Author Topic: powering two sabertooths  (Read 2752 times)
Offline serengetiTopic starter
« on: December 12, 2007, 01:25:33 AM »
What equipment do I need to power two sabertooth 2x5 rc motor controllers with the same 7.2v pack? How can I put in in parallel so booth motor controllers get 7.2v? Do I need any special material wires? If you can make a plain diagram, that would be great.
Offline cooldog
Re: powering two sabertooths
« Reply #1 on: December 12, 2007, 06:12:51 AM »
all you need is some wire any kindwill work. just run one set of wires from your batterys to sabortooth #1 and run a seperate set of wires it sabortooth #2
questions
1)what motors are you using
2)why dop you have 2 motors controllers in 1 robot
3)are they a good investment
(i am going to buy one for my rc robots)
-admin
favorite web sites
http://www.instructables.com/
« Reply #2 on: December 12, 2007, 07:55:28 AM »
Just connect all the grounds together, and all the V+ together.
It might be a bit annoying connecting four wires to your battery, so you may want to make what is called a power bus.
