Author Topic: Circuit grounding, what?  (Read 3346 times)
Offline michelleTopic starter
« on: December 06, 2007, 10:31:24 AM »
I'm just starting on the $50 robot (have ordered the parts) and am befuddled by the schematic (and parts of the tutorial).
I'm very new to circuitry and building and don't know  basics of electronics like - what does it mean to ground something? Also, where can I find an index of symbols for an electronic circuit? Can anyone recommend a more "basic" tutorial?
If someone used all of the recommended parts for the $50 robot but swapped out the controller, would this be the only part of the schematic that changes?
Thanks for any help!
« Last Edit: December 06, 2007, 10:37:18 AM by michelle »
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
    • Ro-Bot-X Designs
Re: Circuit grounding, what?
« Reply #1 on: December 06, 2007, 11:05:09 AM »
Take a look at the electronics tutorials http://www.societyofrobots.com/electronics_tutorials.shtml
Depends. You can swap the ATmega8 with ATmega168 with no change. Any other microcontroller wil work only with changes in the code (programming) and schematic (different pin mapping).
« Last Edit: December 06, 2007, 11:08:27 AM by Ro-Bot-X »
Offline Trumpkin
« Reply #2 on: December 06, 2007, 11:12:28 AM »
This website is good for learning electronics http://www.kpsec.freeuk.com/study.htm   ;D
Robots are awesome!
« Reply #3 on: December 06, 2007, 11:50:41 AM »
A battery has a + and a - pole.
Ground is the reference voltage, usually defined as 0V, or - as on the battery.
If you have two circuits (say one for a sensor, and another for the microcontroller), they usually need a reference voltage so that they can work together. This would be referred to as grounding. Forgetting to ground circuits is a very common (and the most likely) mistake among beginners, so its why you often read 'don't forget to ground your circuit!' :P
It is called 'ground' because back in the old days, dirt (earth) was considered the reference voltage.
Offline benji
« Reply #4 on: December 07, 2007, 02:51:06 PM »
hey michelle that should give u a push
http://www.owlnet.rice.edu/~elec201/Book/basic_elec.html
there is also a nice page about starting with bots in c
http://www.owlnet.rice.edu/~elec201/Book/control.html
enjoyyy
good ol' BeNNy
