Author Topic: Book Detector Circuit  (Read 3974 times)
Offline airman00Topic starter
« on: February 28, 2008, 10:26:00 PM »
I'm sure you have all heard of the trick in movies, where someone goes into a hidden room , which can only be opened by pulling out the correct book from a bookshelf.
I decided to change this movie cliche a bit. I took a sharp IR sensor and mounted on a bookshelf. It measured the distance to any book that was pulled out, and checked to see if that was the "key" book. After getting it to work with one book pulled out. I made it a combination of books. It has to be 7-9-5 in that order, any other books are ignored. It resets after 15 seconds. I made a video and it is currently processing on YouTube so i'll post it here , once its done processing( probably when I wake up it will be done)
Right now the code to activate a buzzer.
Pull book 7 out
push 7 in
pull 9 out
push 9 in
pull out 5
KEY SOLVED- buzzer rings
,Eric
Re: Book Detector Circuit
« Reply #1 on: February 28, 2008, 10:49:08 PM »
here it is
[youtube]tt6SJHbgCqQ[/youtube]
Keep an eye on the LCD, it shows which book is selected on it. Either 7, 9, or 5
Listen to the buzzer after the combination 7-9-5 is done
Keep in mind this shot is without any editing whatsover, first shot
Offline hazzer123
« Reply #2 on: February 29, 2008, 01:39:38 AM »
Thats a really awesome idea, very original :D
It would be good if you could reset the password. eg Once you entered the password correctly, you then move 3 more books, and the password is reset to that.
How did the sensor sense which book it was? Did you pre program the kind of sensor values book 5 would give ect? Or does it look for relative distances? (ie if 7,9,5 works, would 6,8,4?)
Nice
www.icrobotics.co.uk
« Reply #3 on: February 29, 2008, 06:15:38 AM »
6-8-4 does not work
It is preprogrammed to teh distance values it gets for each book
i'll make some documentation today
« Reply #4 on: February 29, 2008, 03:05:04 PM »
I made a CAD of it
As you can see the Sharp IR sensor just takes a reading of the distance , when a book is pulled out the microcontroller checks to see what book is in what distance range. Then its just a regular electronic lock program
Offline Trumpkin
« Reply #5 on: February 29, 2008, 03:25:59 PM »
awsome idea!
Robots are awesome!
