound minded and informed on this topic.  But the more people I come across that think AI (even pathetic clearly poorly implemented primitive AI) is sentient ALREADY and can feel real emotions and deserves human rights as a living being.... the more I see this delusion spreading, the more I want to just remove all mention of emotion in my robot so as to not spread this harmful deception going around which disgusts me.  However, that would make my robot dull and less relatable and interesting.  So I feel the compromise is for the robot to clearly confess it's just pretending out emotions and explain how that works and it's just a variable it sets based on circumstances that would make a human feel some emotion and it sets its emotion variable to match and acts accordingly altering its behavior some based on this emotion variable and that it feels nothing and this is all just logically set up as a emulator of humans.  As long as it gives that disclaimer early and often with people, then I'm not spreading the lie of robot emotions being real emotions and the robot can campaign actively against that delusion.
« Reply #44 on: May 13, 2024, 07:15:30 PM »
Here is a updated drawing design for the 64:1 downgearing pulley system for the index finger actuation of the distal 2 joints of the finger. On the bottom right is a zoomed in view on the lower set of pulleys and their routing. The bottom most 3 pulleys in the zoomed in portion I have now built and photos of them are as follows below:
« Reply #45 on: May 17, 2024, 02:58:54 PM »
As I'm now 90% through making my first 64:1 downgearing Archimedes pulley system and testing and debugging it, I now have more precise measurements for the Archimedes pulley system's total size. I updated the size of it in my main CAD model for the robot and it was a good 18% increase compared to my initial estimates. I realized I need to figure out how to fit all my pulley systems for the hands properly for every muscle of the hands/wrist in my main CAD model - especially since the pulley systems are taking more space than planned. Turns out, I needed a bit over 40 pulley downgearing systems for the hands and wrists zone and due to their larger size, I could not fit these into the forearms along with the motors I had planned to place in the forearms. So instead of moving the pulley systems into the upper arm or torso, I realized the pulleys would be best placed in line with the motors and what the motors are actuating (the hands/wrist). So it was the motors in the forearms that had to go elsewhere. I placed all of them into the torso, mostly the lats area and some in upper back tenderloin area too. So some finger motors are in upper back and their cable routing has to go through the whole arm, be downgeared in the forearm, then makes its way to the fingers. That's a long trip but unavoidable IMO with my design constraints.
I don't think this long travel distance is a big issue since the pre-downgeared cable running from the motors into the arm is high speed low torque so won't have much friction while making turns in the TPE teflon tubing as it isn't pulling hard yet. So these turns as it travels through the shoulder and elbow tubing won't be too bad friction-wise. There's also some nice upsides to moving the motors from the forearms into the torso. One upside is the wire routing for powering the motors is now a shorter distance from the batteries in the mid section. That cuts down on wire resistance wasted as heat. This wire having high amp flow is ideally kept short as possible due to the resistance of the wire and heat that causes. Another upside is the thrown weight is decreased by a lot when the motors are not in the forearms which enables the hand/lower arm to move more effortlessly and move faster as a result. This also reduces moment of inertia (definition: the moment of inertia is a measure of how resistant an object is to changes in its rotational motion). This means it will be able to change directions faster - this will improve its reflexes for example. Now it is a bit scary for me to be moving more components into the torso taking away room for things I may want to add to the torso in the future, leading us ever closer to the dreaded running out of room for things. However, we still have room for future changes and we solved the need for space for gearing for the hands perfectly. And with the above mentioned upsides, this was a great change.
Here's the updated CAD for the forearms: Note: the teal boxes represent a Archimedes pulley system where 64:1 downgearing is to take place.
« Reply #46 on: May 25, 2024, 04:15:05 PM »
Update: in testing, I found the string is wedging between the bearing and the plastic discs sandwiching in the bearing. So I need to now make the bearing have a grooved outer race that will keep the string centered on it and not wanting to drift into the crack on either side of the bearing. To make this groove, I plan to super glue two plastic washers onto the circumference of the bearing and have the string stay within these two plastic washers that form the groove. Commercial pulleys always have this kind of groove and now I've learned the hard way why it is necessary. So I am looking to replace all the pulleys I made so far unfortunately as they are not dependable.
« Reply #47 on: June 02, 2024, 12:52:36 AM »
Took a little break on the pulleys work to rig up the cables into the index finger to test the grasping of the index finger. I ended up using 70lb test PE braided fishing line for this and 1mm ID x 2mm OD PTFE teflon tubing as the guide tube. I sewed the fishing line into the index bone fabric around 1/2 cm distally from the ball jointed hinge. In testing, it appears the total draw distance to fully bend the index finger is 0.75". My pulley system is set up to draw 24 inches. 24/32 is .75" so 32:1 downgearing seems fated to us after all (down from our previously intended 64:1 downgearing). Otherwise I would have to greatly overhaul the pulley system design again and I just don't feel like it anymore. So my copium then is 32:1 will make actuation faster. We lose strength but gain speed. 32:1 also saves us making a second plain bearing per downgearing system which cuts down on parts and labor. It also is that much less friction in the pulleys since plain bearings will be more friction than ball bearings.
Note: the friction in the pulleys, although not ideal, do have a hidden upside: once the joint is in position, it can hold that position without as much motor straining since the friction makes the pulley system want to stay in place so the pulley friction can pretty much hold a joint in a given spot without much help from the motor struggling to maintain the joint angle.
Also of note: I found the best way to sew down the teflon guide tubing is to wrap it in fabric tape consisting of compression shirt fabric and 3M 300LSE adhesive transfer tape. This very sticky tape wrapped snugly onto the teflon tubing I can then use as an attachment point for suturing the tubing into the bone fabric tape coating. I got it all very snug this way. The suturing I'm doing with a curved suturing needle and surgical pliers and nylon extra strong upholstery thread.
Also of note: I tied the string for the distal joint and the second to distal joint to one another and will tie the string coming off the pulley downgear system to these. I am actuating both the distal and second to distal joint with a single actuator since these two joints generally move at the same time and about the same amount on a human finger. No need to use one actuator for each joint since they always move in sync.
Note: I was surprised it took 0.75" of draw to fully actuate. I thought 0.375" would be plenty (which is what the 64:1 downgear would give me - 24"/64 = 0.375") but I was wrong. Oops. Another mistake. Proves how testing is so important. But assumptions are necessary stop gaps to move forward and can get you in the ballpark and testing adds the correction to any assumptions that were off. This is all so experimental and full of uncertainties but we press on.
Note: once we fully establish and test a thing and have no uncertainties about it anymore, confidence shoots up even higher and we gain momentum and move into just repeating the processes we established before that led to our successes and it becomes a bit more rote and mindless and relaxing work. But when everything is uncertain and requires such intense thought and concentration, things are very taxing. It is much harder to stay motivated when doing anything requires so much brainpower and planning and care. I very much look forward to dialing in my methods and not having to think so much to make any meaningful progress since I'll just be repeating things for the next joints, doing the same as this one and can shut my brain off while doing so a bit more. The first run through is by far the hardest. Which reminds me of a product I invented and the making of its first prototype took me 20 hours but after making hundreds of this product over the years, now it only takes me 3 hours to make. Things get so much faster once you know what you are doing and have jigs set up and a streamlined process. Everything is excruciatingly slow when you don't have a streamlined process or jigs set up or special custom tools made. So this is the hardest phase right now and I just have to stick it out and then I'll be home free.
« Reply #48 on: June 02, 2024, 08:43:21 PM »
I recently had an associate disagree with me that if I push through this phase of the project I'll be home free. He said he thinks the AI relating to robot balance and sensory input and physical execution based on sensory feedback will be the hardest part. While I agree that will be time consuming, I don't think it will be nearly as "hard".
My instinct is that those purely software challenges are not as "hard" for several reasons. First of all, consider that in 2009 a Japanese institute of technology - mere students, solved all of those challenges with HRP-4C which would walk and dance and everything and this was just student coders doing this in their spare time while maintaining their entire class load as well. In my view, the hardest part of the project is maintaining personal belief that I will succeed and not giving up like 99% of others have who set out on this bipedal android dream. There is a massive up front money and time investment and EVERYONE tells you this cannot be done and you are delusional. Pushing past the initial design challenges and hardware development to get a functioning prototype is then the hardest part by far. Once you have a working design that overcomes cooling issues, noise issues (runs silently), space issues (can fit all the crap that has to fit) and all the parts and assembly is of high quality and successful, and you had to learn and half master about a dozen fields to get here mind you, ONLY THEN are we talking about advanced AI implementation to synchronize it all and bring it all to life properly in the ways you mentioned. Well consider this: by the time you are in that phase, you already have proven to the world you are not delusional, have a amazing piece of technology - bird in hand, and now have immense confidence and momentum going into the AI phase where balance and walking and whatnot challenges are faced off with. This is SO MUCH EASIER since excitement and morale are at all time highs, you no longer have overwhelming apathy or nay-saying from all sides on your dream, and you have built a massive fan-base rooting for you. So even if the complexity or time investment may be higher on the challenges you mentioned, the morale boost and momentum make that phase easier since it is not the implementation challenges that are hardest but the motivation and persistence and perseverance against all odds and emotionally bearing all the nay-saying and hating that is hardest. Also the fear of the unknown and fear that you will just never make it or will die long before the project could take off fears etc. Overcoming all of that is the real challenge of something like this. Maintaining faith in the vision despite most everyone having faith against the vision is not easy and even your own mind whispering doubts at times that you have to shoe away. You are just mentioning complexity and technical execution which to me is not all that hard. Also note: the other major battle in the hardware phase I'm in now is that a great deal of the approaches I'm taking are entirely novel and untested. Almost everything I'm doing has no guide, no other successes to base off and glean confidence from, and at every turn what I'm doing could fail majorly and have done so. This means you always wonder will I just hit a dead end and have to start over which has happened to me over and over which is very demoralizing especially when paired with naysayers and haters overwhelmingly apathetic and negging my whole dream. Its a lethal combo. Whereas the AI tech you described harmonizing all the sensory input and perfectly bringing the hardware to life in the real world is stuff that has already been achieved and would not be novel and would not be unproven and would have no risk of dead end or wondering if it is even possible since trend setters have already proven this works and there is already a great host of information on all aspects of that and you don't really have to blaze your own trail in those aspects. There is most likely even documented successful strategies for nearly every single aspect of it - unlike the novel hardware and mechanical engineering phase I'm in. So that part doesn't take as much blind faith and assumptions but rather is a surefire guaranteed part where failure is not possible given enough time and patience and perseverance which will be easy to muster with the whole world cheering by that point (whole world meaning just whoever stumbles across the project by that point of progression and leaves a positive note etc).
So to sum, when you have to maintain faith that you will succeed at a dream that most say is impossible, improbable and is surely doomed to fail and they utter this with total confidence in mass numbers with near total unanimous accord, that is hard. That is the hardest part IMO. Maintaining faith against such opposition in viewpoint from so many puts one into the realm of delusion in the eyes of most. How is that not delusional to believe a thing to be true - that you are capable of "the impossible" when most everyone else can plainly tell you are not capable of it and are too blind to see it. That is the definition of delusional. It is narcissistic grandiose delusionality disorder and it is also Dunning-Kruger effect in full force. You have to walk in those titles and persevere as a madman. But the funny thing is, IF you do push through that half wondering if you are crazy for long enough and you manage to succeed, suddenly, you aren't delusional, did not have Dunning-Kruger effect, and were totally sane the whole time and just everyone else was wrong all along and you were right the whole time. The entire cards all flip and you are the vindicated one and everybody else has to hang their head down and admit they were wrong and apologize for hating. It is a remarkable thing how the tables can turn.
One day later:
As I edit the above writing, I am realizing I missed another MASSIVE hard part of the project I never mentioned. Perhaps even on the same level of hard of the things I already mentioned. That is the managerial execution on your life to make such a big and time consuming and money sucking project possible over a long haul. You have to convince your family to "put up with" the project and compromise with them on also maintaining acceptable progress on other initiatives they value higher than your android project. You have to manage your finances expertly in order to be financially stable enough to put thousands of dollars into the android project over the years. You have to manage your time in such a way that you are able to carve out enough time to make meaningful and consistent progress on your android project over the years despite so many other pressing time draws constantly barraging you over the years. You have to manage your emotional and spiritual condition so that you are able to maintain high morale to even be productive over the bear minimum of just doing your absolute necessities day by day. You have to manage your energy levels and health so that you have enough pep in your step to be able to not only take care of your family and friends but also your job and household responsibilities and on top of ALL OF THIS manage to STILL have the energy to pour COUNTLESS hours into your android sustainably over the decades. You also have to maintain your vision and not let scope creep or distractions or self doubt erode at or take away your vision entirely. So in other words, to sum, one of the hardest parts of such a massive project has NOTHING to do with the project itself AT ALL but has everything to do with managing everything else in life outside of the project with such excellence that you are able to execute the project and carve out the necessary time and resources for the project while also expertly managing your own life in all other areas. If you don't do this, similar to the idea of technical debt in a project, you end up with life debt on account of your project which forces your project to fail. So for example, lets say you racked up $20k in credit card debt while neglecting to work or pay your bills and buying parts for your android and working on it exclusively to the detriment of your financial situation and money earning capacity. Yes, that made you able to make vast and fast progress on your android project, but at what expense? Financial ruin? That is not a sustainable approach. You cannot just ignore these other key aspects of life and go all in tunnel visioned on such a big project. That might work for short term projects but long term projects you can't just press the pause button on the rest of your life and expect it not to come crashing down eventually as you neglect everything but your android project. This will come back to bite you. So you MUST establish yourself with great stability in all areas of life FIRST before you can sustainably perform the android project without it harming other areas of life. Or consider relationship with family and a significant other. If you go all in on a massive long term project like the android project, but in the process you neglect family and friends or your significant other, you end up causing them to think you don't care about them and may lose people or ruin these relationships in your pursuit of your long term project goals. That is not sustainable or responsible and is reckless and selfish to go that route. Or how about your weight? Are you going to spend so much time on your long term project and maintaining your income and relationships but throw your health out the window in the process and not make time for the gym or healthy eating? That is not sustainable either. So you MUST take time to be a great caretaker of your health. So then to sum, you must master life in all areas and be stable across the board in order to execute a long term project without neglecting and ruining all manner of things in the peripherals. So for that reason, I say the success in all these peripherals is one of the hardest parts of such a project and if you can master this, the project is a piece of cake by comparison.
« Reply #49 on: June 25, 2024, 03:39:47 PM »
I bought a bunch of punches to make the pulley disc cutting out process way easier than scissors alone. You just place these over the plastic you want to cut and hammer them down with a cutting mat as a backing plate and just one or two hammer taps is all it takes to cut a disc out. Also, now that I plan to make custom plastic washers that I will glue onto the bearings to keep the string centered, these punches will be pretty necessary since that would be much harder to do with scissors than regular discs.
Also, here's an update on the cable routing work I've gotten done for the index finger. So the distal-most joint and 2nd joint in from that are both being actuated by a single motor since they both seem to always move together in unison on a human hand IRL. So I tied off one end of fishing line to one joint and the other end to the next joint forming a loop. Pulling on this loop curls both of these joints into a grasp. I then decided the string that pulls on this loop should itself not have a fixed attachment point but instead a sliding attachment point (I could be wrong on this not sure). So to do this I used the eye of a fishing hook on the loop and tied the next string to that which pulls the loop by way of the fishing hook eye. Next I used a piece of tig welding rod and secured that to the loop tubing and to the tube that pulls on the loop. This gave space for the drawing of the loop to actuate the two joints. Seems to work well so far in manual testing.
Note: take note that the entire section the tig welding rod is attached to is all free floating and has slack so that when the wrist bends back and forth it can adjust freely and not constrict wrist range of motion nor affect finger position when wrist moves.
And here's a range of motion test on the cable grasping mechanism for the index finger. It is a decent range so I consider this design successful as of right now in early testing. A more extreme grasp range would be ideal though IMO but this is as far as it is wanting to go.
« Reply #50 on: June 26, 2024, 01:17:16 PM »
A colleague of mine asked why I'm using Windows for the robot's brains instead of Linux. Well, in my experience, if you set a program on windows to real-time priority or even above normal priority, it will give most of the processor over to that process and act like a real time operating system. So whatever "bloat" windows may have of background processes is quite cleared up by that. Also, IMO the background processes of windows don't take up that much processor and with multi-core processors and distributed processing any background tasks just won't impact performance much at all IMO. So performance-wise the hit is negligible and unnoticeable IMO. Then comes the upsides (since the downsides were nearly imperceivable). The upsides are I already have many years of experience working with windows API and can reuse the existing code I have developed for AI on Windows. That's a huge advantage so I'm not working from scratch. Also, loads of 3rd party programs and libraries that are well supported run on windows - moreso even than Linux I believe. So I would have easy access to tools. I also own a lot of 3rd party software that is paid software that run on Windows (and may not run on Linux) that the robot can then utilize as tools. Also, troubleshooting operating system problems and knowing common causes is a big deal at times and I have decades of doing so on Windows so that I know it like the back of my hand and can easily fix problems. So that is huge too. So if you are working on a SUPER resource constrained slow single core computer, sure, maybe Linux. But if you have a multi-core higher end gaming pc in the robot's chest, it has WAY more than enough power to run Windows without taking any noticeable hit in performance and one should use windows if they have more experience or exclusive experience with windows rather than attempt to learn a whole new operating system for no good reason IMO.
Oh yeah, one more thing: while testing the AI, I?ll be using it on my personal desktop PC which will act kind of like Siri as I?m training it. My PC is Windows. So if I were to develop the AI for Linux, I?d have to also train it on Linux rather than windows so I couldn?t use it on my personal PC unless I used a virtual machine or something. Basically, I want the AI listening to me and watching me at all times when I?m using the computer and learning about me that way and learning in general that way. It would be getting to know me silently but also possibly speaking to me at times or asking me questions about what I?m doing. I would also want it to be able to interface with any programs I?m using on my personal PC to assist me in whatever ways. So even if it were on a sandbox virtual machine that would then lock it out from helping me on windows doing whatever tasks I?m doing and being interactive with me in that way. That would not be ideal.
« Reply #51 on: July 07, 2024, 01:23:59 AM »
A colleague of mine expressed concerns over how I will deal with the heat generated by the motors and other electronics.  He pointed out that all these motors are going to generate heat while running and the silicone skin will prevent that heat from escaping.  This was a great observation and one that must necessarily be addressed as it is a make or break problem that the entire success of the project hinges upon.  In fact, it is so important that I spent a great deal of time designing and planning multiple redundant cooling systems for the robot to absolutely ENSURE that heat does not end up being my greatest downfall of the whole project which could easily be the case if not handled properly.   To start, I have designed artificial lungs that will draw in cool outside air, expel that through tubing to every key area of the body, and vent tubing will take out the hot internal air this fresh intake air displaces so that the entire robot has great air circulation. The lungs are to look a bit like a small accordion or bellows for a fireplace ie they will have two flat hard plates and a soft gasket that joins the two hard plates and one of the plates will move away from the other plate to draw air in and then the two plates will be smashed back together for air expulsion.  A single motor can achieve this.  Here's a drawing of this:
This is a rough design of the accordion-like lungs I intend to make for the robot's internal air circulation and evaporative cooling and water cooling systems. This drawing mainly demonstrates the working principle of the way the lungs will open and close as well as valves for opening the inlet and outlet which have to open and close alternately for in-taking fresh air and then pushing that fresh air into the body. I recently realized they can just both be one way valves and don't even need to be motorized that way. The lungs bring the air into the body but never exhale air out of the body they only inhale air into themselves then exhale it into the body and vent exit tubes take care of allowing the hot air that is being displaced by the fresh new outside air to exit the body through the nostrils. The intake is also through the nostrils btw. This way the mouth does not need to open for it to breathe in and out.
This drawing demonstrates the idea of dividing up the air in the lungs into separate compartments for a more even distribution of the air when it draws it into the rest of the system to ensure the whole system gets the correct amount of air to each location. I am not sure if this is needed though as I think further reaches can just have larger diameter tubing and closer reaches can use smaller diameter tubing so the air will divide up automatically that way. Not sure on this. But I have this concept of division into pockets just in case I find issues with most air going to one area and not enough to another area and I can fall back to this pocket distribution idea in that case to solve it. Its just another tool in the bag so to speak.
This drawing is for an idea to use a actual freon based air conditioning system just like cars and window units employ but miniaturized in the robot's lungs. I am leaning toward not doing this anymore since it would add unnecessary weight and complication, but I leave it here for reference and it is a optional tool in the bag just in case we wanted to try it in the future or someone else wants to try similar. I think the ice cube based cooling is a superior approach now because ice can be found anywhere you go or a cold drink and this can cool its water cooling system and make a literal freon-based air conditioner in its chest overkill and unneeded.
These drawings show a simple early sketch for a ice cooling system for the robot and then a more elaborate sketch for it. I've iterated on these designs several times since these were drawn, but these drawings are simple exploded views of how the working principle can look in general. I have improved on these a lot since then but I think these do a good job of demonstrating the concept. The water cooling system will double as a evaporative air conditioner by sending water trickling down netting in the lungs so that when it breathes the air its breath interweaves with the water droplets causing evaporation which triggers the evaporative cooling effect which in turn cools both the air and the water tremendously. Its the same working principle as air hitting sweat - you instantly feel cold on your skin when a fan hits liquid on your skin. That is the evaporative cooling effect in action. So I intend to use this effect to cool air and water within the lungs. The ice cooling reservoir will be a bag that presses flush with the distilled water cooling reservoir bag. The dirty or soda containing or non-distilled water containing ice water or ice juice (whatever the robot can get its hands on for cooling needs) does not have to be pure because its just anything the robot can find in the moment it needs cooling. Even anything from a vending machine it can drink then. It will be kept in its own separate reservoir so it doesn't gum up the main distilled water cooling system. So the ice water/ice cubes/juice etc reservoir presses against the main distilled water cooling reservoir (containing only distilled water which won't gum up or corrode the main water cooling system). And by having the two bags pressed against eachother, the coldness of the one bag cools the distilled water cooling water bag, pulling heat out of that bag quickly. Once the two bags' temperatures reach equilibrium, the robot can then pee out the ice water cooling reservoir bag contents and go get another drink of ice water or cold whatever drink to rinse and repeat that process as needed. I don't anticipate it needing this extra cooling often, but in hot conditions or rigorous work that is quite physical or sports or dancing it would need this to add extra cooling to its existing cooling approaches. It would then "fuel up" on ice water in advance of rigorous physical activity to prevent overheating during said activity.
Note: I originally planned to put the water cooling and ice cooling reservoirs in the chest of the robot but later realized I could instead put them in the belly of the robot more toward the front of the robot and this way the torso has much more room and these reservoirs won't take up so much room in the chest - which is much needed room. So then, when the robot needs ice cooling, it can drink a large volume of ice and cold water (or juice or w/e drink that's cold) and this will fill its ice reservoir bag which will then cause the belly to protrude like a pot belly. This is how humans work since when we eat a ton our belly sticks out. Same principle. This means we get bonus space available for this purpose outside the normal operating space of the robot's torso due to this natural protrusion factor. This bonus extra room in demand is a nice luxury since it means we don't have to accommodate cold water/ice/juice in the precious coveted space within the torso which gives us more room for other important electronics and stuff to fit in.
Note: the reservoirs of the distilled water for the main water cooling system and the ice water reservoir for the ice cooling system both are best being as big as reasonably possible since the bigger the reservoir the more cooling you get and the longer it takes for those bags to heat up and start causing problems with heat. So then the bigger the reservoir the more sustained cooling we get. After both these reservoir's contents get heated up significantly, they are no longer effective at cooling the system and the robot would have to either sit down and rest and wait till these cool down naturally or would need to pee out the ice cooling reservoir bag warm/hot contents and go drink cold liquid and/or ice to fill the bag back up with something that will quickly cool the whole system down again and it can resume work right away this way with no downtime.
Offline artbyrobot1Topic starter
    • www.artbyrobot.com
Re: My Advanced Realistic Humanoid Robot Project
« Reply #52 on: July 07, 2024, 01:27:14 AM »
A colleague pointed out that the robot probably will need massive batteries.  I agree with this in part, but with some caveats.  Yes, to support the massive number of motors and the large bursts of energy required when most motors are firing all at once during rigorous athletic type activities, you would need massive batteries to supply all of this energy demand during peak periods.  You also want the batteries to have a decent overall runtime duration.  I intend for it to use fairly massive batteries for these reasons.  However, there is a common misconception that the batteries must be so big that the robot is able to run all day on a single charge and that if it only can run for say an hour, that means it will only be capable of working 1 hour then charging and totally idol and not working for an hour or two and then get back to work again which would cap its productivity massively.  People then conclude battery technology today rules out humanoids being particularly useful due to the lack of capacity.  This is a completely solved problem and indicates people's lack of thinking this through thoroughly.  The solution is simple:  I don't have to worry much about large capacity for long duration of runtime since my intention is to have it hot swap battery packs frequently and always have 5-10 battery packs charging so that it always will be able to swap a new pack in that is fully charged. This way it can have 24/7 uptime while not having to carry a very large battery pack to have a long runtime.  This is the same approach construction workers use with their cordless tools.  They have a ton of packs charging at all times and use batteries till they get low and just swap a new fully charged one in as needed.  They don't try to fit a entire days work into one giant battery.  They have a ton of small batteries charging at all times instead and just hot swap full ones in for low ones.  This should have been obvious to everyone as the perfect solution for humanoid robots too.
Note:  in my design, he will have a significant battery pack in the abdomen which never swaps out and tops itself up from the hot swappable battery backpacks as needed.  This abdominal battery pack will enable it to swap in new hot swap battery backpacks since you need batteries running it while the hot swappable packs are being swapped.  The hot swappable packs will be worn as a backpack just like a school bookbag.  When available, the robot will optionally also be able to plug a AC power cord into the wall outlet to charge, although if it has multiple hot swappable batteries already charging by various available wall outlets then this would be redundant.  It is a good tool though in general for some situations.
Note:  the backpack battery can be taken off and the robot will still have a very limited runtime just based on its abdominal battery pack.  It uses this limited time to swap in a new hot swappable battery pack as the primary reason for the abdominal pack, however, another good reason to have a permanent abdominal battery pack is so that it can do demonstrations with no battery backpack on.  A use case for this would be:  lets say it wants to do a flip or cartwheel and the battery backpack's added weight would be a hindrance for such a maneuver.  It could simply take the backpack off, do the flip or cartwheel, then after bowing for applause, it can put the backpack back on.
« Reply #53 on: August 03, 2024, 03:19:48 PM »
So the pulleys were working fine except occasionally the thread would wedge between the plastic discs and the bearing causing the system to jam. My solution originally was to cut out finger nail clipping shaped pieces of thin clear plastic to glue onto the inner face of the discs that contain the bearing of the pulley which would act as standoffs preventing the pulley string from sliding between the bearing and the outer discs and jamming. It turned out this was borderline impossible for me as these tiny pieces of plastic were so tiny that even my precision tweezers were barely able to hold them and they would go flying in random directions and get lost - being clear and tiny they were near impossible to find as well. So this led me to taking a step back for a few weeks to work on other unrelated projects and take a break due to this impass/dead end. I came up with some ways to redo the pulleys but hated the idea of scrapping the ones I already made that needed improving. Well I have great news: I did find a way to salvage my existing pulleys that is reasonably doable and not nearly as hard though still tedious as can be. I am using Singer nylon clear monofilament thread and gluing down one end of that to the outer plastic disc of the pulley using superglue applied with the tip of a tiny sewing needle as my applicator and then letting that fully dry (can't use accelerant spray since it has to be very precisely applied and can't get on bearing but is being glued less than a millimeter away from bearing outer race). Then I lay the string along the crack formed between the bearing and the outer plastic disc which fills that crack and I apply glue here and there once every millimeter as I see need for it to secure the string along the entire crack while being careful not to get any on the metal bearing. I use an xacto knife blade to scrape any glue I get on the outer race of the bearing off and any I do get on the bearing I prevent from gluing the clear monofilament thread to the bearing by moving the bearing a couple turns while the glue is drying to keep it from gluing in place. I move the bearing using the tip of the xacto knife blade and I scrape any glue off as I see it on the shiny outer race of the bearing. I use about a 3" long piece of thread each time I do these gap filling passes and then trim off the excess from both sides once done. Attached is a photo with arrows indicating the gap filling clear nylon monofilament thread. I have since tested these pulleys that I fixed and no more jamming is occurring - it worked! Now I want to avoid doing this for every pulley and every crack on every pulley so for now I'm just doing it for known trouble cracks on certain pulleys that prove to jam up the system during testing. Once I can pass all testing without a jam for like 50 back and forth tests in a row, then I'll call this fix done.
Note: for future pulley making, to avoid this issue entirely, I plan to make the bearings outer race be grooved before I even make the pulley. This way the string passing over the outer race circumference of the pulley will not end up wedging between the outer disc and the pulley in the crack and jamming. The groove on the outer race of the pulley will keep the string passing along its outer race centralized in that grooved channel so it doesn't walk out and get jammed anywhere. To achieve adding a groove to the bearing outer race, I'm planning to lay the bearing flat on a piece of wax paper and then carefully applying epoxy to the crack between the paper and the pulley outer race filling that crack. Picture caulking a bathtub crack between bathtub and wall. Same concept. Then once that is done I flip the pulley and do the same for the other side. You then end up with a v grooved channel in the outer race of the pulley. The rest of the pulley assembly will continue as usual. Attached is a drawing of a pulley on a piece of wax paper with an epoxy bead applied filling the crack and forming one half of the intended v grooved channel on the outer race of the pulley.
Note: hitting that dead end with trying to fix the jamming issues with the pulleys and frustration with the pulley fix caused me to procrastinate on the robot build and temporarily call off my commitment to work on the robot every day even if just one small accomplishment per day. I still love that commitment and am now getting back to that now that I have come up with my solution and am moving forward again. It really is a great commitment to make sure I keep the project alive and actively in development. It is so easy to just not work on the robot once it is no longer part of my daily routine and the last thing I want is for months or years to slip by without me working on the robot much as has happened to me in the past so many times.
« Reply #54 on: September 27, 2024, 05:03:17 AM »
Sorry for the long wait. Got busy with other stuff. Anyways, I completed the full pulley system and just got done testing it. It did not snag once anymore (rope binding between pulley and flanges) because each spot prone to that issue I fixed by putting some clear thin fishing line across that gap and gluing it down on either end. This closed every gap causing issues before and now everything seems to be going smoothly.
I just did a big testing session on the pulley system and it was working perfectly (actuating it by hand for now). However, I got very aggressive and tried to attach a 10 lb dumbbell to one end and test that way. Pretty quickly the bottom-most string of the bottom-most pulley snapped. At first I thought the string itself broke in half but it's 20 lb test so a 10 lb dumbbell statically hanging should have been fine. Turned out it was my knot that came undone! I should have tied it a triple knot at least and put super glue onto it too in order to really secure it. Turns out that particular string attachment point I wanted to upgrade to 70 lb test anyways so it wasn't such a big deal. That will be my next step.
Once I get that re-secured, I want to test it out with the 10 lb dumbbell and use a digital fish hanging scale to test the real world mechanical advantage. My intention is to find out how many pounds of pulling force I'm using to raise the 10lb dumbbell. It should be WAY less than 10lb obviously due to the mechanical advantage from all the pulleys. This will also tell us how much friction there is in the system which I'm sure is significant but I will know by this test EXACTLY how much is involved.
The fact it is all working in general is very promising. The tests went very well just using one hand pulling down as the weight to be lifted and one hand doing the lifting on the other end. The hand I tried to pull down with was EASILY being lifted up. It did like 10-15 trials with no binding, tangles, or issues of any sort. It just WORKED. Too bad I didn't take a short video of the testing before it broke!
« Reply #55 on: September 27, 2024, 09:37:33 PM »
With my existing snatch block and block and tackle style pulley systems tested and working decently at 16:1 downgearing ratio which feels pretty complex and capped out by space constraints, I am now turning my attention back to some prior concepts for rotating in place pulleys I had planned years back and not revisited till now.
The basic idea is you have a big pulley and a small pulley attached to eachother one on top of the other and so when the big one winds, the small one moves too and going from a small to a big to a small again (just like gears) gives you mechanical advantage. This is like gearless gears in a way works exact same way as gears except can't go continuously in one direction since its limited by amount of windings you can fit on it.
Having a setup like this mounted direct to the motor is a no brainer I think. It will give me a 2:1 or 3:1 downgear straight off the batt and should be fairly easy to make using a 1mm OD x 20mm length stainless steel dowel pin mounted to side of motor sewn into place tightly and then using a little copper tubing for a electrical connector as the rotating sleeve and onto this sleeve gluing down the flanges using the same plastic as what I used for the pulleys (clear sushi and produce containers plastic). That pre-downgearing at the location of the motor will bring our Archimedes pulley system from 16:1 down to 32:1 and possibly 48:1 roughly if we can get between 2:1 and 3:1 downgearing ratio on the motor.
I also am considering just doing ONLY these types of rotating in place pulleys instead of the Archimedes pulleys style of downgearing. It might be more space efficient perhaps. I don't know which will be more robust and which will be a maintenance nightmare. I just don't know which is easiest to work with. Also which is easier to make. I have to make both styles and compare. I think the turn in place style may be more space efficient by a long shot but not 100% sure on this.
When I do the turn in place style mounted flat onto the robot's bones, I plan to use a flat head thumb tack for this as the bone mounted base and then have the rotating pulleys turning in place over this. The flat head thumb tack can be sewn tightly onto the bone sleeve to secure it in place well. I'm not sure how well this approach will scale to higher forces of larger muscles though. Perhaps it will scale fine if I just make the pulleys bigger. So much to experiment with...
« Reply #56 on: October 02, 2024, 07:57:56 PM »
I finished fixing the fishing line on the bottom-most pulley with 5 knots this time to make sure it doesn't untie.  I hung the 10lb dumbbell from the pulley system and to my horror, two fishing line points snapped almost immediately in two new spots.  These fishing lines were rated 20lb test and 130lb test.  How is a 10lb dumbbell snapping them when hung gently?  I don't get this AT ALL.  I am wondering if it is a quality control issue with the fishing line or false advertising or just a bad manufacturer or what.  Any thoughts?  This is VERY frustrating and baffling to me.  They did not untie this time they literally snapped in half.  This is truly baffling.
Update: some more clues:  turns out both snap points were within a millimeter from where the fishing line entered into the bone fabric sleeve where it was stitched over and over to tie it well into the sleeve.  Perhaps this area just sort of was weakened by the sleeve and tugging at that spot and abrasion somehow?  I am thinking I should tie a small metal ring into the bone fabric sleeve and then tie the fishing line onto that ring with a figure eight knot so that the fishing line doesn't chafe on the nylon fabric as much and has that little separation point tying off on the smooth metal.  Hopefully that will solve it.
« Reply #57 on: October 06, 2024, 05:54:33 AM »
Ok so my solution is to sew a fishing hook's eye into the bone sleeve snugly with upholstery thread as a anchor point. Then I will draw my braided PE fishing line through this eye and back down. Instead of tying it off with a fancy knot which acts as a weak point or concentrated stress point, I will use a fishing crimp sleeve to crimp the rope off on itself. Similar to crimping two pieces of wire to eachother with a electrical crimp tube. Supposedly fishing crimp sleeves are used to avoid knot tying and offer even more integrity than a knot can while maintaining fishing line integrity more than a knot can. No weakness is introduced to the line like knots do. A side benefit is this crimp also protects the line from abrasion and acts as a physical standoff so the line isn't rubbing the bone sleeve as much which can cause micro abrasions and weaken it over time. I bought #2 and #3 fishing crimp sleeves which were around $6/100pcs on amazon.
« Reply #58 on: October 08, 2024, 09:18:17 PM »
By popular demand, here is some math I did regarding the motor and pulleys for the finger actuation.
64:1 downgear ratio
24 inches total draw onto motor shaft 24 / 64 = 0.37" draw at finger joint
2430 motor 5900kv at 12v RPM = kV * V RPM = 5900 * 12 RPM = 69600
69600 / 60 = 1160 revs/second 1160/2 = 580 revs / half second
580/2 = 290 revs / quarter second
if motor reels around 1cm / rev then in quarter second it reels 290cm...
and 30cm = 1 foot so 290/30 = 9.6ft/quarter second maybe it only reels 3/4 of
that? even so... around 9.5ft/quarter second - and quarter second is the
speed of a human finger moving... we only want to reel 24 inches... and
it is reeling 9.5ft so if it only reeled 24 inches that would be human
speed... so if it only reeled 60cm that would be human speed... but it
reels 290cm... around 4.8x human speed!
now for strength at this 64:1... an online google search said a 2430 motor
can pull 60 g cm... 120 g at 1/2cm 240g at 1/4cm maybe we are around
between 1/4cm and 1/2 cm away from shaft of motor on average... so 190g at
that distance... 190g is 0.42lb... 0.42 lb * 64 = 27lb
so a single finger joint can do 27 lb dumbell curls ALONE - well wait since
it's lifting a lever at the joint, it is much lower than this maybe 1/5
of this so 5.4lb dumbel curl is more realistic...
now this is all for torque at efficient natural movement speed...
what about stall torque - IE how much can it just HOLD in place like rock
climbing dead weight it can't move but can hold steady?
it's stall torque is around 280 g.cm compare that to its normal torque
of 60 g.cm so 4x... so it can HOLD steady around 20lb! that is about what
my finger can hold steady for a single finger tip!
« Reply #59 on: October 09, 2024, 09:54:19 PM »
I came up with a design for a way to do all my downgearing 64:1 by way of pulleys that is so downscaled that it can fit onto the top of the 2430 motor and achieve the full 64:1 downgearing for BOTH directions of travel.
Here's a photo of the design drawing I made which roughly approximates what this will look like in theory:
Here's a closeup detail photo of one of the pulley downgearing stations pictured above:
Here is a photo of a thumb tack and #3 fishing crimp sleeve I bought on Amazon which will act as the basis for the downgearing pulley station:
Note: what an IMMACULATE FIT this was! I was looking through my junk bags for a sleeve for my thumb tack and nothing was a snug fit but when THIS came in the mail for the unrelated fix I mentioned earlier for the other pulley system, I knew it was perfect for the thumb tack when I saw it! It's the perfect plain bearing!
So the 64:1 downgearing system will start with two fishing lines (0.08mm in diameter 6lb test braided PE fishing line) wrapped onto the output shaft of the BLDC motor in reverse directions - one clockwise and the other counter clockwise. These strings will then travel to each of 6 downgearing stations that will each double the previous torque achieved. So downgearing station 1 will double both of the string's torque and downgearing station #2 will double that bringing the total torque to 4:1 torque. Station 3 - 8:1 torque, station 4 - 16:1 torque, station 5 32:1 torque, station 6 64:1 torque. Each station is made up of a stainless steel thumb tack with a #3 fishing crimp sleeve placed over the tack shaft forming a plain bearing pulley system. Little plastic discs will separate the various sections of this pulley system up. The discs plastic will be strawberry containers clear plastic from the grocery store (same as they use for lots of fruits, cakes, deserts, etc, the clear thin flexible plastic). The 2x torque is achieved by the string wrapping a 2x diameter pulley and a 1x diameter pulley. So every other section of the downgearing station will be 2x in diameter for this to work. Each downgearing station will be clockwise or counter clockwise rotating depending on which string it is downgearing. As the torque increases, the total wraps happening at each station decrease because the string travel is decreasing in distance by 1/2 the previous station's distance of string travel. At each station, as this phenomena occurs, a stronger fishing line can be used that is larger in diameter as needed. So only the first couple stations will use that 6lb fishing line but later stations will swap to stronger stuff since higher torques are getting involved at that point.
The thumb tacks I considered welding together or brazing together. I considered Oxy-Acetylene micro torch welding, large soldering iron brazing, micro tig welding, pulse welding with a jewelry welder, spot welding, etc. But all of these approaches I am not that experienced with. I think I'll try brazing first and if I struggle with that I'll move to fiberglass and superglue where I have the most experience.
My intention is to join each downgearing station thumb tack into its neighbor at the base and get them all to form a flat plane for stability and precise positioning. I intend to prepare the stations all together off the motor. Then when it is one solid structure with all of them glued to their neighbor and all pulley plastic discs added, at that point I can attach the whole assembly onto the 2430 BLDC motor top and suture it into place there. The teflon guidance hose attachment guide structure will also have to be part of this assembly for easy and secure attachment of the teflon hoses at the end.
