Author Topic: Adjustable voltage regulators  (Read 3022 times)
Offline SeagullOneTopic starter
    • Loren John Presley - Author, Artist, Roboteer
« on: December 19, 2007, 08:39:39 PM »
I have a question that's been bugging me for a while.
How do you adjust adjustable voltage regulators? I'm going to begin the electritronics portion of my robot soon and I'd like to know how to use those.
Also, going back to my 5V-10V planetary gear motors (I'm not sure how much they'll draw. Their stall current is 17amps and there's no chart to go with them), what capacitors would any of you recommend I use to cancel out the electrical noise?
Thanks.
I think the chauffeur did it.
He did.
Offline ed1380
Re: Adjustable voltage regulators
« Reply #1 on: December 19, 2007, 09:01:25 PM »
datasheets. use them.
IIRC most use a resistor
« Reply #2 on: December 19, 2007, 09:03:16 PM »
they use resistors
paulstreats
  • Guest
« Reply #3 on: December 20, 2007, 07:16:16 AM »
The cheap ones, you have to connect a resistor between 2 of the legs - the resistor value you use depends upon what voltage you want. It should be in the datasheet.
The more expensive ones usually have a trimpot built in that you just turn (the even more expensive can charge pump above the input voltage)
« Reply #4 on: December 20, 2007, 12:51:45 PM »
Wow, I didn't know individual electronic components had datasheets of their own. I always just saw them lying around in bags at Radio Shack I've been wondering how to do it.
As for capacitors, its best to use 100uf for about every 250mamps. So at say 8amps a motor, I ought to use 3.2f capacitance for each motor. I probably ought to put some close to the batteries as well. What do you guys, think?
He did.
