Author Topic: Suggestions for a ballfollowing bot  (Read 4253 times)
Offline neo01124Topic starter
« on: December 12, 2007, 01:11:27 PM »
We are working on a ball following robot and basically it shall have the following components:
1) Image processing part-we have taken care of this with some matlab code.
2) Linking a camera wirelessly to a laptop-not yet figured out
3) Setting up a wired serial link between laptop and bot(read motors)- taken care of using a simple max 232 and at89s52 uC and hbridges(motor
    control)
4)Setting up a wireless serial link between the laptop and the bot-basically we want the bot to be free of any wires i.e. no wires should go into the laptop from the bot.I figured out  that i can use a virtual serial port of my bluetooth dongle, a Zippys( isscbta) dongle, and use its COM port no instead of COM1(of the serial port keping everything else same) and using a bluetooth receiver(??gess thats what its calld) on the other side and i wont have to understand nethin about bluetooth and have seamless flow of data serially.
I want to kno what this mystery bluetooth receiver should be and what wireless camera should be used?? Moreover any other suggestions are weclome!!
Offline Mega
    • MegaBot Blog
Re: Suggestions for a ballfollowing bot
« Reply #1 on: December 12, 2007, 01:21:22 PM »
You can just buy a simple bluetooth module like this.
You have to make sure that your microcontroller can be connected to the bluetooth module.
If you're using a popular microcontroller like the Arduino or Basic Stamp, this won't be a problem.
For the image processing part, make sure to check out this site: http://www.roborealm.com/
Mega
Visit my robotics blog at http://megabotblog.blogspot.com/
Offline Steve Joblin
    • Roebotz
« Reply #2 on: December 12, 2007, 01:30:05 PM »
For extended range, consider XBee instead of bluetooth... just as easy to use, and maybe even a bit less costly.
« Reply #3 on: December 12, 2007, 01:34:44 PM »
wats the primary difference between blutooth and xbee(xigbee)?? and why is bluetooth on a higher price scale?
    • Roebotz
« Reply #4 on: December 12, 2007, 03:33:01 PM »
I asked the same question myself on Sparkfun's forum --> http://forum.sparkfun.com/viewtopic.php?t=8442
« Reply #5 on: December 13, 2007, 02:33:09 AM »
Thanks steve that post was really helpful!! any ideas about how to wirelessly send data from a usb camera on my bot to my laptop??
or maybe there is a turnkey solution for this..
« Reply #6 on: December 13, 2007, 08:52:07 AM »
just get a wifi cam............
« Reply #7 on: December 14, 2007, 07:21:51 AM »
any other options for the camera part??
