Author Topic: PVC  (Read 7790 times)
Offline gamefreakTopic starter
  • Robo-Enthusiast
PVC
« on: March 19, 2008, 09:58:38 AM »
Would you consider PVC as a good building material? Build a framework out of PVC pipe and then take thin sheets(1/8") and cover it?
Re: PVC
« Reply #1 on: March 19, 2008, 11:55:28 AM »
It is a good material
except for that little problem of it being toxic and all
http://www.besafenet.com/pvc/about.htm
  • Robo-Enthusiast
Re: PVC
« Reply #2 on: March 19, 2008, 12:42:46 PM »
Seems odd that plumbing would be made of toxic materials. The point of the pvc is to have a strong but light box that is semi waterproof.
Offline Asellith
  • Helpful? 9
    • CorSec Engineering
Re: PVC
« Reply #3 on: March 19, 2008, 03:06:29 PM »
I think only the fumes are toxic not the plastic. Probably would not be a good idea to eat it but the c does stand for chloride  so yah it's toxic
Jonathan Bowen
CorSec Engineering
www.corseceng.com
Offline ed1380
Re: PVC
« Reply #4 on: March 19, 2008, 04:00:40 PM »
o man gotta stay away from that NaCl  :P
Re: PVC
« Reply #5 on: March 19, 2008, 04:02:03 PM »
LMAO ed !!!  :D  :D :D  :D  :D  :D
PVC gives off toxic fumes when you burn it AND also some fumes escape without any burning or anything , just by evaporation
  • Robo-Enthusiast
Re: PVC
« Reply #6 on: March 19, 2008, 06:02:18 PM »
hmm Sodium explodes when it touches water(not really explodes but it still combusts) and chlorine is a poison gas, when combined, they form an essential thing to life, why do chemistry and common sense not go together? The same goes for water, hydrogen is flammable, oxygen is necassary for a combustion reaction, combine them and they put out fire, CURSE YOU CHEMISTRY
So would building a frame of pvc pipe and then putting 1/8" thick sheeting on it provide a durable chassis for snow plowing?
Offline ed1380
Re: PVC
« Reply #7 on: March 19, 2008, 07:13:07 PM »
FOR A ROBOT. YES.
FOR ATTACHING TO YOUR CAR. NO
FOR ATACHING TO A ROBOT THE SIZE OF YOUR CAR. NO
  • Robo-Enthusiast
Re: PVC
« Reply #8 on: March 19, 2008, 07:24:08 PM »
what with all the yelling?
Offline ed1380
Re: PVC
« Reply #9 on: March 19, 2008, 08:11:47 PM »
MY CAPS BUTTON IS STUCK.
ITS NOT YELLING.
Re: PVC
« Reply #10 on: March 23, 2008, 03:49:57 PM »
Yeap PVC is generally good.
It does have a cracking problem if you machine it badly . . . and it tends to only come in round pipes . . .
As for toxicity, certainly better than metal pipes . . . mmmmm rust! Or lead pipes during the roman times . . .
Offline maverick monk
Re: PVC
« Reply #11 on: March 28, 2008, 08:02:33 AM »
yeah, just dont chew on it or put it under your pillow when you sleep... it will be good, i used 1/8th inch pvc sheet for my robot chassis, it worked well, the rest of the chassis and drive train.....
Re: PVC
« Reply #12 on: March 28, 2008, 09:18:00 AM »
I would be in a well ventilated area when machining it , just in case
and maverick can u post a pic of your bot?
Re: PVC
« Reply #13 on: April 01, 2008, 07:59:56 AM »
its a wip, will get a better drive system.
