Author Topic: My Advanced Realistic Humanoid Robot Project  (Read 297370 times)
Offline artbyrobot1Topic starter
    • www.artbyrobot.com
Re: My Advanced Realistic Humanoid Robot Project
« Reply #90 on: March 01, 2025, 01:39:06 AM »
Disaster has struck:
In testing recently, I had some VERY bad news: I don't think the spring extension idea is going to work. The amount of force required to unravel the Archimedes pulley system when working against all the friction in that system, the friction in the winch in place pulley, all the friction in the teflon tubing runs, and the magnetic friction of the motor itself while working against the downgearing (since when working in reverse direction it acts as up-gearing) is all working against the spring and I think it's too much to ask of that spring. I can't even really pull by hand - pulling pretty hard like 3-4lb of force it wasn't budging. So this is tragic for my whole approach so far and we have to go back to the drawing board. A proposed massive overhaul solution in next post.
Note: The name of the resistance to turning a BLDC motor has while freewheeling (no electric applied to it presently) is called cogging torque, which is caused by the interaction between the permanent magnets and the stator's iron core. This force may seem insignificant but due to my downgearing system, the spring has to deal with it after it has been multiplied 44 times due to the downgearing the spring would be fighting through from reverse direction at the bottom of the pulleys and traveling through what then acts as upgearing when going in reverse direction from spring's end.
« Reply #91 on: March 01, 2025, 02:02:23 AM »
I think I've solved it! So first, I want real force working on the extension aspect, not some wimpy spring. I already said there's a lot of frictions that extension system has to bust through to work. And I'd hate to have a very strong spring anyways since when grasping, the motor would then be fighting against a strong spring for extension which is a huge inefficiency that works to weaken the grasping action significantly at that point which is bad design frankly. So we want IN DEMAND opposition for the extension rather than a constant opposition of a spring fighting against the grasp attempt of the motor. We also want the motor that does the grasping to actively rotate in reverse direction rather than freewheeling in order to not have to fight it's static friction caused by its magnets which is significant. This means we either have to go with a two motor system - one for grasp direction of the joint and one for extension direction of the same joint (HORRIBLE WORST CASE SCENARIO BUT POSSIBLE IN A PINCH) or we need to go BACK and refute the notion that the motor is unable to operate two separate pulley systems for extension and grasping functions coming from a single motor attached to two pulley downgearing systems. Which would entail the motor turning clockwise to create grasping and counter clockwise to create extension. The problem with such a proposed system is that in theory it was said to be impossible due to the inevitable derailment issues and tension issues that this would invite. I am proposing we tackle those issues it invites head on rather than avoiding them entirely like we were trying to do for quite a while now. It is a VERY tall order to get that to work but that would be the best possible scenario IMO. It is great if we can get it to work since we tap into the full power of a single motor to do both flexion and extension and we then kill two birds with one stone. All the friction issues with the tubing and pulleys is solved by the motor when it reverses directions and actuates the opposing pulley system. We just have to have slack in the line due to the different diameter mismatches of the two different winding directions we face and also have to have that slack pulled taught by some mechanism to prevent slop that causes derailments. I really want to press for that HARD now. But to do that I really have to scrap the winch in place pulley idea basically I think. Well not necessarily - even that I think can be worked out but is higher risk and harder than my current favorite new, novel solution. So we can reattempt winch in place stuff perhaps in the future but I want to set it aside for now. My newest idea is for that first large run-out downgear to be 2:1 and use regular Archimedes pulley system approach but to put that pulley into the torso and have a weight hang off the bottom of it or have a VERY tiny motor attach to the bottom of it that is to place tension onto it regularly to remove all slop. This can be a motor the size of my pinky fingernail perhaps (not sure though). OR a weight. I lean toward using a weight now since that would be easiest I think to pull off. I got the weight idea from studying the cable machine for triceps at the gym the other day. I can have the same type of weights or something similar to those used by gyms. But doesn't have to be adjustable like those but same concept.
Granted one downside to this approach is what if the robot is laying down or upside down wouldn't it not have weight able to pull down by gravity then? So to solve this I can have 3 weights perhaps, one for each possible direction: upright robot, upside down robot, laying down robot... actually 2 weights should be fine: laying down and upright. Hmm... well if he's laying on back or stomach the weight would have to pendulum or slide past a central point to the other side of robot on a track. Yeah that should work! So 2 weights I think can do it. If upside down he's screwed we'll say. He won't use fingers in any direction change way until he flips back around upright or sideways if doing a cartwheel or handstand for a bit. That is a fine tradeoff. Right now I'm thinking a straw with lead tube in it as the weight or something like that. Even considering just using a fishing sinker perhaps at the moment. Have to think on this more...
« Reply #92 on: March 01, 2025, 02:17:54 AM »
Here's the official design drawing of this proposed single motor actuating both forward and reverse directions with two separate Archimedes pulley systems opposing one another. You'll also note that the left hand side of the drawing has a pair of Archimedes 2:1 pulley downgear systems, one for forward and one for reverse directions of motor and these two are going to be very long (16 inches long) and therefore are located in torso. The remaining 16:1 Archimedes pulley downgearing systems will be kept in the forearms near to the finger joints they are actuating as we had planned originally and already have in place.
You'll also note the weight that hangs off the bottom of both of the 16" long 2:1 pulley downgear systems that can keep them both taught at all times despite their varying lengths that will always be changing. The weight is able to slide since it has a fishing hook eye above it and on both attachment points to the 2:1 pulley downgear systems so it is always adjusting these 3 fishing hook eyes to always keep tension on both systems freely.
« Reply #93 on: March 01, 2025, 02:31:24 AM »
Also, I recently stumbled upon a VERY much simplified version of my miniature pulleys. So up to now I've been using 1x3x1mm ball bearings to make tiny pulleys and been variously perfecting this approach but it is still not THAT small and is a bit complex to make and we have to make literally THOUSANDS of these to do the whole robot. That presents a bit of an issue due to the large work that requires. At least until mass manufacture of them comes in one day perhaps. But while DIYing that, it's alot to deal with making SO MANY somewhat challenging to make things. That said, my proposed EVEN MORE miniature and WAY WAY WAY simplified to make pulley is to just use a single fishing hook eye. Literally, that's it. I can use a tiny fishing hook eye and use that as my very first pulley for the 2:1 16" long Archimedes downgearing systems in the torso. This will cut down on size taken dramatically and complexity of its build. It will make the pulley basically failure proof too. The way it will EVENTUALLY fail is by the rope rubbing it enough to cut it in half. But I think the rope would fail before the pulley would fail and so that doesn't matter then. You'd replace them both at once on routine maintenance. No need then to worry about that eventuality. And the ridiculous ease of manufacture of such a simple pulley makes replacing it trivial. I also think that using this just in low load, high speed, low force early pulley downgearing stages is a non-issue since the friction with such a low load on the first downgear or two will be so trivial that the string itself would fail WAY before it would slice through the metal (acting like a saw over time). I think it would take literally MANY years due to the super low friction at these low forces. Now I'll still use the ball bearing style for later stages of downgearing where the loads go way up, but for the first stage or two I think this will work just fine.
« Reply #94 on: March 14, 2025, 03:32:56 AM »
So the idea to move a portion of the pulley system stuff over to the torso is now out because I've been kind of talked out of it so I'm putting that aside for now. Going to actually try to do that stuff within the forearm. Also instead of a fishing sinker I'm going to try to use an elastic cord made for making bracelets for kids. I think that will be enough force just to keep tension on the line that is being unreeled. Doesn't have to be much I don't think.
I'm also considering just hand testing my pulley systems for now. So disconnecting them from the motor shaft entirely so I can just do testing to see how things feel and can observe things easier way quicker and with less hassle. And when I do go to test by way of motor, I'm just going to use a brushed motor and connect a lab power supply by hand with alligator clips so I can avoid messing around with microcontrollers and firmware and custom motor controllers entirely which is a bunch of rabbit holes I want to avoid as I just secure testing my pulley designs for now. I don't want to get hung up in a year or two of electronics stuff just so I can test my pulleys which would be so stupid and annoying. I need to get my testing iterations done as soon as possible without distractions and longer delays. Once I am happy with the pulley's performance and they pass all my tests and everything seems solid then we'll go ahead and connect it back up to the BLDC motor and then will worry about the custom microcontroller and custom motor controller and all the firmware or whatever at that time and will be doing that with the confidence of a big win with the pulley systems giving us momentum as we enter into those rabbit holes of electronics.
« Reply #95 on: March 20, 2025, 02:47:21 AM »
Ok so a quick couple updates.
First, since the ideas for downgearing with pulleys have been coming in fast and furious, ways to do it easier or ways to fit it here or there or what have you, it's getting a bit scattered and I'm now starting to tear down my work too much for my comfort. It's like I'm chasing the next shiny new approach a bit overly now. So I decided to stick to the current approach as long as it is viable enough to be "good enough" so as to not waste my hard work anymore as I was starting to do. For example, the pulley system I was testing with a 10lb dumbbell did not need to be torn down and rebuilt I don't think. Stuff like that is starting to cripple progress in some sense. So my new approach is when I come up with a idea for a possibly better downgear implementation, I will just write it down and put it in a queue. Then on the next joint actuation I will use these. This way I can have like 10 different downgearing approaches over 10 joints and I can compare and contrast them, note the pros and cons of each, and over long term testing I can find the clear winners. This will also give me a greater understanding and experience and take more out of so much guesswork and into more concrete and tested territory on this stuff.
A side benefit is that people tend to think I've progressed zero with pulleys since I keep building them then taking them apart and starting over. At least under this new approach, I get joints done and over with and working before building the next downgear iteration so the progress feels more tangible and the robot gets done rather than just being in iteration and tear-down cycle hell where it appears from the outside like I am not actually accomplishing anything. So that part will be nice.
Another cool development is that I realized I can put a pulley downgear inside a tube. Normally up to now I was exiting the guide tubing to do a downgear and then afterward the string goes back into tubing to go to wherever. But I realized particularly if doing a fishing hook eye downgear that the entire downgear phase of that can fit into a tiny tube and that has some nice perks. For example, if the 2:1 downgear is the first downgear right off the motor, and the motor is reeling in 32" of string, that 2:1 will be 16" long. Well now that I can do my first 2:1 downgear all within tubes, I can run the downgear from the shoulder to the wrist, giving me PLENTY of room to deal with that amount of runout. This is quite exciting and just gives me more freedom and flexibility. I might do something with this for the first couple downgears so a 2:1 downgear pulley #1 and a 4:1 downgear pulley #2 but then do the rest in the forearm as initially planned and most likely using ball bearing based pulleys for the more heavily downgeared higher force phases of the downgearing process.
That all said, I have the downgear system of 44:1 downgear now done and attached to the finger fully and the extension spring attached to the extension side of that joint fully. So I am ready to begin testing and see how much that spring fails to extend the joint due to friction and motor magnetic cogging issues. I will then add more and more springs until it works. That is my solution. Yes, those springs collectively are fighting the motor when the motor goes to actuate grasping, however, that is just a concession we have to make with this design. Other downgearing designs that don't involve springs for that aspect but involve bidirectional motor actuation with pulley systems for either motor direction are coming next. But I'm finishing the spring based design I was talking about for some time now rather than scrapping it as I was planning of late. It is not THAT bad and it deserves to be at least tested and shown the light of day. It would be a shame to waste that work. It was good work. Also, I realize it MIGHT be the best solution. My theory says no but I can be wrong. Testing is the only way to know 100%. So it's worth keeping it as one of the downgearing methods I'll be testing out.
« Reply #96 on: April 12, 2025, 09:31:51 AM »
Ok so I did a big refactor of my pulleys and ran a test again and it still is not working. The first set of archimedes pulleys tops out and can't move anymore while the finger still hasn't moved. This is because of slack in the lines. I did not calculate slack in the lines into my calculations at all and am shocked by how much there is... Rather than do a major new overhaul with new math and new draw distances on every pulley AGAIN, I'm going to just drop the final pulley of the system so instead of 44:1 it will be 22:1 now. While we cut half the grip strength with this move, this might be okay after all. It still gives us 20lb of of burst grip strength I believe and 11lb of casual easy sustainable grip strength. Most common tasks should only require 8lb of grip strength anyways for a single joint tops. Because remember, I'm not doing a single motor for all 3 finger joints but one motor per joint which helps alot in the strength department and control department. So anyways, this hack I think is okay also because it hit me lately that I highly doubt I'd use the full beast mode burst strength of a 44:1 downgear anyways. I'd be too worried about the wear and tear on the fishing lines and pulleys and maintenance times getting too short between maintenance overhauls if the robot is using that level of grip strength for tasks. In reality, I am now imagining I will only let the robot do VERY minimal strength stuff to reduce the maintenance to a minimum. Like sewing, cutting, and delicately picking up small loads. I will treat it like it has the strength of my 4 year old just to baby it and make it last longer between repairs. Kind of like having a old beater car you don't trust and never throttling the engine hard but just gradually easing on the gas pedal to avoid blowing a gasket so to speak and avoid a trip to the mechanic. So that said I think 22:1 might actually be okay. And with that final pulley out of the way, I'll have WAY more than enough draw distance to bend the finger 90 degrees and account for string slack AND account for string stretch over time without any issues at all. Much better. Not to mention we do pick up speed this way and that might be a VERY nice feature when all is said and done. A faster moving finger can speed up its work I think. Like notice how 3d printers go way faster and that speeds up prints. So speed might be king over grip strength in the end perhaps. It's a tradeoff.
Another update is I realized I can wind a second very fine 0.08mm fishing line on the output portion of the winch in place pulley mounted next to the motor and this second line coming off that pulley will be attached to a tension spring consisting of a bracelet jewelery making cord for jewelry for kids. This line will maintain tension on that winch in place pulley and the motor output shaft at all times to prevent derailments. The metal tension spring that extends the finger will then have the help it needs to keep the whole system taught. That's the plan anyways. The runout of this line will need to be 12.48" of tensioned draw. To achieve that I need a length of this cord of about 15" I think which stretches to 27.48" at full extension. This would occur each time the motor causes the grasping actuation and it would be playing tug of war with the motor so that when motor relaxes or reverses direction, the winch in place is remaining tautly in opposition.
« Reply #97 on: April 15, 2025, 02:01:34 AM »
A note on fishing line durability. I think this was mentioned in passing quite a few times but at some point, a mention of durability concerns becomes that final mention that makes you really start to question it more and so I finally did some research on chatgpt and found out a human finger joint probably will actuate like 1-2k times per day which blew my mind since that would add up to like 10-30k times per month and so basically, once a month the main finger fishing lines will likely need replacement. I looked into alternative materials but didn't have much luck. So what to do?
Well after thinking about this a fair bit, my conclusion is to just shrug and move forward as it stands with the fishing line approach. I'll treat them as a consumable. My plan now is to just expect 1 hour of maintenance for every 20 hours of runtime. Or maybe to be more conservative, lets bump that to 1 hour of maintenance to every 10 hours of runtime? Maintenance will involve redoing pulley systems with fresh fishing line, or swapping in full new pulley systems to replace older ones every so often. It can have a pre-emptive maintenance schedule. My intention is that one robot will maintain his neighbor and the two will have a buddy system of maintaining eachother. Once I have expected time to failure of fishing lines established, they can swap in new ones automatically to prevent failures from happening during work times.
I don't think this is too bad of a deal or a deal breaker. Yes, hopefully materials advances will give me a better string one day, but for now, I'm okay with this maintenance scheduling thing. As long as its all automated, I think this is fine.
After all, our bodies muscles constantly need repairs and they grow from the repair process. So what do you expect for artificial muscles that can't self heal? Maintenance has to be a regular thing IMO.
« Reply #98 on: April 24, 2025, 08:45:54 PM »
Update: I bought several sizes of kevlar string to use to replace the PE fishing line particularly in the high tension areas that may face the highest durability challenges. I found it on amazon in many sizes. I just bought one of each size: 0.5mm diameter 50lb test, 0.8mm diameter 100lb test, 1.1mm diameter 200lb test and 1.3mm diameter 300lb test. This is probably a game changer for my project IMO.
« Reply #99 on: April 29, 2025, 07:46:19 PM »
After further consideration, I'm scrapping using the elastic cord for a bracelet idea (as a tension spring for the winch in place pulley). The point of that was to use as little space as possible but I just don't trust it. I am not sure what material it is made of and my experience with rubber bands has always been dry rot issues. I am going with 2mm OD tension spring instead. It has to stretch 12.5" and so I'm using a 12.7" strip of it to start. That feels like a snug stretch but does comfortably reach the 12.5" of stretch needed. This brings its stretched total length to 25.2". I bought 3mm ID 4mm OD TPFE tubing to be its guidance tube for this. That arrives tomorrow and then I can begin assembly.
This 4mm OD guidance tube is a bit bulky and long for the arm IMO so I will relocate it to the torso since if I use this method for other motors these 4mm OD tubes will add up in space taken up fast. The arm can't house them - it's just too much space taken at that point for these. But the torso can house them in the back or sides I think. For now, since the torso is not yet attached, I'm going to place this tube ON the string suspended from my ceiling and treat that string as though it were to torso for now.
« Reply #100 on: April 29, 2025, 08:14:34 PM »
Here is the tension spring in question from the previous post. I want this spring inside the tubing though which is not shown in the drawing of it.
« Reply #101 on: May 10, 2025, 03:46:41 AM »
Good news: I had mentioned before I was planning to use 2mm OD tension spring for the winch in place pulley tension solution but once I got the 3mm ID 4mm OD PTFE tubing to go over the spring, I saw that the 4mm was just WAY too big once you multiply that out to 300 motors. 300 of 4mm OD tubing starts to take up a massive area at that point and I struggled with that. I MUST be miserly on space taken up by parts to get all the crap I need to fit in there to fit in there! Anyways, I fortunately discovered that you can buy tension spring down to 1mm in OD! I was unaware of this before now! You can find it if you search "0.2x1.5x1000mm tension spring" where 0.2mm is wire thickness, 1.5mm is OD, 1000mm is length.  So I ordered 1mm OD tension spring and 1.5mm OD tension spring to test and see what seems best. If the 1mm OD spring seems reliable to me, I'll go with it. Anyways, since the spring is now smaller, I can use also a smaller PTFE tubing to house the spring so I ordered uxcell PTFE Tubing 1.8mm ID x 2.2mm OD off amazon. 2.2mm OD tubing compared to 4mm tubing is SHOCKINGLY smaller when you look at them. So it will be WAY more space efficient now.
Here's my updated tension spring concept drawing:
« Reply #102 on: May 22, 2025, 03:27:02 PM »
Ok so I currently have an order for 0.2x1x1000mm tension springs stuck in customs for weeks and placed another order just today for the same in hopes it goes through faster. But at $9 for a single spring that is 3ft long, I am feeling RIPPED OFF on price. It is bullcrap. All relating to the tariff nonsense. So I decided today to pivot and just roll with the elastic band in place of tension spring. It's a jewelry making elastic band I bought some time ago in a roll. WAY cheaper at $0.03 for 3ft instead of $9 for 3ft. That's 99.7% off! Talk about a discount! The issue I had before when I looked into this option was the tie-off point. I would need a way to tie PE fishing line to the end of the elastic band without the tie point being bulky. Well I figured out a way to do it without any bulk at all! See I want this to fit into my 1.8mm ID PTFE tubing to keep size down. My solution was to just glue the fishing line lengthwise directly to the elastic band. No knot at all. No turns at all. Just literally lay it on top and glue it down flush. I figured about 6mm length of joint would be solid. And I did this on both sides with my PE fishing line. I used 0.08mm 6lb test braided PE fishing line for this. So now I have two fishing line segments coming off the end of it for double the strength of this connection. But I only wanted one piece of fishing line to go the distance to attach to the motor end so I twisted the pair of fishing line segments together and glued the twisted pair with 401 glue then cut one of the two away leaving just one of the pair to go the distance to the winch in place pulley that this is all supposed to tension for me.
I will use this string and elastic band method for now as I wait on springs and stick with this method for at least this first motor actuator setup for now. If the elastic bands don't last, we'll upgrade to the metal springs later on during maintenance or w/e.
Note: the total length of the elastic band I am using for this is 2ft and it stretches to 3ft snugly without too much force. I'm just going by feel and instinct for this measurement. If I were to go 1ft with 1ft of stretch, the stretch is more intense and the pull is harder. But I don't think I need much pull for just tensioning the winch in place pulley and I also think the more tension you place the more wear and tear on the elastic band which will shorten its lifespan. So playing it conservatively with the 2ft length selection for now.
Note: to apply the 401 glue I used an exacto knife handle with a sewing needle in place of the xacto knife blade and the tip of the sewing needle acts as my precision glue applicator.
« Reply #103 on: June 13, 2025, 11:44:49 AM »
Sometimes to get the braided PE fishing line threaded through the fine PTFE tubing can be tricky, so I came up with a neat device to assist in this. I will be making a threading tool based on a needle threader tool I've been using. It's basically a wire folded in half that you shove through a needle eye and then stick your string into its end and then pull it back through the needle eye. In my use case, I'm creating a custom one of these threading tools that will feed through my entire length of tubing till its folded end comes out the other side and I can thread my string through that end and then draw it back, bringing the string through the tubing with it.
I just ordered some 40ga copper and stainless steel wire to use to make this device in question. I'll see which metal is best. Gonna try the copper first I think.
« Reply #104 on: July 19, 2025, 04:11:49 PM »
Minor update: I have now carefully mounted the PTFE tubing that leads to the elastic string tensioner for the winch in place pulley. I mounted it snugly to the side of the PTFE tubing coming off the same winch in place pulley that leads to the Archimedes pulley system. I routed both of these using my CAD for reference in such a way that their routing will not interfere with the next motors that will be installed later. I mounted this PTFE tubing that leads to the elastic string tensioner using ONLY 401 glue which is something I've never tried before now. Usually I first wrap the tubing in adhesive transfer tape and spandex cloth wrap and coat the cloth in 401 glue but skipping that made it able to be more snugly mounted to the other tube by way of only glue. We'll see how that holds up without the other reinforcement the cloth provides etc. Seems to look so far so good though. They are in turn glued to paper soaked with 401 glue and to a little piece of stainless steel wire bent at a 90 and that wire in turn glued to the winch in place pulley mount baseplate which is itself made of paper and 401 glue. So basically everything is becoming 401 glue construction! I have some concerns about how this will hold up in the event of a fall or w/e but perhaps we can create some sort of protective cage around any delicate outcroppings like this in the future. For now I am just going for ease of construction and speed of construction to get things back on track and rolling again.
Note: The PTFE tubing that leads to the elastic string tensioner for the winch in place pulley is 0.66mm ID 1.16mm OD PTFE teflon tubing. The string coming off the winch in place pulley feeding into this tubing that will act as tensioner string tension carrier string is 6lb test 0.08mm PE braided fishing line. I was able to thread this fishing line into this TPFE tubing by hand with no issues at all very easily.
The next task will be to mount the end of this string to the 2 feet of elastic string for jewelry making and thread that into 1.8mm ID 2.2mm OD PTFE tubing and tie it off at the end of that tubing and then mount that tubing to the gray string hanging from my ceiling for now. That will conclude the tensioner mechanism for the winch in place pulley and this will usher in the next round of manual hand testing to see how much tension that is giving us. I also will be moving the tension spring mounted on the motor to align it better and shorten it more since it only moves like 4mm and so can be way shorter than it is now.
« Reply #105 on: July 21, 2025, 02:56:01 PM »
I finally finished making the tensioner mechanism for the winch in place pulley and I taped it off up the string descending from the ceiling and taped the far end of it onto the ceiling. I noticed I have to keep it as straight as possible since when curling with too much turning the elastic bracelet cord grips the sides of the PTFE tubing which could interfere with the amount of tension it brings to my winch in place pulley. So this will mean on the robot itself it will have to go from the shoulder all the way down the torso in a straight line and then down the leg to about the knee as well. It's 44" long in total. I ended up bumping up the elastic bracelet cord to 30" long to reduce the amount of tension it puts on the winch in place pulley more. The longer it is the less tension it brings and the shorter it is the more tension it brings. If it really can't fit into the leg I can cut the elastic bracelet cord in half and place braided PE fishing line in between the two halves and have that make a 180 degree turn around a pulley and thereby have the same length of elastic bracelet cord but separated into two halves mounted parallel to eachother that create a in series matching tension but taking up half the overall length. This way I could keep it out of the leg area if needed. However I think it might fit into the leg area fine perhaps. Not sure (once we get all the other motors and their tension strings that amount of 2.2mm OD PTFE tubing will start to add up.
Note: I'm also considering taking the elastic bracelet cord out of the tubing and lubing it then putting it back in since lube on the grippy elastic bracelet cord would take away it gripping the sides of the PTFE tubing some I think. Silicone lube is best for this according to chat gpt.
Note: to secure the far end of the elastic bracelet cord I used 401 glue to glue on PE fishing line onto its end the same way as we discussed before and then took the far end of this PE fishing line and came out the end of the PTFE tube with it and taped it off onto the outside of the tube. We'll see how that holds up it might need to be glued down if it gradually is pulled through the tape over time which would be no good.
« Reply #106 on: August 01, 2025, 06:52:11 AM »
The tension spring mounted to the motor setup upon further testing seems like a somewhat bad method. The issue I'm having is too much play in the tubing running between that spring and the finger joint. When tension is applied to that spring by way of the tubing, the tubing recoils and moves quite alot and allows alot of slack out to the joint so that the spring has very little involvement in the joint and doesn't really get used much period. So the full range of motion of the joint is just absorbed by tubing slack. When I tried to pretension the tubing so that the joint movement translates to the spring, the total tension placed on the joint by this became too high.
Fortunately, I came up with a much more elegant and simple solution for all of this. Basically, my plan now is to just use the bracelet cord tied point to point across the joint directly on the joint and that will be my spring for extension that counters the motor. This eliminates the need for metal springs at all which cuts costs, it also eliminates the PTFE tubing run, saving some space, and should be easier to install and easier to give precise amount of elasticity/resistance to taste. If I want more springback on the joint I can just add more bracelet cord in parallel to the first. This way I can add more resistance pretty easily.
« Reply #107 on: August 02, 2025, 04:03:44 AM »
So in recent testing a fresh issue I ran into was the TPFE tubing would start gradually pulling through its tightly wrapped tape sleeve to my surprise. Its low friction surface gradually pulls free of the tape over time. To resolve this, I decided to thread through the tip of the tubing to create a mechanical bond for the tip and once threaded through I just 401 glued down the ends of each thread onto the sleeve that was originally supposed to hold it in place to begin with. This seems to work great so far in the little bit of testing I've done since.
« Reply #108 on: August 20, 2025, 01:19:14 AM »
I figured out a robust way to make the extension cord for finger extension using the bracelet cord and a fishing crimp sleeve. The idea is to crimp the two ends of a folded in half strip of bracelet cord and this way both ends can be sewn down into the fabric without any gluing which could potentially fail or be a weak point. I am planning to use this in place of the tension spring style finger extension setup.
« Reply #109 on: August 27, 2025, 03:49:02 PM »
Ok I figured out a bit easier way: tie a knot at each end of the strip of bracelet cord and then tie my nylon thread off onto the bracelet cord inside that bracelet cord knot. The bracelet cord knot on each end acts as an endstop. Seems to work great so far and cuts down on materials this way over the previous way I proposed.
« Reply #110 on: September 03, 2025, 03:05:08 PM »
Okay so the bracelet cord self untied quickly so I'm going back to my previous approach of tying off both ends of the bracelet cord with a fishing crimp sleeve.
While trying to cut in half fishing crimp sleeves with my mini miter saw I noticed it was a difficult process and not ideal. So I came up with a easier method which was way faster, cleaner, less setup and takedown, no deburring needed, etc!
The method is to lay the fishing crimp sleeve on a flat surface and line up a exacto knife blade perpendicular to it across its top and then apply moderate downward pressure to score the metal and then slide the knife carefully back and forth creating a perfect scoring line that grows deeper with each pass. After several passes the fishing crimp sleeve halves separate cleanly! This method uses a similar principle to a copper pipe cutter used in plumbing.
« Reply #111 on: September 06, 2025, 12:10:35 PM »
I installed two tensioners for the robot and they were seriously successful overall in testing. So much so that I am now confident enough in the entire pulley system to move onto the custom mini BLDC motor controller to get the motor to run motorized tests of finger movements next. Well after a couple very minor tweaks that is.
So the first tensioner I installed on the extension part of the index finger joint we are working on. I used the bracelet cord folded in half and fishing crimp sleeved then sewn into the bone fabric. It seems just about perfect except for one thing: I want to keep it under mild constant tension but the bone fabric creeps/moves slowly when put under constant tension like this because it is taped into place on the bone after all. The tape is allowing the movement. This means it does not stay put and my anchor points move over time so I can't set a tension and rely on it staying at that tension long term. To resolve this I need a mechanical connection at the tension point anchoring location.
To mechanically connect my anchor point, I have decided to use tiny self tapping screws. I have avoided screwing into the bones till now but I'm making an exception here. The screws won't be going that deep and the finger bones are unlikely to break anyways IMO. So I feel comfortable with this. Here's the screws I ordered for this from Amazon:
Next, I created a tensioner for the middlemost archimedes pulley. That pulley was creating significant drag and slowing down the finger extension during testing due to rope friction. So adding a tensioner line to pull it back down toward the fingers during extension was my solution for this. It worked amazingly well. To make this, first I tied off a fishing hook eye to the bottom of the radius bone just above where my TPFE guide tubing entrance is. Then I glued a 7cm piece of bracelet cord to a piece of 6lb test .08mm braided pe fishing line with 401 glue. I secured the top of the bracelet cord to the top of the archimedes pulley system and then threaded the other end through the fishing hook eye and back up and to the bottom of the archimedes pulley where I tied it off. So it ties off at top, comes down to bottom, goes through the fishing eye then comes back up and connects to my pulley. It creates just enough downward pull to delete the rope drag slowing down that pulley from coming down and this enables the system to unwind and extend back to its starting point after each time I contracts/pulls upward to cause finger contraction. This means the finger extension now happens swiftly with no hangups and the whole archimedes pulley system is now under constant tension at all times which keeps things neat and prevents tangling issues pre-emptively. This rig was a massive success and took up hardly ANY space at all.  I put the post it notes behind the archimedes pulley tensioner so you can see it. It's hard to see otherwise without a contrasting backdrop. It works amazingly well.
« Reply #112 on: September 10, 2025, 11:27:07 AM »
Back on the electronics again. Have been going over my BLDC motor schematic and making some little tweaks to it. Here's the updated schematic. It's a combination of lots of other schematics I've found online as well as some chatgpt help. With 1 being no clue and 10 being absolute expert tier in BLDC motor schematics I'm probably a 5 IMO. So take my design with a grain of salt. It will be very fun to see if it works. Note that I put a couple schematics of Electronoobs - a great youtuber on the left hand side as reference and study material. My schematic is the big one on the right. Electronoobs series of videos on BLDC motor controllers has been extremely helpful in me forming a rudimentary understanding of this stuff.
« Reply #113 on: September 19, 2025, 12:10:00 PM »
I started some testing on some subsections of the BLDC motor controller and ran into some problems and learned several things. I'm working with chatgpt to resolve each issue and have been updating my schematic to reflect alot of the changes I am making. One thing I learned is that for the high side switch, the voltage from gate to source has to be 10-12v higher than the drain voltage because the drain voltage becomes the same as the source voltage once the switch is on. The voltage from gate to source then either has to start out as motor input voltage + 12 while still fitting within the voltage from gate to source max allowed voltage as stated by the datasheet or it has to rise dynamically as the source voltage rises such that the voltage from gate to source is 12 more than the source voltage as the source voltage rises to become the drain voltage. Fortunately, I can have the former for this 2430 motor since I can use 6-8.4v to supply the motor and the voltage from gate to source max value is 20v. This means I can use voltage from gate to source of 20v and this, when mosfet is first switched on, does not fry mosfet but as the source rises to become 8.4v, 20v-8.4v is still 11.6v which is sufficiently high to enable the mosfet to still stay on without anything dynamic set up. If I want to go with a 12v motor supply on some of the bigger motors later on, I will need a bootstrap circuit to supply the highside mosfet with a dynamic voltage from gate to source that rises when source voltage rises. So I added that schematic diagram to this as well as an option. I also can use a mosfet driver for this but was hoping to cut that cost and added volume taken up by just using discrete components rather than a IC for this.
Anyways, to break things down even more in testing, I decided to just test turning on and off a single highside mosfet using a pair of lab power supplies, one to provide 20v and one to provide 8.4v. To turn on I connected the gate and source to my 20v lab power supply and I connected my red alligator clip of my 8.4v lab power supply to the drain and then measured from source to the black lead of the 8.4v power supply and verified 8v on that test which worked - proving the mosfet was in fact on. I then removed the black alligator clip of the 20v lab power supply from source and shorted the source to the gate to drain the internal capacitor inside the mosfet and then tested from source to the black 8.4v clip and sure enough it was near 0v so was off. But it did gradually climb back up to 8.4v after the short from gate to source was removed due to capacitive coupling and leakage according to chatgpt. So I will need to add a 10k ohm resistor between gate and source pins to short it automatically and keep it fully drained and off fully when it's supposed to be off.
So I plan to just gradually add components little by little and test after each thing is added to ensure it is working right still after each little change and this way gradually build out the circuit, proving each thing works as we go. This is because things have all these gotchas and "oh you didn't know this little detail?" that keeps coming up and proves it was more complicated than I thought. So I just have to prove every little thing as I go. To try to find out what is wrong after the whole thing is built would be WAY harder than to figure out what went wrong when a single component is added and it was working before said component was added. So that's how I will be able to overcome this challenge best I feel.
Note: Reminder: I am building a custom BLDC motor controller because an off the shelf one would not have enough miniaturization to fit into the tight space constraints I have to work with. Also, building my own gives my software more precise control of every little advancement of the rotating magnetic field and along with that I'll have the ability to PWM the advancements to make them more smooth, less noisy, and have torque control as well this way which means the fingers can be rough and fast in movement as needed or slow and gentle and dainty or slow but powerful etc. I can also create acceleration profiles that match human finger joint acceleration in order to have the movements look very natural just like a human's movements which is very important to me. Just alot of fine precision is possible when its all my own circuit I feel. While off the shelf ones may have some of this functionality, the price often reflects that and is then prohibitive. But in any case nothing is off the shelf with this level of control AND the ability to so finely tune its form factor and volume envelope to fit my exact needs in space on a per motor basis.
« Reply #114 on: October 21, 2025, 09:26:31 AM »
Well I finally got back to the electronics after about a month long detour real life interruption. All kinds of stuff slowed my progress on this session. But I got stuff done nonetheless. 0603 LED to 0805 resistor and some nickel strip leads coming off. Tested and working. This will be the indicator light for when the lowside mosfet comes on for one section of the custom BLDC motor controller. 0603 LEDs are extremely tiny for hand soldering and they don't take solder well either. I was originally going to go with blue LEDs but chatgpt said that would give off a unrealistic color through the silicone skin so orange would be better to give a more natural and less silicone skin piercing indicator light. Somehow I ran out of 470ohm resistors so I had to order more and I used my 200ohm ones instead for now. Which are a bit too bright. But chatgpt said I can diffuse the LED with a glob of silicone tinted black to darken and diffuse the light it gives off which sounds like a good idea to me. I am planning to use wire wrapping wire to come off of this assembly and tie into things. Somehow just attaching these two parts and testing it took me almost 3 hours. Between studying the schematic to refresh my memory on what is going on, visualizing placement options, overheating and destroying one LED, trying to locate the right color LEDs, shopping for replacement 470ohm resistors, researching and substituting in 200ohm resistors, discussing LED color options with chatgpt, figuring out how to solder a 0603 LED directly to a 0805 resistor part to part by hand, accidentally breaking a part off of its nickel strip lead and having to redo the connection, etc etc. All of it just crawls. Hard to stay patient with electronics sometimes and I do things in inefficient ways often. Learning what can and aught not to be done is tough from a patience perspective. But I insist on trial and error and experimentation which takes time. I just need to get into a daily habit to stick with it till completion. It's all complicated. Trying to figure out how to electronically isolate it all next. Thinking of using lamination plastic taped around it all so I can still see it all and visually troubleshoot. Also I'm considering how I can use solder wick braid as a heat pipe for each mosfet and run that over to the liquid cooling system. But it can't conduct. So thermally it can conduct but electrically it can't. Trying to figure out whether to create a barrier of micah or just thermal silicone for this and the routing needed. Also considering if I need mini coaxial shielded cable for the wiring of each or just regular wire wrapping wire when going from microcontroller to mosfets etc. Also trying to figure out if I need hall effect sensors or back emf reading or no feedback but my potentiometer and the implications of each option. Just so much to consider in all of this. And all of those considerations also slow things down even more as I have to make decisions on it all. It's quite overwhelming.
« Reply #115 on: November 02, 2025, 01:08:52 PM »
Ok so I decided to use 30 gauge wire wrapping wire and wire wrap that onto my nickel strips that I connected onto my LED setup then trim off any excess nickel strip. What I like about this is this wire is very fine so it takes up hardly any space and by being able to wrap it on I did not have to apply heat which could have desoldered my smd components by accident. I also like that it is already insulated and color coded so I don't have to worry about insulating my nickel strips the whole run to wherever this connects. To insulate the whole LED contraption here I used packing tape so I can see all my components well but still have them electrically isolated. I just folded the packing tape over the whole assembly like closing a book over a bookmark.
note: after wire wrapping the wire wrapping wire I noticed it was not that tight on there. I did not use a wire wrapping tool because I lost mine so I just used needle nose tweezers to manually wrap it around and around. Anyways to tighten it well I just crimped it with the tip of my wire strippers that has some kind of toothed pliers that crimps things well. After doing that the connection appears very solid.
« Reply #116 on: November 07, 2025, 06:58:19 PM »
Couple updates:
An audience member redid my brushless DC motor schematic in the traditional commonplace formatting which for most is easier/quicker to read and understand due to familiarity. So I'm reposting it. It looks mostly accurate although I have since added a 100nF ceramic capacitor between the gate and source of the highside mosfets to reduce ringing issues. Standard practice according to chatgpt. I also changed the LED color to orange because chatgpt said blue would show through the silicone skin more and add a cold inner glow and we want it to look like real skin so no blue.
As to why the highside mosfets get a 100nF ceramic gate capacitor but not the lowside, here was how chatgpt explained it to me:
-High-side MOSFETs:
Their source pin moves up and down with the motor phase (it?s not at a fixed potential).
During switching, the drain and source both move rapidly, and the gate voltage must track that movement precisely ? any ringing or inductive noise can momentarily over-stress Vgs.
That?s why we add the small capacitor across gate and source: it tames that high-frequency ringing and helps hold the gate steady relative to its moving source.
- Low-side MOSFETs:
Their source is solidly tied to ground, so the gate always swings relative to a fixed, quiet reference.
They don?t experience the same ?floating? gate drive or large dv/dt transitions on the source pin.
So, the gate is inherently more stable, and you don?t need that extra 100 nF G?S capacitor.
Anyways, here is the audience member schematic:
Here is my updated schematic with the changes I mentioned:
In further news, I tediously installed the new 100nF ceramic capacitor between gate and source of the mosfet. Due to the close proximity to the 10k ohm Vgs resistor and various other low temp solder joints in the immediate vicinity, any heat applied would surely have caused those to desolder and the whole thing to start falling apart so I ended up just soldering nickel strips to either side of the 100nF ceramic capacitor (by itself off to the side) and then used the tip of a sewing needle to apply a tiny amount of conductive silver glue onto the gate and source nickel strips coming off the IRLR7843PBF mosfet and then pressed the nickel strips of the ceramic capacitor into that. I put that in front of a mercury vapor bulb for an hour or so to cure and then applied another generous helping of conductive silver glue over the top of the joint. I then baked that another 7 hours under the mercury vapor bulb again. This photo shows the final result.
It appears to be a solid joint and I think this is a great way to make attachments when you can't use soldering! It might even be better than soldering in some cases from a ease of application perspective but not sure yet on that.
« Reply #117 on: November 11, 2025, 01:30:34 PM »
Okay so here I have attached the LED and resistor pair with their 30ga wire wrapping wire onto my highside mosfet's front face. I may add conductive silver paste to the wire wraps in the future if any issues come up there. However, I am wondering if just tightly wrapping it in electrical tape would more or less guarantee the connection doesn't open circuit. We'll see.
I also finished soldering together six braided copper solder wick strands which will act as my heatsink for my highside mosfet. I am still deliberating on how to attach it to back of mosfet in such a way that it will be electrically isolated but thermally conductive. I am leaning toward thermal tape for this.
« Reply #118 on: December 03, 2025, 02:23:24 AM »
I just tested the positive high-side switch portion of the motor controller and everything seems to be working as intended. The section including all parts involved is circled in a bold blue line to indicate the portion I just tested successfully.
One issue I'm having though is that the drain of the A09T attaches to the 100ohm resistor tightly and is a weak point that broke off twice now. Hardly any wiggling at all on the arduino input line and ground line leading into the A09T mosfet causes the drain solder attachment to break off. I am wanting to glue it all down onto the mosfet but I'm supposed to tape the heatsink on under all this stuff so I don't think I should glue it down. I need some kind of backing sheet to glue things off onto (where a PCB normally does this job). Which will provide much needed strain relief at all attachment points. I guess I'm learning the hard way why PCBs are used in general. Without a flat backing plate or substrate of some sort the attachment points between components are vulnerable to flex and breakage super easily. This surprises me.
To perform the test I used one lab power supply set to 20v and one set to 8.07v and used a 18650 lithium battery as the 4.12v to simulate the arduino output pins. I carefully electrically isolated all the metal lines with packing tape for now to ensure no short circuits and then I connected the lab power supply pins to the correct locations with alligator clips. Finally I connected the 18650 lithium battery 4.12v to simulate the arduino turning on the A09T mosfet - I did this using the two nickel strips for this portion joined to the battery with neodymium magnets. If I had a 3rd power supply I could get 5v off of I'd have done that but I didn't have one in arms reach so the battery it was. The LED came on and I tested the output line to the motor was indeed 8.07v. I then disconnected the + side of the battery and verified the line going to the motor was 0V. It was - although if I kept the multimeter on that line longer I noticed it would creep up to like 3.4v but something similar happened on my last test run and chatgpt said this was like parasitic capacitance involving the multimeter or something and nothing to worry about. The main thing is it would START at 0v when I first connected and then rise up to 3v or w/e over time on the multimeter screen and this behavior was ok last time so meh. We're good I think.
Where to go from here then? Well I'd say I make the other (lowside) portion of the half bridge and then test the full half bridge to ensure it's all working. I think then my design is validated enough to move into diy flex pcb for some of these portions that are on the layer that goes onto the main beefy mosfets.
« Reply #119 on: December 05, 2025, 11:01:24 PM »
So armed with my successful electronic test of my prototype highside switch with driving circuit all passing, I determined now it is sufficiently validated to go through the process of converting it into a printable schematic and doing the whole DIY flat flex PCB making and acid etching process to streamline the development of the rest of the motor controller and most likely many more motor controllers as well.
I opted to use photoshop as my circuit making software of choice as I'm very familiar with it and use it often. I first dropped my top view photo of my prototype circuit into photoshop then I redid its layout a bit to make it more compact, moving around copied pieces on the photo to achieve this. Next, I used the pencil tool to color in blue pads and traces connecting all the pieces of it together. I then hid all but this pads and traces layer and printed it several times, tweaking the printing scale until it fit the size of the pieces IRL. 7.5% scale was the perfect fit.
Next, I will need to refresh my knowledge of the transfer paper print and transfer of the ink off of this paper onto the copper clad blank flat flex PCB and then acid etching away all unwanted copper and then removing the ink to reveal the fresh copper traces and pads. Then I can solder all the SMD components onto this. Heck I may even make a solder paste stencil and place components and bake them on. But perhaps just hand solder for now? Not sure. The former is faster in the long run but takes more setup and is quite committing. I'd rather validate my designs even further before going that far.
