Author Topic: need suggestions for a medium-sized geared dc motor category  (Read 32686 times)
Offline mchahnTopic starter
I've finished a 2-wheeled rc robot that uses two N20 motors.  I'm now starting a project for a bigger 2-wheeled robot.  I have been going crazy trying to find a geared dc motor bigger than the N20 (~20mm long by ~10mm radius) but smaller than the zillion 60mm long planetary motors I've found.  Ideally it would be the following ...
30mm to 40mm long
15mm to 20mm diameter
5v to 12v
250 to 500 rpm
I don't need an exact model.  Just pointing me to some category of motors anywhere near these specs would be greatly appreciated.  Thanks in advance...
Offline mklrobo
Re: need suggestions for a medium-sized geared dc motor category
« Reply #1 on: August 03, 2022, 07:06:21 AM »
 8) Excelsior!   8)
     In reference to your motor problem, it might be best to see if you can find a nice motor
and put the gear down assembly yourself. While this may seem tedious, you will know how
every part of the motor works. If you get easily acquired motors, with a gear pack you can
use, that will go above and beyond what everybody else has. Good luck!
 ;D  See you next time, same robot channel,  8) same robot time!  8)
