Author Topic: Computer Interfaced Electronics  (Read 5438 times)
Offline iLL_LeaTTopic starter
« on: November 04, 2007, 02:09:22 PM »
Hello!!!
I have a question about controlling electronics with computers.  I'm a computer science student with a personal interest in electronics.  Though I have not had time to put anything together yet, I am semi-educated on on the subject.
I'm hoping, when I have time, to make some computer interfaced electronic.  However, none of my laptops have serial ports and I don't have a desktop.  Moreover, I have noticed that newer Linux distributions don't support USB to serial converters because serial controlled devices are becoming obsolete.
So, If can't use the serial port, what should I use? Is there any way to use the USB port directly with out getting my masters in electrical engineering?  What do you use?
Thanks,
iLL
« Last Edit: November 04, 2007, 02:11:38 PM by iLL_LeaT »
Offline frank26080115
Re: Computer Interfaced Electronics
« Reply #1 on: November 04, 2007, 02:19:25 PM »
What? I'm running the latest Ubuntu release and my FTDI chip is working fine.
Try uninstalling the brltty package if it is installed, if it is running you'll never have any working serial port.
« Reply #2 on: November 04, 2007, 02:29:21 PM »
I had never heard of FTDI
I see that they actually have Linux drivers  :o :o :o :D
Thanks....
Offline dunk
    • dunk's robot
« Reply #3 on: November 04, 2007, 05:53:30 PM »
every USB to serial converter i have ever used has worked under linux without the need for any configuration.
as for serial controlled devices are becoming obsolete, i deal daily with networking equipment that needs to be initially configured by serial port.
RS232 is far from obsolete but i will admit it's uses are changing.
« Reply #4 on: November 04, 2007, 08:52:18 PM »
ummm
Phidgets is the easiest and then comes just using the USB to serial ..
Phidgets:
http://www.phidgets.com/products.php?product_id=1018
Offline Kohanbash
« Reply #5 on: November 04, 2007, 09:46:50 PM »
airman have you used that with linux?
« Reply #6 on: November 05, 2007, 01:20:00 PM »
ummm
Phidgets:
I was just taking a look at the manual for that.  It looks very cool.  I might have to pick one of those up!!!
thanks airman00
« Reply #7 on: November 05, 2007, 05:01:59 PM »
no not with linux,
but it should work.
I use visual basic to control it but I am sure that you can use a linux based software. Worst comes you'll use a windows emulator.
PM me if you need any specific help with the Phidgets
Offline Half Shell
« Reply #8 on: November 05, 2007, 10:53:25 PM »
I highly recommend Arduino with a protoshield. http://www.arduino.cc and http://www.adafruit.com to buy it. It is very low cost, USB compatilble, works well with Linux and is incredibly easy to program and get up and running with your electronics projects. It even has Boarduino as a way to better interface with solderless breadboards.
Offline Spoil9
« Reply #9 on: November 10, 2007, 08:58:52 PM »
Ok, so here is my noob question.
If I have an old laptop that is really good for nothing, can I use that as a microprocessor for my projects or is it to much to convert?
- Bill
Knowledge is Power. Power Corrupts. Study Hard. Be Evil.
« Reply #10 on: November 10, 2007, 09:05:21 PM »
The laptop would be overkill for a small robotics project.
I used a laptop  because I needed vista speech recognition , webcam , and otherstuff.
also you wouldn't be able to program the MCU inside the laptop, and it has a lot of leads.
Go with a MCU like AVR, PIC , or STAMP.
I prefer PIC for quick projects, and AVR for medium.
 ( PIC because I sue PICBASIC)
So, no you cannot use the laptop MCU
(by the way, the laptop is not good for nothing, you can use the laptop to program the PIC or AVR)
Offline IceMetal
« Reply #11 on: November 23, 2007, 11:17:24 PM »
Hello!!!
Thanks,
iLL
The cheapes and best way to control things with your computer is the parallel port  I created a page for it
http://geocities.com/scancool/parallel.html
but if you dont have a parallel port go for usb I got a kit and put it together for like $10 all you need is the component
http://www.delcom-eng.com/productdetails.asp?productnum=802300
« Last Edit: November 23, 2007, 11:18:44 PM by IceMetal »
