Author Topic: Need Help With $50 Robot  (Read 5470 times)
Offline chyooTopic starter
« on: November 30, 2007, 06:38:34 PM »
Hi, I'm new so please understand my views here, I have build the circuit OK did some test and they turned out fine by when i tried to programme it it gave me a device missing or unknown message, I'm using the 9v and the 6v battrey method
please help me anyone
Offline garriwilson
Re: Need Help With $50 Robot
« Reply #1 on: November 30, 2007, 06:43:28 PM »
Which programmer do you have? If it's the  $34 one, then I could probably help you. More info please.
« Reply #2 on: November 30, 2007, 07:14:16 PM »
No its the same one thats on the tutorial the 10 pin, I really don't know what next to do please help
« Reply #3 on: November 30, 2007, 07:52:46 PM »
scroll down towards the bottom until you see this image, then read that section and the one before
http://www.societyofrobots.com/step_by_step_robot_step4.shtml
If it still doesn't work, check voltages on your programmer pins.
« Reply #4 on: November 30, 2007, 08:00:06 PM »
My computer only has one serial port so what then man, so the is just a communicational problem right? my circuit is good then?
« Reply #5 on: November 30, 2007, 08:22:35 PM »
Not really. USB ports are 'virtual' serial ports, dude. :P
What the error means is that it is not detecting the programmer for one of these reasons:
A) programmer not powered up (check voltages)
B) you are telling it to use the wrong port (check device manager)
C) you have another program running that is using the same port (close other programs)
« Reply #6 on: November 30, 2007, 08:41:35 PM »
OK can i build a serial-to-USB adaptor, the little capacitor that has the #101 can i used  a 103m instead of that on
Offline ed1380
« Reply #7 on: November 30, 2007, 09:12:38 PM »
you could or you could buy one.
parts at sparkfun would be cheaper since a usb-serial cable costs $30 at CC or RS
« Reply #8 on: November 30, 2007, 10:12:23 PM »
??? you must use a programmer to program the ATmega8
If you use a programmer to upload a program called a bootloader, then you can use serial for future programming.
nope
the number is a capacitor rating:
100 = 10pF, 101 = 100pF, 332 = 3300pF, 103 = 10000pF = 0.01uF
« Reply #9 on: December 01, 2007, 09:15:25 AM »
So then I have to use the 101 then.
the programmer thats a canection termal rigth? without this it wont work?
Is there anyother way?
« Reply #10 on: December 01, 2007, 09:27:41 AM »
I don't really understand your question . . .
For a microcontroller to work, it needs a program. To upload the very first program you absolutely must use a programmer, no exceptions. :P
paulstreats
  • Guest
« Reply #11 on: December 01, 2007, 09:34:18 AM »
The programmer isnt just a set of header pins that you soldered onto your board, It is a seperate piece of hardware. There are two different ones in the optional list of parts for the $50 robot. Basically its the part that goes between your computer and the electronics board. Once the electronics board is programmed, you can take it away
