Author Topic: PWM switch - RC based autonomous boat  (Read 13103 times)
Offline JendkerTopic starter
« on: October 11, 2015, 09:40:25 AM »
I am building an autonomous boat. As a master steering system I wanted to use RC's radio, as a secondary I wanted to use Raspberry Pi. To choose the steering source I wanted to use one of the channels from the radio receiver - 1 would mean radio as a source, 0 - Raspberry Pi. To choose which system is in use I need electronic element to choose which PWM signal is forwarded. Is there already built electronic part to do such thing? I was thinking about preparing something by myself, with 2 AND gates and one XOR (as presented on the diagram below). The question is, if I indeed have to build it myself, will the gates be the good choice? I don't know if the PWM can be forwarded through a gate because of its high speed of changes (of the frequency)? I assume that it is relevant. Maybe there is a different, better solution?
I will be grateful for your help!
Offline cyberjeff
  • Helpful? 7
Re: PWM switch - RC based autonomous boat
« Reply #1 on: October 11, 2015, 06:27:38 PM »
I didn't read the logic, which I assume it is right, but I don't see why this wouldn't work. I haven't used the outputs on the Pi, but I assume they are totem pole, and don't need a pull up resistor.
The servo pulse width is around 1.5 msec, a garden variety cmos 4011 is 60 nano seconds, so plenty  fast enough. If you just have a handful of servos this seems like a good way to go.
