Author Topic: Can I connect jumper leads to solder onto a simple dc motor?  (Read 15168 times)
Offline w31ha0Topic starter
I'm new to robotics and am wondering if I can solder a jumper lead onto a DC motor with the other end connected to the raspberry pi. The jumper lead I'm thinking of is this:
http://www.kiatronics.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/7/0/70658.jpg
The left side will be connected to the raspi GPIO and the right side will be soldered to the DC motor. I've tried doing that but it doesn't seem to work.
If this is not possible,what kind of wires should I use to connect the motor directly to the raspi GPIO outputs?
Offline Plague
Re: Can I connect jumper leads to solder onto a simple dc motor?
« Reply #1 on: July 29, 2015, 11:47:10 PM »
If I understand your question you want to solder the jumper wire to the DC motor but the solder won't work?
If that the case,  you can  strip the tip of the jumper wire,  removing the pin and exposing the wire inside.  That way the solder can attach to the wire and the motor. Your jumper wire won't be jumping any more  ;D
Offline cyberjeff
  • Helpful? 7
« Reply #2 on: July 30, 2015, 03:21:42 AM »
STOP
It's not clear what you are doing.
A servo has 3 wires, a power wire, a ground wire, and a signal wire. The signal wire carries a minute amount of  current and is typically hooked up to a GPIO pin configured as PWM. The ground and power carry the full load which may be an amp or so.
The GPIO of a Pi has a 16 mA  (.016A) max rating,  that is sufficient for lighting LEDS (a few) and signal wires to servos. It will not directly power motors.
If you have a servo, the wire shown is fine for connecting to the signal connection of the servo.
A DC motor has 2 connections and will probably draw several hundred mA. Hooking up a DC motor directly is a recipe for baked Pi. Don't even consider that!
Offline cyberjeff
  • Helpful? 7
« Reply #3 on: July 30, 2015, 08:18:09 AM »
Shields are usually used to connect motors. You may also see that as a motor controller. Google that.
If  this is all new to you, you may wish to start with an Arduino as there are many off the shelf plug in boards that require no soldering.
The point I wish to make is that neither the Pi or any of the microcontrollers like an Arduino has enough current to drive a motor directly. It will need an interface to protect it and to supply enough current.
« Last Edit: July 30, 2015, 08:27:12 AM by cyberjeff »
