Author Topic: Line following robot - LDR question.  (Read 10120 times)
Offline prologTopic starter
« on: December 15, 2007, 11:06:13 AM »
I'm developing a line following robot with 8 LEDs and 8 LDRs as sensors
like this
I'm using PID algorithm..
I detect line by comparing the analog values of the LDRs with the threshold values..
Apparently, I always have to re-calibrate the threshold values for every new place.
Furthermore, the threshold values keep changing in accordance with the lighting pattern of the place..
Is there any smarter way to make the threshold values auto-adapt to any environment?
Thanks in advance...
Offline HDL_CinC_Dragon
Re: Line following robot - LDR question.
« Reply #1 on: December 15, 2007, 11:17:32 AM »
You could build a hood over the sensor bar so outside light cant get to the LDRs
BTW, theres 9 LEDs and 8 LDRs :P
United States Marine Corps
Infantry
Returns to society: 2014JAN11
paulstreats
  • Guest
« Reply #2 on: December 15, 2007, 01:22:07 PM »
it not necessarry to pair them, the important thing is to have enough detectable light. I think the reason that there is 1 more LED is so that each LDR has a light source on either side. Think about it if say the left LDR didnt have an LED to its left. It would only get 50% of the light that the others are getting along with an inaccurate reading. :P
PS. 1)Turn the LED's off, 2)Take a reading,3)turn the LED's on, 4)Take a reading. 5)Subtract the 1st reading from the 2nd reading. (This takes a reading of just the background light, then a reading of the background light with the led lights. Then subtracts the background light reading leaving only the true value of the reflected LED light)
« Last Edit: December 15, 2007, 01:26:10 PM by paulstreats »
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
    • Ro-Bot-X Designs
« Reply #3 on: December 15, 2007, 01:50:43 PM »
Hey Paul, check out this link: http://www.wrighthobbies.net/guides/linefollower.htm
About the LDRs, they are slow in response and the ADC conversion also takes time. Why not use IR LEDs and IR phototranzistors? They are digital and offer fast feedback so you can speed up your robot.
« Reply #4 on: December 15, 2007, 05:06:05 PM »
yeap, I call it auto-config.
Have your sensors during startup take readings of the line (physical angle your robot by 90 degrees so that all sensors are on the line) and the ground, add those two reading values, and divide by two for the threshold. This will have to be done for each sensor.
do this!
about ~50ms, depending on the size of your photoresistor. but if you modulate like paulstreats mentioned, then you'd want IR . . . but you'd still need a threshold.
« Reply #5 on: December 15, 2007, 07:29:43 PM »
Why 8 sensors? Thats overkill !!! :D
I am doing line following with 5 and it detects turns of every angle , as well as knowing when there is a break in the line
« Reply #6 on: December 15, 2007, 08:59:54 PM »
also why would the modulation paulstreats mentioned have to be IR?
paulstreats
  • Guest
« Reply #7 on: December 15, 2007, 09:28:00 PM »
it can still be done with ldr's only its a very slow process.
I suppose that more sensors = more resolution. It can be done with just 3. or even 2 if you dont mind your robot veering left and right. There is a link ro-bot-x left above that shows a line follower with just 1 sensor (although with 1 sensor its entirely possible for the robot turn 180 degrees and go the wrong way)
« Reply #8 on: December 15, 2007, 11:00:04 PM »
with only 3 you cannot detect sharp turns AND detect breaks in the line
only with 5
« Reply #9 on: December 16, 2007, 09:37:41 AM »
yea but i was only saying because he said 8 LEDs and 8 LDRs but theres 9 LEDs :P
But yeah, there is a benefit to having an LED on both sides of the LDRs as mentioned above
Infantry
« Reply #10 on: December 19, 2007, 04:01:59 AM »
Thanks guys!
That pic is not mine, btw..
My sensor board is very similar to that though
Anyway,
what are phototransistors and how do they offer digital feedback?
How do IR LEDs differ from normal LEDs?
Thanks!
« Reply #11 on: December 19, 2007, 05:18:16 AM »
the light they emit is invisible to the human eye, though cameras can pick up IR light
phototransistors work in basically the same way as the photoresistor, just for IR, think IR photoresisotr * which doesn't exist)
Offline Ro-Bot-X
  • Helpful? 25
    • Ro-Bot-X Designs
« Reply #12 on: December 19, 2007, 06:18:30 AM »
Check out this IR photoreflective sensor: http://www.wrighthobbies.net/catalog/product_info.php?cPath=34&products_id=105
The sensor has a IR LED that emits IR light that reflects of close distance (about 3/16 of an inch) objects back to the IR phototransistor. The phototransistor needs a pull up resistor of 10K and the IR LED a series resistor of about 330-470 ohm. The output will stay high until a reflection gets to the phototransistor and changes to low. This is very fast response and is digital, no need for ADC conversion.
« Reply #13 on: December 19, 2007, 10:51:33 AM »
Offline Barnaby
    • Electrolympics
« Reply #14 on: December 28, 2007, 12:29:57 PM »
My first line following robot has this same problem, I'm currently experimenting having an extra LDR on the top of the robot, to find the light level and callibrate the others accordingly, but I'm using comparators so that might not work with PIC's.
Thanks,
Barnaby
I am an amateur (very) robot builder.  By the last count, I have built:
1 (working) Robot
Have a look a it on my website!
http://electrolympics.bravehost.com
