Author Topic: the living grimoire  (Read 37210 times)
Offline beefTopic starter
the living grimoire
« on: March 23, 2022, 12:09:23 AM »
https://jizz.is/threads/the-living-grimoire.95/
https://github.com/yotamarker/public-livinGrimoire
this is a software design pattern, which enables adding a skill(ability) to an AGI using 1 line of code
more info can be found here :
https://www.yotamarker.com/f2-the-livingrimoire
the vast majority of people are unable to grasp the concept of "1 line of code to add a skill"
but it is the same concept as seen in this matrix movie scene :
https://www.youtube.com/watch?v=w_8NsPQBdV0
so if you have any questions please be specific, meaning : do not ask in the form of "I don't get it"
Offline mklrobo
Re: the living grimoire
« Reply #1 on: March 23, 2022, 02:27:50 PM »
 ;D  Hello!   ;D
     I liked the website, battle programming.
     The one line of code to add a skill statement, incurs more context with
the information than on the surface of the assertation.
     Headers, libraries, and support files all go into, "just one line of code".
If you are using FORTH, that is understandable.
I could not access your Github address, so I would ask you to explain your vernacular;
"this is a software design pattern, which enables adding a skill(ability) to an AGI using 1 line of code".
 I can only add my own bit of wisdom when it comes to pattern matching;
 - " if there is a pattern, then there is a sequence}{ if there is a sequence, then there is a formula }
      if there is a formula, then there is a family of formulas; if there is a family of formulas, then
      there is a solution for every variable in the statement."
    Please explain, I wish to understand.   ;)
 see you next post,   8)  same robot time, same robot channel!   8)
« Reply #2 on: March 24, 2022, 10:45:58 AM »
« Reply #3 on: March 24, 2022, 10:56:03 AM »
https://we.tl/t-DuCDUuSxGI
^ pdf with elaboration
