Author Topic: Charging Batteries  (Read 4855 times)
Offline MillenniummanTopic starter
Charging Batteries
« on: March 13, 2008, 08:13:26 PM »
Looking a this site, there is a diagram of a circuit for checking battery charge level, but I can't find one for actually charging batteries. I'd like for them to charge in my robot from a 12VDC power supply. In what I am doing right now, I am planning on 10 NIMH AA batteries in series, maybe in the future 2 sets of those in parallel. Any tips/links on how to charge that from such a power supply? Should they get 12V or 1.2V ?
Re: Charging Batteries
« Reply #1 on: March 13, 2008, 09:14:41 PM »
Welcome to the forum
Here is a helpful link
http://www.powerstream.com/NiMH.htm
Also, since you have 10 identical NiMH batteries in series , practically speaking it is one battery and not 10 batteries. So treat it like its one 12V battery.
,Eric
« Reply #2 on: March 13, 2008, 11:02:46 PM »
That information is very useful, but it seems to be more oriented towards choosing a normal battery charger and there don't appear to be any circuit diagrams.
Offline AndrewM
    • I Am.  When?
« Reply #3 on: March 14, 2008, 05:43:28 AM »
Texas Instruments makes what appears to be a rather nice IC for handling battery recharge.  I picked one up, but haven't had a chance to integate it into a circuit yet.  Here's the link:  http://focus.ti.com/docs/prod/folders/print/bq2000.html
The PDF datasheet on the page includes sample schematics.  MAXIM-IC also has some charging circuit diagrams on their website.
blog: www.iamwhen.com
Saving the world from humanity one robot at a time.
« Reply #4 on: March 15, 2008, 03:55:15 PM »
How many mAh? Might be better to just buy a $40 charger (cheaper than your batteries, anyway!)
As for a circuit, just attach it directly to your charger. No circuit needed. You can also use a desktop power supply to control the current. Just make sure you don't go above the rated current or overcharge (you need to time it), and lower the current to trickle towards the end.
edit: Forgot to mention, you must charge at above the battery voltage, like 14V or something like that. Use a diode to make sure the current only flows into your battery.
« Last Edit: March 15, 2008, 03:57:06 PM by Admin »
« Reply #5 on: March 16, 2008, 07:25:36 PM »
2000 mAh. They cost less than $30, which is just a little more than the equivalent (voltage and mAh, figuring in how I am setting up the AAs) lead acid battery at Frys and a lot lighter and more versatile. But also a little more complicated.
It seems more elegant to just plug in a DC power supply into the robot, but maybe a charger would be the best way to go.
« Reply #6 on: March 16, 2008, 07:32:56 PM »
Also, I am wondering if there is any information available on how many amps a given battery can supply? Like a AA NIHM vs. a little lead acid vs. a salvaged laptop battery. When I try to look for it, I just get amp hours, but I would think that a battery could only supply so many amps at a time, and a quick test with a motor, a wheel, and my ability to stop it seems to show that AAs provide can't provide as much as my desktop power supply.
« Reply #7 on: March 16, 2008, 08:33:50 PM »
It will/should be in the datasheet:
Discharge rate: 3amps
(or something like that)
Offline benji
« Reply #8 on: March 17, 2008, 06:02:48 AM »
can a dc regulator be used as a charger to the batteries?without any circuit in between? as it is a constant voltage source
good ol' BeNNy
« Reply #9 on: March 21, 2008, 09:03:57 PM »
you don't want to use a voltage regulator, or even a regulated voltage . . . and its still not the power source :P
Offline benji
« Reply #10 on: March 22, 2008, 05:27:37 AM »
i mean by voltage regulator a trans , power>trans>6 volt dc regualted
if i connect this directly into a battery ,whats gonna happen?
as the voltage is the same nothing i guess is gonna happen ... just to be sure
anyone can post a battery charger circuit?
good ol' BeNNy
Offline ed1380
« Reply #11 on: March 22, 2008, 11:53:26 AM »
i've noticed that batery chargers charge at about 133% the batery voltage rating.
and yes you could use a wall wart as a charger. thats what cheap chargers are
