Author Topic: robostix avrisp cable  (Read 4513 times)
Offline vidamTopic starter
  • Robotronics.org
    • DC/MD/VA Robotics and Automation Team
« on: February 12, 2008, 08:15:46 PM »
I want to make the robostix avrisp cable as shown in this website:
http://docswiki.gumstix.com/Robostix_AVRISP_cable
The 10-pin ISP is on the Robostix, but the AVR programmer is 6-pin.
in figure 4-1 http://www.atmel.com/dyn/resources/prod_documents/doc2521.pdf
shows the connections between 6-pin and 10-pin ISP. Is this the correct schematic to use to match up the wiring appropriately to make the cable?
Thanks!!!!
Offline TrickyNekro
  • Hardware and Firmware Designer
    • The Hellinic Robots Portal
Re: robostix avrisp cable
« Reply #1 on: February 14, 2008, 07:51:40 AM »
Yes they should be ok!!!
  • Robotronics.org
« Reply #2 on: February 20, 2008, 05:03:14 PM »
I just had the cable made at work for the AVRISP programmer 6-pin to 10-pin ISP on the Robostix. I must say what a pain in the behind to make this cable. First they don't tell you what parts you need. So you have to infer from the picture what parts to buy. Luckily, we had all the parts at work and an expensive crimper helps too!!!!!
Offline ed1380
« Reply #3 on: February 20, 2008, 05:24:57 PM »
yeah i remember people having problems with their $50 robot because of the 10 pin and 6 pin programmers
  • Robotronics.org
« Reply #4 on: February 20, 2008, 06:55:38 PM »
Now that I finally have everything hooked up, I get the flashing orange light on the Atmel AVR Programmer. I remember there was a post about this problem but now I cannot find that post. The post had a link to a downloadable driver. Can someone link me to it?
Thanks,
  • Robotronics.org
« Reply #5 on: February 21, 2008, 09:59:47 AM »
Thanks,
Found what I was looking for: http://www.societyofrobots.com/robotforum/index.php?topic=3013.msg24470#msg24470
  • Robotronics.org
« Reply #6 on: February 21, 2008, 10:15:54 AM »
This is how I fixed the blinking orange led:
The Manual firmware upgrade instructions on page 28:
http://www.atmel.com/dyn/resources/prod_documents/AVRISPmkII_UG.pdf
I now get a green light! Yay!
