Author Topic: Sharp IR in Australia  (Read 5670 times)
Offline BubblesTopic starter
« on: January 10, 2008, 05:49:07 AM »
I've been doing a bit of researching lately and have decided upon buying a microcontroller board to start some projects with. The only problem i am having at the moment is that i cannot for the life of me find a range finder in Australia!  >:( Does anybody know of a store which has a basing in Australia that will have a sharp IR range finder? I have looked at some which do not have a shop/warehouse in Aus however i would really like to find something from within Australia so that i will not have to pay for so much shipping.
Offline robonoob
Re: Sharp IR in Australia
« Reply #1 on: January 10, 2008, 02:10:53 PM »
sorry, i cant help you with your problem directly but i think that if money isn't an issue then u could use sonar instead... if u are building a wall avoiding robot or smthing then this would be better imo
« Reply #2 on: January 10, 2008, 03:40:25 PM »
hmmmm I don't think there will be a store that sells any . . . is shipping from singapore cheap for you? there are a few online robot stores based there if you google it . . .
« Reply #3 on: January 10, 2008, 05:25:49 PM »
yea i got smae problem spipping like 9$ us... sigh oh well ill just stick to photocells
paulstreats
  • Guest
« Reply #4 on: January 10, 2008, 07:07:40 PM »
please please please...... Save up the money for for one.
It really is worth it. Photocells have nothing to replace a ranging device
« Reply #5 on: January 10, 2008, 07:17:59 PM »
OK, thanks i will check that out.
Actually, does anybody know an alternative to using a sharp ir range finder when all i won't to accomplish is obstacle avoidance?
Offline robonoob
« Reply #6 on: January 11, 2008, 07:05:59 AM »
quote myself above: sorry, i cant help you with your problem directly but i think that if money isn't an issue then u could use sonar instead... if u are building a wall avoiding robot or smthing then this would be better imo
so i would use sonar.
« Reply #7 on: January 11, 2008, 08:12:51 AM »
Well, you can use two photoresistors seperated by ~2 inches.
http://www.societyofrobots.com/schematics_photoresistor.shtml
Then get a really bright low angle green LED (~15 deg, 4000 candela+), and put it right next to only one of your photoresistors.
Light will shoot out from the LED, bounce off of close objects, reflect back, then only hit the closer photoresistor.
Subtract one photoresistor ADC value from the other and that will be the range to the object.
Why use a second photoresistor? Its a method to cancel out ambient light.
« Reply #8 on: January 11, 2008, 04:32:02 PM »
oh geez thx a lot admin...ill try it now if that fails ill buy an ir range finder ;D
« Reply #9 on: January 11, 2008, 11:53:49 PM »
Thanks alot for that! I will definitely try it out ;D . What do you think about placing another photoresistor on the other side and averaging out the two side ones and using that value to minus from the central one so that it won't be as susceptible to something like a lamp on one side of the bot?
« Reply #10 on: January 12, 2008, 04:43:39 AM »
um... admin could you show me how to make the circuit...im really noobish and cant find it on the web.. :-\
« Reply #11 on: January 12, 2008, 10:18:31 PM »
« Reply #12 on: January 12, 2008, 11:36:44 PM »
oh soz im really blind  :D
