Author Topic: Mod servos without microcontroller  (Read 4348 times)
Offline BubblesTopic starter
« on: January 21, 2008, 08:20:46 PM »
when modifying the servo the tutorial says to use a .hex file to center the servo, however i was wondering if i could just hook it up to a receiver and use the transmitter joysticks to center it instead.
thanks in advance  :D
Offline ed1380
Re: Mod servos without microcontroller
« Reply #1 on: January 21, 2008, 08:25:54 PM »
that'll work. just make sure the trim is set to zero also
Offline Trumpkin
« Reply #2 on: January 21, 2008, 08:28:08 PM »
I did that and I had to modify them again after I got my microcontroller working. I had the trim settings set to zero. ???
Robots are awesome!
« Reply #3 on: January 21, 2008, 08:43:00 PM »
your servos were running at a different voltage in your circuit and off the reciever
Offline Trumpkin
« Reply #4 on: January 22, 2008, 09:13:29 AM »
I use the same battery for the reciever and the microcontroller.
Robots are awesome!
« Reply #5 on: January 22, 2008, 09:14:31 AM »
well either the pulse wasn't the same OR the servos were getting different voltages each time even though the batteries were the same
« Reply #6 on: January 22, 2008, 04:56:24 PM »
why would the amount of power they were getting affect whether or not they would go back to zero?
« Reply #7 on: January 22, 2008, 05:40:57 PM »
well the servo has circuitry inside it , so different power means the circuitry works slightly  differently
