Author Topic: ti-84 plus in robotics?  (Read 4916 times)
Offline maverick monkTopic starter
« on: April 25, 2008, 08:07:09 PM »
I know the io port in my ti84 can be used for sensors, as well as the usb port, and tuts for using the ti84 as a robot board?
Offline JesseWelling
  • Only You Can Build A Robot!
Re: ti-84 plus in robotics?
« Reply #1 on: April 25, 2008, 11:20:51 PM »
As a novelty hardware hack, I'd say it is possible. But if you wanted the most capable robot you personally could make, I'd say you could do much better with less hackery using a decent micro  such as an AVR, ARM, or PIC.
Offline Fredrik Andersson
« Reply #2 on: April 26, 2008, 12:13:26 AM »
Maybe this will be interesting for you then:
http://www.smallrobot.com/scimath.html
Current project: Pirrh - Portable Intelligent Round Rolling Hexapod
Offline bietz
    • My projects
« Reply #3 on: April 26, 2008, 10:49:04 AM »
BTW, does anybody have any links on how the I/O protocol works for the TI89? (I believe it's the same as TI84) Because I've wanted to try to make a sort or robotics platform for a calculator for a while now... But it's hard to find that kind of info on the web...
« Reply #4 on: April 26, 2008, 11:20:51 AM »
my thoughts were that you could use it to store information, and preform calculations, it would probobly be very usefull if your robotics project involved complicated trig problems for figuring out location, since alot of that stuff seems to be hard to put on a small pic or avr.
Offline ed1380
« Reply #5 on: April 26, 2008, 12:32:14 PM »
im pretty sure its i2c for the ti83. ive never been able to find out more
http://i2c-bus.org/
