Author Topic: Appropriate Components???  (Read 12243 times)
Offline Kate91Topic starter
« on: November 07, 2016, 10:41:22 PM »
I am designing a prototype product and would like to use a series of components from Little Bird Electronics in the production. (https://littlebirdelectronics.com.au)
I would need it to, once a button it tapped, initiate wheels to roll until the light sensor sensors light. Then I would need a programmer connected to the light sensor and wheels to stop the wheel movement & start a robotic motor to raise 2.5 - 4kgs, to an 80° angle.
For the same action to happen in the opposite series of events (lower the object and roll back until light sensor, on opposite side of original, can no longer sense light) would I need a different set of programming (i.e. different motors and programmers)?
I use thinking of using the “Tiny AVR Programmer” in congjunction with an "Analog Ambient Light Sensor TEMT6000" as well as the "12V Low Low noise DC Motor” is this the right set of components to be using?
Tiny AVR Programmer
https://littlebirdelectronics.com.au/collections/programmers/products/tiny-avr-programmer
https://littlebirdelectronics.com.au/products/analog-ambient-light-sensor-temt6000
12V Low Low noise DC Motor 146RPM w/Encoder https://littlebirdelectronics.com.au/collections/robotics/products/12v-low-noise-dc-motor-146rpm-w-encoder
