Author Topic: Stepper Motors  (Read 4576 times)
Offline cooldogTopic starter
Stepper Motors
« on: February 02, 2008, 04:57:18 PM »
can i take a stepper motor and just apply a volatge and it will turn or will i need a microcontroller to make the right pattern commands
-admin
favorite web sites
http://www.instructables.com/
Offline benji
Re: Stepper Motors
« Reply #1 on: February 02, 2008, 05:13:51 PM »
in steppers you should regulate your powering to your steppers to make it turn, its a matter of powering a number of coils
,in most steppers you need 4 pins to do this and another 2 which is vcc and ground.
google stepper motors and youll get intensive info,there are also some ics made as stepper drivers
good ol' BeNNy
Re: Stepper Motors
« Reply #2 on: February 02, 2008, 05:18:24 PM »
so can i
(sorry i have no idea what you just said)
-admin
favorite web sites
paulstreats
  • Guest
Re: Stepper Motors
« Reply #3 on: February 02, 2008, 05:50:54 PM »
You can just apply voltages to the seperate coils 1 at a time. If you want to do it without a microcontroller, then you should be able to do something with a 555 timer and some mosfets
Re: Stepper Motors
« Reply #4 on: February 02, 2008, 06:08:53 PM »
so thats a no
-admin
favorite web sites
Offline ed1380
Re: Stepper Motors
« Reply #5 on: February 02, 2008, 06:32:14 PM »
something like the distributator cap off a car would work. the faster you turn the distributor the faster teh stepper will turn
Offline Rebelgium
    • orgcrime.net
Re: Stepper Motors
« Reply #6 on: February 02, 2008, 06:34:26 PM »
Isn't that the first sentence in every stepper motor tutorial?
You can't just apply voltage to the leads to make it turn. The easiest way is to use a stepper controller IC.
orgcrime.net
Re: Stepper Motors
« Reply #7 on: February 02, 2008, 06:50:22 PM »
is there a simple circut that i can make
or can i salvalge them from electonics
« Last Edit: February 02, 2008, 06:55:28 PM by cooldog »
-admin
favorite web sites
Offline hazzer123
Re: Stepper Motors
« Reply #8 on: February 03, 2008, 04:38:29 AM »
Heres a schematic that controls a unipolar stepper motor. All you need to give it is a direction and a step pulse.
http://www.aaroncake.net/circuits/stepper.asp
I used it when i was beginning electronics. It was useful in both helping me get a stepper motor turning, and understanding logic gates.
Take time to really understand the circuit. And understand every circuit you use. Then you will be able to make your own more quickly.
www.icrobotics.co.uk
Offline benji
Re: Stepper Motors
« Reply #9 on: February 03, 2008, 05:16:28 AM »
sure no, to make it turn u need to make your 4 bits turn which means the powering to the coils turn and thus the shaft turns
good ol' BeNNy
Re: Stepper Motors
« Reply #10 on: February 03, 2008, 08:28:01 PM »
can use the motor drivers from printor or scanners to controll stepper motors
-admin
favorite web sites
