Author Topic: psp  (Read 3408 times)
Offline eduard2000Topic starter
psp
« on: May 04, 2008, 01:53:54 PM »
hy i have a psp ( but te scren is broken )and i want to usit as the microcontroller for the robot
is it posibel
Offline JesseWelling
  • Only You Can Build A Robot!
Re: psp
« Reply #1 on: May 04, 2008, 02:03:04 PM »
I think it might be.
This would be the first step I would take  ;D
http://www.linuxdevices.com/news/NS3739081571.html
Re: psp
« Reply #2 on: May 04, 2008, 02:06:03 PM »
yea but what output would you use?
maybe use the screen or speaker output?
Re: psp
« Reply #3 on: May 05, 2008, 12:01:20 AM »
I don't know too much about the PSP but if the chip has I2C or SPI there is a whole plethora of GPIO expanders and A2D units you could use.
But you are correct you wouldn't really use a PSP for I/O as much as the thinking part of the Robot.
Offline Asellith
  • Helpful? 9
    • CorSec Engineering
Re: psp
« Reply #4 on: May 05, 2008, 03:43:44 PM »
It has a USB port that would work for most things needs converting to ttl level uart but that should work
Jonathan Bowen
CorSec Engineering
www.corseceng.com
Re: psp
« Reply #5 on: May 09, 2008, 06:23:48 PM »
Yes, but it would be steel cool to try ;D
Offline Tsukubadaisei
Re: psp
« Reply #6 on: May 11, 2008, 08:27:02 AM »
The first thing you should do is to use the pandora battery and install a custom firmware. Then  you can download a c or lua(or any other laguage that is available for psp) library for the psp, because they not olny allow you to easly program the psp but they also include code for the interface(buttons+analog stick), mem. stick, IR(if you are using the 1000 series), usb, wi-fi, and UMB drive(there are hudreds of place on the internet you can find this stuff easily, so I leave it to you). The psp cant directly interface with your robot components so you need a microcontroller. I see 2 advantages of using a psp in robotics: first is its speed(333mhz). second it is easy to debug(relatively "highdef" LCD + stereo speakers).The disadvantage is the fact that the process is more troublesome then usual. Not to mention that your lcd is broken so there is no way you can debug or even install the custom firmware. The last resource would be disasseble the psp and work directly with the motherboard, but that would be just as fun  as building a robot out of a computer mother board: it sucks.
Offline Asellith
  • Helpful? 9
Re: psp
« Reply #7 on: May 11, 2008, 02:30:17 PM »
If you want to replace your screen sparkfun carries the screen
Jonathan Bowen
CorSec Engineering
www.corseceng.com
