Author Topic: Do you think this robot movement is useful?  (Read 35624 times)
Offline naffoffTopic starter
« on: November 02, 2021, 12:31:22 AM »
I am a self taught robotics enthusiast I have been building an all wheel drive robot using torque vectoring. It steers like a swerve drive but without the complicated drive-train. I am wondering if you know situations where the robot movement is useful?
Looking forward to all your replies!
https://youtu.be/iPlnzkzqwRQ
Offline mklrobo
Re: Do you think this robot movement is useful?
« Reply #1 on: November 04, 2021, 12:18:48 PM »
 8)  excelsior!   8)
  I love this robot!!!!   ;D
   It looks like all the drive wheels can be moved independently, thus, making
turns on corners in cramped spaces a breeze.
   It first glance, I would think that a type of movement model could be articulated
to give a prediction of how effective this would be in a cramped environment.(like someone's house)
     I am wonder is 2 chassis could be used; one for traveling, and one for close quarters turning, a
chassis within a chassis?
« Reply #2 on: November 09, 2021, 02:17:50 AM »
Hi!
I am so sorry for not replying sooner!
Yes it can move in quite flexible way,  what I am experimenting with that I have not seem tried before, is using casters but without powering the pivot point, so you have to use the speed of each wheel to move the car to change direction of the wheels.
Offline gisicak
« Reply #3 on: July 12, 2022, 08:51:28 AM »
Hello, I have started a full-scale humanoid robot project. Check out the progress, I am currently finishing a leg to begin working on the sensors and electronics. I will be using brushless DC motors, MPU6050, and ultrasonic sonar sensors.
Check out my projects
https://questcraft.net/
Offline gisicak
« Reply #4 on: July 12, 2022, 08:55:40 AM »
;D Hello!
Awesome work! I have tried also to use the wire wrap direction, and found that the wires acted like
antennas, with the bus speeds. This put out a lot of noise and loaded down my CPU with a fanout rate.
I did not do as good job as you have but only present this as a possibility. Good Luck!!  ;) :) :D ;D
Download Kiddions Mod Menu
