Author Topic: help me plz...wtf is this???  (Read 5375 times)
Offline SmAsHTopic starter
« on: January 11, 2008, 05:22:39 AM »
ok help what is this thingy ??? it was in a motion detector (store bought) and its a small barrel like a big resistor and had some werid fluffy copper coloured stuff in the middle.... and with pic chips do u need the stand and the programmer for them??
Offline robonoob
Re: help me plz...wtf is this???
« Reply #1 on: January 11, 2008, 07:06:56 AM »
maybe a picture of this thing would help us to help you :)
Offline Trumpkin
« Reply #2 on: January 11, 2008, 08:46:23 AM »
yes please post a picture or describe it alot better.  ;)
Robots are awesome!
« Reply #3 on: January 11, 2008, 02:10:20 PM »
ok ill just have to upload it to net hold a sec
« Reply #4 on: January 11, 2008, 02:27:19 PM »
Offline ed1380
« Reply #5 on: January 11, 2008, 02:36:10 PM »
the little sliding bolt or the IC under it?
« Reply #6 on: January 11, 2008, 02:40:37 PM »
no the big yellow thing
Offline bukowski
« Reply #7 on: January 11, 2008, 03:11:31 PM »
what kind of motion detector is it?
Is it passive (IR or electromagnetic disturbance) or active (Radar / Sonar)?
« Reply #8 on: January 11, 2008, 04:29:34 PM »
y'know i got no freakin idea..my friends dad is closing a factory and we hit it down so...yea ;D
Offline ed1380
« Reply #9 on: January 11, 2008, 04:33:41 PM »
is it one of these things?
« Reply #10 on: January 11, 2008, 09:04:01 PM »
yes it looks kinda like that but it doesnt rotate...
« Reply #11 on: January 13, 2008, 12:18:49 PM »
it appears to have writing on it . . . did you google search it?
yeap, you need a programmer to program PIC chips :P
« Reply #12 on: January 13, 2008, 02:46:07 PM »
so basicly i can just programme the chip then solder it on to the board?
paulstreats
  • Guest
« Reply #13 on: January 13, 2008, 03:12:42 PM »
You are best off soldering in a socket to your board and then plugging the pic into the socket.
If you have an older computer ~5 years with a serial port, you may be able to make and use a jdm style programmer for around $2. Mine works perfectly and you can program the pic while it is plugged into your circuit. You might want to use a multimeter to see if any of the pins on your serial port register a voltage of ~12 - 13 volts. If so then a jdm style will work.
The yellow thing on the original post is quite fuzzy so its hard to see exactly what it is, a hazarded guess by your description would be either an inductor coil or an aerial if its fitted with a radio module (to communicate wirelessly with the alarm system)
« Last Edit: January 13, 2008, 03:26:41 PM by paulstreats »
« Reply #14 on: January 13, 2008, 04:10:42 PM »
yea i originally thought that when i examined it but i needed an experts advice.
