Author Topic: Sonar Cross-Interference  (Read 2884 times)
Offline david_or_johnnyTopic starter
« on: December 18, 2007, 09:27:04 PM »
Hi all,
I recently undertook a navigation project, and to make it work, I need several sonar sensors. But my environment is very high resonance noise-wise (it's a very small maze); I'm afraid a sonar signal would bounce all across the walls and return to the other sensor and cause problems. If I use a 40 kHz sonar along with a 42 kHz sonar, should I expect no interference?
Furthermore, if my maze bot is traveling at 25 miles per hour theoretical top speed, will I be able to get sonar readings in time?
Thanks,
David
Re: Sonar Cross-Interference
« Reply #1 on: January 26, 2008, 05:45:11 PM »
sorry for the late reply, apparently I missed this post . . .
check the part datasheet for sensitivity
also, sound will bounce around for less than a second. if you send a pulse, wait a second, then send another pulse, there should be no ghost signals bouncing around.
resonance is not really the right term, resonance refers to something that vibrates at a particular frequency.
There will be some delay needed to process a signal, and your robot will have moved within that time period. Just do a quick calculation to determine how far your robot will have moved. Sensor data will become useless if your robot moves faster than your sensor data can be processed.
