Author Topic: How do I use 10" 3D printed leg sections to make 24" legs?  (Read 14740 times)
Offline fester225Topic starter
« on: April 29, 2025, 09:19:45 PM »
I have a 3D printer capable of printing 10" parts. I'm working on a design for a two-legged robot that will need leg sections around 24" long.
How do I attach 3D printed sections to each other in a way which will allow a total leg 24" long and give as much strength as the original sections?
"There is only one basic human right, the right to do as you damn well please. And with it comes the only basic human duty, the duty to take the consequences." -- PJ O'Rourke
Offline artbyrobot1
    • www.artbyrobot.com
Re: How do I use 10" 3D printed leg sections to make 24" legs?
« Reply #1 on: May 03, 2025, 08:01:32 PM »
I'd say print with a tube series of holes on both parts and then insert steel tubing (dowel pins or w/e) down the holes on both parts running at least 6" of overlap into both parts so that the insides are steel reinforced as the joint seam.  Then just glue them together as usual.
