Author Topic: hexapod powering  (Read 4480 times)
Offline benjiTopic starter
hexapod powering
« on: April 19, 2008, 08:06:22 AM »
hey folks, i did baught a battery for my bot ,,6 volts 9amps ..sounds a lot but here is what i got to power
12 servos (500ma * 12==6 amps)
1 stepper(500ma)
a sharp ir (nearly 500ma)
RF transmitter/reciever( ??)
and the atmega128
my question is about consideration for capasitors at the input,,for such big current drag whats the best cap tp use at the in?
all the stuff above are feeding from the battery directly exept the atmega128 which is having 5 v after a 7805
now i have a 0.33uF at the input and a 0.1uF at the 7805 out (micro in)
good ol' BeNNy
Offline BANE
  • E=roboticsC^2
Re: hexapod powering
« Reply #1 on: April 20, 2008, 05:54:44 AM »
where did you get that battery :o
Bane
Offline Tsukubadaisei
« Reply #2 on: April 20, 2008, 07:17:38 AM »
That is fine, just follow what the datasheet says.
« Reply #3 on: April 20, 2008, 03:18:43 PM »
so no need other than this little 0.33 uf cap for all that stuff?   ???
good ol' BeNNy
« Reply #4 on: April 20, 2008, 03:28:54 PM »
top secret  ;D
to be honest with ya i didnt try it yet , its just written 9 amps and i doubt it can give 5 or 6 which i would be glad with
good ol' BeNNy
« Reply #5 on: April 26, 2008, 06:29:01 PM »
Guess the cap value, no other way. 100uF and a 1uF as a minimum.
The cap removes sudden drains/spikes in the voltage, but to know what that spike is, you'd have to test it after everything is already hooked up and running.
You can use an oscope to see how caps affect the spikes.
« Reply #6 on: April 27, 2008, 09:18:28 AM »
should i expect too many spikes from batteries?
good ol' BeNNy
« Reply #7 on: April 29, 2008, 02:57:04 PM »
The batteries don't cause the spikes, the devices that use the battery power does. Motors are the worst offenders . . .
Offline izua
    • izua electronics
« Reply #8 on: April 29, 2008, 03:03:12 PM »
servos won't suck 500mA all the time. depending on the stepper motor function, you can also power it down after it does its job, since the detent torque might be enough, or at least lower the current through it.
anyway, where did you get the battery? lead-acid? :D
« Reply #9 on: April 29, 2008, 03:31:43 PM »
actually i didnt buy it yet but i saw it at a store,, it lookslike the AA batteries but way more thicker
and its written on it 9000 mA
good ol' BeNNy
« Reply #10 on: April 29, 2008, 03:32:43 PM »
each cell provides 1.5 v so i have to ge 4 serially connected
good ol' BeNNy
