Author Topic: commanding MOS/FETs  (Read 3107 times)
Offline izuaTopic starter
    • izua electronics
commanding MOS/FETs
« on: April 25, 2008, 10:39:22 AM »
I'm planning to build an efficient stepper controller.
I want to understand how to command MOSFETs efficiently so they don't heat at all - I've seen it done for DC motors and steppers sucking 3-4 amps with the transistors cool to touch. (I think they were IRF or IRFZ family). I've been told that one factor is having a very low drain-source resistance while another factor is pumping a bigger voltage into the gate.
I haven't been able to find any more info on this, but I have a few BUZ11 power mosfets around to play with (rated at 30A, 50V, 75W and 150/300ns switching time).
What I want to do is a stepper control circuit for <4Amps, with the transistors cool.
Ideas, suggestions, any experiments anyone done before? thanks.
Offline Rebelgium
    • orgcrime.net
Re: commanding MOS/FETs
« Reply #1 on: April 25, 2008, 12:00:50 PM »
Those are the only ones I know to.
Having the max allowed gate voltage ensures your FETS will conduct for 100%, resulting in less heat.
orgcrime.net
    • izua electronics
« Reply #2 on: April 25, 2008, 12:10:23 PM »
I'll need that voltage from somewhere. and an extra pair of transistors to drive that voltage from my uc.
what is the characteristic that determines at what voltage the transistor goes into saturation?
Offline GHF
    • GeeksHaveFeelings
« Reply #3 on: April 25, 2008, 12:35:20 PM »
You don't have to do all that. There are MOSFET drivers that take care of the higher voltage and and be controlled straight from a micro's pins.
-Xo W.
    • izua electronics
« Reply #4 on: April 25, 2008, 12:39:18 PM »
I haven't found any for sale, that's the problem.
Then again, I might be looking for the wrong stuff. Any names?
« Reply #5 on: April 27, 2008, 01:43:51 PM »
see mosfet datasheet for a graph at the bottom ;)
go to digikey or mouser.com and type 'mosfet driver', you will find a few thousand :P
As for choosing a mosfet, if its a one-off design, just get over-rated mosfets. No harm in that . . .
