Author Topic: first robot help  (Read 5626 times)
Offline cooldogTopic starter
first robot help
« on: November 07, 2007, 06:15:02 PM »
help!!
i got this sweet tank from a secondhand store and when i opened it up i got scared! it had some sweet gears. anyway it didn't come with a remote so i was wondering i've been reading up on topics and came accross one that looks like what i would like to do. it is called RC tank by polar bear6 he talks about useing servo circuit bords to run motors. it has 3 motors in it but i only need to have two move. the motors run off of a costom 9.6 NiCd recargable battery. so what i am asking is if the servo circut bords work with these motors
« Last Edit: November 07, 2007, 06:49:12 PM by cooldog »
-admin
favorite web sites
http://www.instructables.com/
Re: first robot help
« Reply #1 on: November 07, 2007, 06:45:34 PM »
hi i am looking to hook up indifferential drive to my r/c tank chasi it came with two 9.6 volt motors. so i was wondering what speed conrollers are best for this.
P.S. i'm on a buget
-admin
favorite web sites
Offline Steve Joblin
    • Roebotz
« Reply #3 on: November 08, 2007, 07:48:56 AM »
Probably not. The servo circuit boards don't go above ~6 or 7V. Depends on what voltage you want to run your motors at. Why not just use the motor driver in your tank?
...to hook up indifferential drive to my...
I think you meant so say differential drive.
'indifferential drive' means your robot doesn't care where it goes :P
« Reply #4 on: November 08, 2007, 09:30:33 AM »
ya what motor controler do you recommend
-admin
favorite web sites
« Reply #5 on: November 08, 2007, 09:32:21 AM »
do i need to program a microcontroller????????
-admin
favorite web sites
« Reply #6 on: November 08, 2007, 10:34:44 AM »
eeehhhhh we would need more info on your motors and what you plan to do with them to answer those questions . . .
« Reply #7 on: November 08, 2007, 11:07:28 AM »
they r 9.6 volt and they came with my tank. and i plan to use them one the same tank!!!!!!!!!!!!!1
-admin
favorite web sites
« Reply #8 on: November 08, 2007, 11:10:35 AM »
Then just use the same motor controllers, too.
So if you want to make it a robot, yes, you need a microcontroller to control the motor controllers.
Offline ed1380
« Reply #9 on: November 08, 2007, 01:50:32 PM »
just get a receiver and transmitter designed for land use, and a couple ESC (electronic speed controllers)
« Reply #10 on: November 10, 2007, 08:52:51 PM »
i got this sweet r/c from goodwill. i took out the reciver ( it didn't have a contoler ) and i hooked it up dirrectly so it just goes straight. i tried hooking up 2 photocells one for each side but it wouldn't respond. i know the motors are good because i had them running but i can't figure out what is wrong.
P.S. i don't want to use a microcontroller!
-admin
favorite web sites
« Reply #11 on: November 10, 2007, 09:01:28 PM »
use a microcontroller - if you want to get into robotics that is the way to go.
or you can use something called a comparator. search the forum and google for info about them.
P.S. Microcontroller will be needed eventually!
« Reply #12 on: November 11, 2007, 06:25:56 AM »
i know i need a microcontroller or a capacritor but i am not going to for this project.
any other ideas
-admin
favorite web sites
« Reply #13 on: November 11, 2007, 07:23:23 AM »
cooldog, try to keep your related posts together . . . you are causing people to repeat saying things to you ;)
