Author Topic: how to know the working of the istalled components in pc board  (Read 3373 times)
Offline anupTopic starter
« on: January 15, 2008, 12:59:54 PM »
hello
i am not able to understand the installation of pc board ???
Offline Trumpkin
Re: how to know the working of the istalled components in pc board
« Reply #1 on: January 15, 2008, 01:24:05 PM »
I do not understand you question can you describe a little more
Robots are awesome!
Offline jsmoker
« Reply #2 on: January 16, 2008, 11:13:33 AM »
Are you looking for how to put in like a PCI or ISA or AGP card?  I'm making a large generalization here, but motherboards have 3 "upgradeable" points: the CPU, the memory, and the I/O PC slots. I assume you're talking about PC slots.  These also come in different type: ISA, PCI, PCI Express, and AGP.   Newer motherboards mostly come with just the PCI and PCI Express slots.  Replacing boards is fairly simple:
1) Make sure the board you're replacing matches the slot type
2) Ground yourself (which can easily be done by touching the metal frame of the chassis
3) unscrew "holder" on the old board and take it out (carefully)
4) insert the new board and screw in the "holder"
5) install software for the new board if needed
Opening the case varies from case to case, some have a sliding door, some have a swivel door, some require on or two mechanical buttons that need to be pushed before, or while opening the door, you just have to figure that one out yourself.
here's some pictures of slot types:
http://www.worldstart.com/tips/tips.php/992
http://en.wikipedia.org/wiki/PCI_Express
Re: how to know the working of the istalled components in pc board of robot
« Reply #3 on: January 18, 2008, 11:04:03 PM »
how do i know how to connect the components e.g microcontroller,capacitors wiring etc.and whats its working?
« Reply #4 on: January 18, 2008, 11:09:35 PM »
well there is no "sure" way to know components are working, unless you test each individual in a seperate circuit.. and to know where things go youll need to create or find a circuit. search around for different circuits on google or this site and then try them out. start off easy then go up.
~smash
Offline ed1380
« Reply #5 on: January 19, 2008, 12:26:08 AM »
read. read. and more reading.
heres for starters.
http://www.kpsec.freeuk.com/study.htm
I'll try to upload a couple books on electronics and robots
heres the newest one i have
http://rapidshare.com/files/84939931/Wiley_-_Electronics_For_Dummies_-_2005_-__By_Laxxuss_.pdf
« Last Edit: January 19, 2008, 12:51:54 AM by ed1380 »
