Author Topic: Hotglue vs. Heat Shrink  (Read 9095 times)
Offline airman00Topic starter
« on: December 10, 2007, 07:55:54 PM »
I kinda ran out of heat shrink today , so I just hot glued over the solder joints.
Is that good, or will some unforeseen problem occur?
If its just like heatshrink, should I use it all the time ( its much quicker to do)
,Eric
Re: Hotglue vs. Heat Shrink
« Reply #1 on: December 10, 2007, 08:12:22 PM »
hot glue is much hotter than heat shrink . . . there is the possible risk the intense heat could damage your electronics . . . plus, heatshrink just looks cooler ;D
Offline ed1380
« Reply #2 on: December 10, 2007, 08:23:01 PM »
electrical tape?
« Reply #3 on: December 10, 2007, 09:01:19 PM »
electrical tape?
electrical tape gets loose
heatshrink and hotglue do not
Yea, but wouldn't soldering in the first place have the same heating side effect as hotglue?
Offline ed1380
« Reply #4 on: December 10, 2007, 09:26:06 PM »
anything you say
paulstreats
  • Guest
« Reply #5 on: December 11, 2007, 04:45:50 AM »
hot glue stays hotter for longer.
Offline Steve Joblin
    • Roebotz
« Reply #6 on: December 11, 2007, 07:37:29 AM »
I'm not quite sure on this, so it is more conjecture than fact, but I think the reason why they use heat shrink has to do with it's combustability.  Heat shrink will not burn, it will just melt.  I don't know what the characteristics are of hot glue, plus I don't know if there are any harmful fumes released when exposed to high temperatures.
Offline Trumpkin
« Reply #7 on: December 11, 2007, 12:05:10 PM »
I'm guessing since hot glue melts by high temperatures in the first place it will not release harmful fumes ;). I don't think hot glue burns, I have seen it used in toys electronics.
Robots are awesome!
Offline HDL_CinC_Dragon
« Reply #8 on: December 14, 2007, 10:46:21 PM »
I too have seen hot glue used in toy electronics. the furbies from like 8 years ago have a ton in there to project their micro processors and such.
United States Marine Corps
Infantry
Returns to society: 2014JAN11
