Author Topic: not sure about microcontrollers  (Read 5661 times)
Offline pianomanTopic starter
« on: May 01, 2008, 09:09:14 PM »
Yeah, I have been researching for awhile about what microcontrollers would be the best for learning the most, and doing the most. I think that it would probaly be good to program in C, because it seems that most microcontrollers are programmed in that language.
But no matter how much research I do, I can't seem to decide on a microcontroller to buy. It would be best for me to hear about your expiriences and how you learned to program.
I have alot of ideas floating around in my mind that would be so awesome to see in action and use for doing chores.
I have a budget of about $60
Thanks in advance
I HAVE TO GO BECAUSE MY SIS WANTS THE COMPUTER BACK!
Offline JesseWelling
  • Only You Can Build A Robot!
Re: not sure about microcontrollers
« Reply #1 on: May 01, 2008, 10:24:35 PM »
I think AVR's are the best way to go if you want cheap microcontrollers that have free C compilers.
Although you might need a little bit more that $60 to get you started (programer: $20-50, development board $30-100) depending on what you can find. I'd start looking at Sparkfun.com for nice AVR development boards.
Offline superchiku
  • cooll
« Reply #2 on: May 01, 2008, 10:27:20 PM »
i can help you with an avr programmer which is basically $1 other things you have to buy..
JAYDEEP ...
IT AND ROBOTICS ENGINEER
Offline benji
« Reply #3 on: May 02, 2008, 08:20:39 AM »
AVR ATmegas
good ol' BeNNy
« Reply #4 on: May 03, 2008, 11:19:24 AM »
Depends on your application, your requirements, etc.
Can't help you if you don't know this :P
« Reply #5 on: May 07, 2008, 05:23:42 PM »
thanks for all the quick replies (sorry for not responding sooner).
i think i am going to buy a bunch of Arv's and follow some tutorials off the web, and instead of using a development board i will just program them through my breadboard.
i am also really interested in programmer for basically $1 superchiku, please tell me about it!
Offline superchiku
  • cooll
« Reply #6 on: May 08, 2008, 12:52:57 AM »
ok ill help u but 1st tell me if ur computer has a parallel port in it , if it isnt there then this wont work
JAYDEEP ...
« Reply #7 on: May 08, 2008, 01:35:46 PM »
I do have a parallel port!
will this programmer support most Avr's?
« Last Edit: May 08, 2008, 01:37:16 PM by pianoman »
Offline izua
    • izua electronics
« Reply #8 on: May 08, 2008, 01:54:18 PM »
Programmer (hardware) doesn't care.
If you use a programmer via the parallel port, that's merely a power amplifier. Flashing/Downloading to flash is made by software. And software can always be updated to support new AVRs ;)
Offline benji
« Reply #9 on: May 08, 2008, 03:39:56 PM »
you can use the ponyprog serial port programmer to, do it yourself ,the components are so cheap too
good ol' BeNNy
Offline superchiku
  • cooll
« Reply #10 on: May 09, 2008, 04:38:49 AM »
ya it will support any avr u want , tell me ur email id ill mail it there ...
JAYDEEP ...
« Reply #11 on: May 09, 2008, 08:06:36 AM »
ok i just sent you my email superchiku and also, i think i may try to build the si-prog as well.
(thanks for the info benji).....(and izua)
« Last Edit: May 09, 2008, 08:09:28 AM by pianoman »
