Author Topic: another one for the $50 robot  (Read 3158 times)
Offline ajax spray n wipeTopic starter
« on: March 02, 2008, 12:38:26 AM »
For my $50 robot, I want to put either a sonar rangefinder or a sharp  IR rangefinder. With either choice, could anyone please tell me if having a maximum range of ~5 metres is too much for a robot that might be used as a sumo bot?
Also for the IR rangfinder, is having 2 rangefinders (1st one:20cm-150cm; 2nd one:100cm-550cm) of different ranges a good idea, or am I doomed to fail?
Could anyone please reccomend an MCU for the ATmega168 chip that has in-built DC motor drivers or H-bridge so that I can use DC motors intead of servos for moving around?
Thanks.
Re: another one for the $50 robot
« Reply #1 on: March 02, 2008, 06:43:40 AM »
what do you plan to build?
and also why are you building the $50 robot MCU , if you are just going to buy your own?
H bridges come in DIP packages also, so you could add it yourself to the $50 robot mcu
