Author Topic: Homemade ESCs  (Read 5403 times)
Offline TrumpkinTopic starter
Homemade ESCs
« on: February 23, 2008, 09:05:21 AM »
I have found a couple of homemade ESCs that look pretty good. I thought I would post them since somebody on this forum probably has a use for them.
http://www.nyblimp.com/articles/ESC.htm
http://www.rc-airplane-advisor.com/electronic-speed-controller.html
Robots are awesome!
Offline frank26080115
Re: Homemade ESCs
« Reply #1 on: February 23, 2008, 11:23:31 AM »
They are not hard to make from scratch, just program a microcontroller to read pulse lengths and output PWM signals to a H-bridge.
Servos are expensive, it's best not to just waste them.
Offline TrickyNekro
  • Hardware and Firmware Designer
    • The Hellinic Robots Portal
Re: Homemade ESCs
« Reply #2 on: February 23, 2008, 11:27:21 AM »
If you want to get more involved with electronics.... have a look here...
http://images.google.gr/imgres?imgurl=http://www.stefanv.com/quiet/riser100/t-photo9.jpg&imgrefurl=http://www.stefanv.com/rcstuff/riser100.html&h=142&w=450&sz=23&hl=el&start=8&um=1&tbnid=JddZDaBJ5xI6gM:&tbnh=40&tbnw=127&prev=/images%3Fq%3DHomemade%2BESC%26um%3D1%26hl%3Del%26sa%3DN
Homemade ESCs are becoming popular.... But I can't still find an ESC schematics for brushless...
Have something in mind???
I had a broken one and it worked fine!!!
And HS-311 cost almost nothing... And you can still keep the gears... PWM and H-bridge can be not as good as expected...
Cheers
Re: Homemade ESCs
« Reply #3 on: February 23, 2008, 12:05:25 PM »
I just posted those because i thought other people might want to use them for something.
Robots are awesome!
Offline javafiend
Re: Homemade ESCs
« Reply #4 on: February 26, 2008, 07:48:39 AM »
So what's the difference between an ESC and a DC motor driver?
Offline ed1380
Re: Homemade ESCs
« Reply #5 on: February 26, 2008, 03:58:57 PM »
an esc is a type of dc motor driver.
an esc takes servo signals and transforms them into dc motors outputs.
motor driver is to animal
as ESC is to dog
Offline TrickyNekro
Re: Homemade ESCs
« Reply #6 on: February 26, 2008, 04:55:02 PM »
Well the main difference is that ESC uses pulses to operate... But Motor controller would use what ever like pulses, data (most commonly), etc
It's like ed mentioned...
Cheers!!!
