Author Topic: filtered PWM problem  (Read 2828 times)
Offline SomeSabaTopic starter
« on: February 22, 2008, 12:37:06 AM »
hello everyone
I'm trying to read the PWM from my wireless futaba receiver. Im using a low-pass filter that has a 10k ohm resistor and .1uF capacitor, with the transmiter stick centered the flilter outputs .269 volts, and .185 and .369 for left/right.
The receiver and my atmega168 share a common ground, and i connected the filter's output to my ADC.
After many weeks of tweeking software ive concluded that my ADC value somehow cycles through all 3 apropiate voltage values. For example if i have my LED turn off when the PWM is .185 or .369 and turn on at .269 the LED will basically flash or flicker depending on my ADC prescaler.
Should i changed my low pass filter or just try to read the PWM periods with interupts and timers?
I've spent many weeks on this problem, any help is appreciated
Offline Tsukubadaisei
Re: filtered PWM problem
« Reply #1 on: February 22, 2008, 03:08:48 AM »
My advise is to use the search feature:
http://www.societyofrobots.com/robotforum/index.php?topic=3099.0
look at the last post, it has source code and everything. I did it by reading the PWM directly(without using the integrator circuit).
« Reply #2 on: February 22, 2008, 02:36:26 PM »
Thank you for your links, but the links you have me tell me how to do what i already am doing/know how to do. I  was wondering if anyone knew why i am experiencing the problem i am with the flashing LEDs, or if i should just give up and switch to reading the PWM
« Last Edit: February 22, 2008, 02:37:59 PM by SomeSaba »
« Reply #3 on: February 22, 2008, 08:59:20 PM »
When I tried the integrator circuit I first tried without an op-amp and got almost the some voltages you are getting( 0.2V~0.3V) I think those voltages are very low and I couldnt read the signal very well. When I debbuged using the terminal app that comes with the gcc developer I got lots of random small values. So I connect a op-amp with a 1kΩ and 10kΩ for 10X amplifying and got 2V~3V depending on the PWM. Thanks to that I was able to read the signals with precision.
So I think you could:
1) use an op-amp
2) use the software solution and read the PWM directly (after all it is just software, not a mess with components and cables)
