Author Topic: ADCRESULT1  (Read 4634 times)
Offline orchidTopic starter
ADCRESULT1
« on: April 04, 2008, 12:24:00 AM »
Hi there...
I have a problem here regarding to the ADCRESULT1. When I use 1 sensor, then I got the ADC value on the ADCRESULT0. But, when I connect the second sensor to the ADC pin on the tms320f2812 dsp board, the ADC value on the ADCRESULT1 are not as expected. Here I attach some of the source code that I have edited for your reference.
  AdcRegs.ADCTRL1.bit.ACQ_PS = ADC_SHCLK;
   AdcRegs.ADCTRL3.bit.ADCCLKPS = ADC_CKPS;
   AdcRegs.ADCTRL1.bit.SEQ_CASC = 1;        // 1  Cascaded mode
   AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0x8;
   AdcRegs.ADCCHSELSEQ1.bit.CONV01 = 0xA;
   AdcRegs.ADCTRL1.bit.CONT_RUN = 1;       // Setup continuous run
  AdcRegs.ADCMAXCONV.bit.MAX_CONV1 = 0x1;  // convert and store in 2 results registers
// Clear SampleTable
   for (i=0; i<BUF_SIZE; i++)
     SampleTable[i] = 0;
   // Start SEQ1
   AdcRegs.ADCTRL2.all = 0x2000;
   GpioDataRegs.GPBDAT.all = 0xFFFF;
   // Take ADC data and log the in SampleTable array
   while(1)
     for (i=0; i<AVG; i++)
        while (AdcRegs.ADCST.bit.INT_SEQ1== 0) {} // Wait for interrupt
        // Software wait = (HISPCP*2) * (ADCCLKPS*2) * (CPS+1) cycles
        //               = (3*2)      * (1*2)        * (0+1)   = 12 cycles
        asm(" RPT #11 || NOP");
        AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1;
        Voltage1[ConversionCount] =( (AdcRegs.ADCRESULT0>>4) );
Voltage2[ConversionCount] =( (AdcRegs.ADCRESULT1>>4) );
Please help me to solve this prob.
thanks...
Re: ADCRESULT1
« Reply #1 on: April 06, 2008, 11:36:13 AM »
It sounds like cross interference.
Make sure your power supply is clean and good.
Also, make sure you have the sensors plugged into the same place as specified in code - sometimes the ADC can 'take' voltages from nearby ADC pins.
Re: ADCRESULT1
« Reply #2 on: April 06, 2008, 07:25:16 PM »
i got it...
thanks
