Author Topic: can i use this serial port or not for ATmega8?!!  (Read 4317 times)
Offline mohamedTopic starter
« on: March 16, 2008, 11:03:26 AM »
now the final step is programming the ATmega8 in the 50$robot
but the admin said in the tutorial that u r goging to need either the AVR STK Serial Port Dongle Programmer
or the AVR ISP2 Programmer
but the first one i didnt find it and the other is too expensive for me so can i use just a normal serial port and i connect it to the board by a serial port socket instead of the 10 pin header but it will be 9 pins instead of 10 so i dont know if this is possible
here is a pic for what i mean (seial port socket and serial port)
Offline ed1380
Re: can i use this serial port or not for ATmega8?!!
« Reply #1 on: March 16, 2008, 11:21:35 AM »
first you'd need to instal a bootloader into the atmega8. then you can program it without the dongle. but until then you'll need to find a programmer
Offline superchiku
  • cooll
« Reply #2 on: March 16, 2008, 11:33:13 AM »
try to make a bsd programmer then ulll be able to program it using win avr the schematic for the programmer can be lfound out by google search
JAYDEEP ...
IT AND ROBOTICS ENGINEER
« Reply #3 on: March 16, 2008, 12:51:54 PM »
do u think i can do this by using ponyprog or not to program the ATmega8
also i want to know if there is any other ideas or not thanks
here is the link http://booksbybibin.14.forumer.com/viewtopic.php?t=3
« Reply #4 on: March 17, 2008, 11:20:49 AM »
i have a question can i programe the ATmega8 by using this method or not
plz answer me http://www.bsdhome.com/avrdude/
coz i didnr find the AVR serial port in mt country and the other programmer is too expensive
« Last Edit: March 17, 2008, 11:21:58 AM by mohamed »
Offline pomprocker
« Reply #5 on: March 17, 2008, 12:08:02 PM »
On instructables.com there are step for creating your own AVR programmer.
Ahh here is the link
Ghetto Programming: Getting started with AVR microprocessors on the cheap.
http://www.instructables.com/id/Ghetto-Programming%3a-Getting-started-with-AVR-micro/
« Reply #6 on: March 17, 2008, 03:10:59 PM »
thanks pomprocker thats realy good link and easy for a noob to follow  ;D
but does that make me use the ponyprog i mean does the ponyprog support parallel ports or only serial ports
i mean that i can ollow the tutorial steps (50$ robot) as it is or there will be any changes
thanks
Offline pomprocker
« Reply #7 on: March 17, 2008, 04:04:46 PM »
If you build a separate programmer, you don't need to incorporate it into your $50 robot board (no male headers in the corner, and no blue wires underneath).
ponyprog will send out to any com port you set it to.
« Last Edit: March 17, 2008, 04:09:35 PM by pomprocker »
